Hot Rods laSalle Transmission question
Discussion in 'The Hokey Ass Message Board' started by Neilb, Dec 4, 2022.
  1. Neilb
    Neilb
    from Mead Co
    I haven’t had much luck finding a usable top shift LaSalle for a project I’m working on but I do have a nice side shift LaSalle from a low mileage car. Before I try fabricating something does anyone know if there was ever an off the shelf conversion kit? Thanks
  2. alchemy
    alchemy
    I think there’s a HAMBer who still makes the same ones he did decades ago, and has ads in the cl***ifieds. Maybe King Shift is his name?
  3. deucemac
    deucemac
    Hurst made one long ago. A friend had an Olds with one in it when we were in high school circa 1965. If I recall correctly, it was a syncro-lock and not a mystery shifter. Also, I believe they used the same clamp type arms as Chevy did. It wouldn't be too hard to fabricate one since the syncro-lock has changed names to Master shifter and some searching should turn up Chevy arms. Fabricating a mount plate and brace isn't that hard and shift rods can be shortened for your trans. Good Luck!
  4. vtwhead
    vtwhead
    @KingShift in NJ I believe has his version for those side shift trannies. I had a Hurst kit years ago and kick myself now for not making templates to reproduce the pieces.
    @Neilb I sent you a pm.
  5. vtwhead
    vtwhead
    Also, @Eddie in GA. might know where a 37 is.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    A few years ago, someone from Canada, I believe, was selling reproduced Hurst style mounting brackets for the '38-'53 transmissions. Like someone already mentioned, the shift arms are the same style as the ones used on 1949-65 Chevrolet three speed transmissions, and pretty much any Hurst three speed shifter will work.
    bchctybob likes this.
  7. Neilb
    Neilb
    from Mead Co
    Thanks for the info guys. I think I have a Chevy 3 speed somewhere so I’ll definitely take a close look at that route.
  8. I sold a NOS Hurst side shift conversion a few years back. Still kind of kick myself for letting that one go. I've got a side shift LaSalle with Hurst shifter on the shelf.
    Will try and remember to grab some measurements and pictures for you.
    Paul likes this.
  9. Paul
    Paul
    Editor
    I have run the Hurst Mystery Shifter on a '50 Olds 3 speed, same transmission with short shaft, I liked the way it shifted better than the '37 top shift but I like the stick placement in the '37 better, plus it's a much more aesthetically pleasing stick, to me anyway.
    tough call.
    bchctybob and Speedy Canuck like this.
  10. vtwhead
    vtwhead
    here is all I could dig up in my file. Gives you an idea of the bracket you could make. Of course this shows it for the closed drive line application but I am certain you can engineer around that. There is also a support bar made from flat stock that connects the bracket to the trans bolt into the bellhousing. I have one somewhere. I will get a pic to you of it.
    mgtstumpy, kadillackid, Paul and 2 others like this.
  11. Paul
    Paul
    Editor
    here's a snapshot of one on a spare transmission
    I have correct rods, arms and stick somewhere..
  12. Neilb
    Neilb
    from Mead Co
    Thanks again guys. The images will be very helpful for me and others. It gives me a good picture of how I can go about it. The most unusual part of my plan is I’m hoping to actually put it behind a hot rodded Cadillac flathead:).
    bchctybob and Paul like this.
  13. Paul
    Paul
    Editor
    a '40 flathead with '37 transmission, sometimes I wonder why I let them get away..
    can't keep them all I guess
  14. Neilb
    Neilb
    from Mead Co
  15. Neilb
    Neilb
    from Mead Co
    Looks like something went awry with the picture upload. Note the water pump facing backwards. There were two of these side by side facing backwards in the tank. They sat at an angle so the carb mounting surface on the intake is canted. I badly wanted to mount the engine in a car on an angle, take it to a show, and wait to see if anyone got the joke.
    070F0CD6-AB70-411B-8F15-309C97A0BEA3.jpeg F35DF5E9-63E3-4030-A2F5-4EC2180B8631.jpeg
  16. Thread like this are so cool. I do not ever see myself using a LaSalle but the knowledge is priceless! thanks guys!!!!
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
  18. Try Mark Shephard, 1-860-884-6833, days. He used to do a lot of Lasalle transmission conversions. He had mounting plates made for the conversions. He may still have some mounting plates available.
    51 mercules likes this.
  19. bchctybob
    bchctybob
    I made up this shifter for a Chevy 3 spd w/OD from an old Hurst 3 spd shifter, another combo that's hard to find a shifter for. I used some old random rods that I had. Note that the arms are just heavy wall tubing with levers welded on, easy to make. Set screws attach them to the shafts, flats were ground in the shafts after everything is adjusted.
    Moriarity and Nailhead Jason like this.
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Looks rugged enough!
  21. Paul
    Paul
    Editor
    '49-'50....Oldsmobile-Cadillac-LaSalle-9 bolt bottom cover....M/S CL-3854
    vtwhead, bchctybob and Moriarity like this.
  22. Neilb
    Neilb
    from Mead Co
    That looks great. Very clean looking job.
  23. bchctybob
    bchctybob
    Thanks, I think I had less than $50 in it and two or three nights work. I really needed the shifter to move towards the center of the car and up to fit better in my ‘31 Tudor, so buying one, no matter what the cost wasn’t really going to get me what I needed.
    You can sometimes buy good Hurst shifters for cheap when the seller doesn’t have the rods and levers. I lucked out and found one with the bolt on handle for $25. I was going to modify a stock old Ford handle but I never got that far. It was a fun project.
  24. hot rodd kid
    hot rodd kid
  25. vtwhead
    vtwhead
    my neck hurt so I fixed this for ya
