Technical 1931 Pontiac build - 25 years and counting
Discussion in 'The Hokey Ass Message Board' started by 31 B'ville, May 15, 2021.
  1. nochop
    nochop
    from norcal
    OUTSTANDING
    31 B'ville likes this.
  2. vtwhead
    vtwhead
    Flawless execution as usual.
  3. dirt t
    dirt t
    In a word WOW!!
  4. TFoch
    TFoch
    Nice metalwork!
  5. Rj27buick
    Rj27buick
    Beautiful- thanks for sharing all the details
  6. HRBOB34
    HRBOB34
    Very Nice!! I had a31 pontiac sedan that I changed alot of the wood
    in the body to steel! I also took 2 inches out of the roof! after having a garage fire, i made it into a sedan delivery! I did it in the 80s! Car still lives in Fla today!
    It has a slant 6 turbo charged! I will try to dig out some photos!
  7. i.rant
    i.rant
    Excellent design and execution of the many details you’ve built into your Pontiac.
    Your skills are admirable. Thanks for taking the time to share your ideas and photos.:D
    This is me .
    I am not you .
    this car has been planned and executed perfectly .
    everything is thought out and simply does it’s job functionally and with style .
    you have made this car your own , while sticking to a traditional hot rod recipe .
    i friggin ‘ love it !!!
  9. 31 B'ville
    31 B'ville
    from SE Pa
    7D8299EA-82B1-4AF9-A376-95223ADC0CD5.jpeg 308AD6A3-1370-4ECB-9929-F910BA7A1881.jpeg D737974C-FD8E-421C-A2D6-56EA2B13C259.jpeg DEBEA85F-E069-4DF6-98E4-97BE22C3E1BE.jpeg E4C2E4AB-AD88-4502-ABD6-9CAB8C9DA06C.jpeg I received the new gas tank and even though the dimensions matched my original tank it didn’t fit exactly the same way. The upper tank supports on the frame had to be trimmed and reshaped and the filler stub did not line up with the original hole in the tank cover.
    With the new tank mounted, my brother relocated the hole in the tank cover.
    Shitbox, Okie Pete, SS327 and 8 others like this.
  10. 31 B'ville
    31 B'ville
    from SE Pa
    Did not want to weld shut the holes for the fender bolts so I made covers with studs on the back to hold them on.
    I also built a battery cover after deciding on a shape using cardboard. IMG_6656.jpeg IMG_6979.jpeg IMG_6661.jpeg IMG_6811.jpeg IMG_6867.jpeg IMG_6868.jpeg
  11. 31 B'ville
    31 B'ville
    from SE Pa
    A “new” old coolant overflow bottle was added and my son-in-law spent a lot of time over the Thanksgiving and Christmas holidays getting the wiring pretty much completed, including the interior and IMG_7318.jpeg IMG_7314.jpeg IMG_7315.jpeg IMG_7519.jpeg dash lighting.
  12. foolthrottle
    foolthrottle
    So, thats what perfection looks like
  13. bchctybob
    bchctybob
    Where did you get your air cleaners? Are they 5 1/8” or 4 7/32”
    The car is just amazing….
    Thor1, 31 B'ville and SS327 like this.
  14. 31 B'ville
    31 B'ville
    from SE Pa
    Air cleaners are (were) 4 7/32” reproduction Corvette and SD Pontiac. Carbs are Carter 500s which are 5 1/8”, so my brother trimmed the bases larger and made aluminum spacers to match the carbs. Not sure, but I don’t think anyone makes that air cleaner to fit the larger carbs. IMG_7520.jpeg IMG_7521.jpeg
  15. bchctybob
    bchctybob
    Nice job on the adapters! I just need to loosen up my wallet and buy those air cleaners.
    winduptoy and 31 B'ville like this.
  16. HRBOB34
    HRBOB34
    Nice work!
  17. 57tailgater
    57tailgater
    from Georgia
    What is that coolant overflow bottle from? I like the look! What is the approximate size?
    winduptoy likes this.
  18. 31 B'ville
    31 B'ville
    from SE Pa
    The overflow bottle is 11” tall ( to the top of the cap) and 4 1/2” diameter. My brother found it at an estate sale. Here is a picture of the return address and the only paperwork in the box. I have never seen another one and couldn’t find anything else about it. Maybe someone else on here knows more. IMG_7562.jpeg IMG_6191.jpeg
  19. 57tailgater
    57tailgater
    from Georgia
    Looks like that's tank has been around for a while! Cool find. Awesome thread to follow - keep up the great work!
  20. TFoch
    TFoch
  21. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_7739.jpeg IMG_8070.jpeg IMG_8011.jpeg IMG_8075.jpeg All of the gl*** is cut (I chose the old green “E-Z Eye” tint) and all but the windshield are installed along with the garnish moldings
    TFoch, winduptoy, SS327 and 10 others like this.
  22. Okie Pete
    Okie Pete
    Clean , well thought out project. Looks great
  23. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_8790.jpeg IMG_8848.jpeg IMG_8881.jpeg IMG_8900.jpeg IMG_8901.jpeg IMG_8984.jpeg I used a Mini ( early 1960s ) oil cooler for a transmission fluid cooler and coated the floor and firewall with 3 coats of ATAC paint from DEI. With the body removed from the frame I made heat shields from embossed aluminum to further keep exhaust heat from reaching the interior. Dis***embly continues to prep the frame and then the body for paint.
    TFoch, winduptoy, Shitbox and 14 others like this.
  24. Tim
    Tim
    from KCMO
    Those embossed panels are clever!
    winduptoy, 31 B'ville and bchctybob like this.
  25. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_9093.jpeg IMG_9121.jpeg IMG_9255.jpeg IMG_9256.jpeg After adapting a rotisserie designed for a vintage Mini to hold my frame and taking care of some last minute welding, we began the process of filling , sanding, filling, sanding, priming, sanding, priming, and more sanding. Finally it was time to paint.
  26. clem
    clem
    Wow !
    That ch***is with that colour paint has turned out really nice !
    Looking forward to seeing the body painted now.
  27. This project is the pinnacle of hotrodding. Brilliantly, creatively, aesthetically pleasing and the craftsmanship is impeccable. If it was a roadster it easily could outcl*** many of the AMBR contestants. It is art, pure and simple.
    31 B'ville, clem and Thor1 like this.
  28. 31 B'ville
    31 B'ville
    from SE Pa
    IMG_9367.jpeg IMG_9368.jpeg IMG_9372.jpeg IMG_9369.jpeg IMG_9370.jpeg Off of the rotisserie and back on 4 wheels.
  29. guthriesmith
    guthriesmith
  30. TFoch
    TFoch
    Looking great!
