Technical Lost my spark
Discussion in 'The Hokey Ass Message Board' started by spillaneswillys, Dec 11, 2022.
  1. I tried to start my 51 Dodge truck today and in going down the line of what's wrong I found that I lost my spark. I am not familiar with a distributor where there is no oil. I ***ume I can pop a cover off the top and there will be some sort of coil pack but I would like some advice first. Help! distributor.jpeg
  2. Paul
    Paul
    Editor
    that big black thing on top of the cap is the coil
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    NoelC and chryslerfan55 like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    That is an HEI electronic ignition distributor. first you need to verify that there is 12 volts to the power wire going to it. after that there are several things that may be wrong, the ignition module, the pickup coil and the ignition coil could all be culprits
  5. Bob Lowry
    Bob Lowry
    And make sure that the plug that goes up and into the module is good and tight. Could be that simple.
    squirrel likes this.
  6. Blues4U
    Blues4U
    from So Cal
    Check to see if you're getting 12v to the distributor. These photos may help:
    [​IMG] [​IMG] [​IMG]
    Bob Lowry and bchctybob like this.
  7. Hitchhiker
    Hitchhiker
    I've had numerous graphite ****ons that go from the coil to the rotor break on HEI on thr last couple years. Could be something simple. Really they are pretty simple to begin with...
    belair and jaracer like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    My Son recently repaired his barbers 56 Chevy that has the same HEI. Turns out who ever wired it used one of the extra acc fused terminal :confused: from the fuse panel. It blew the fuse. :rolleyes:
  9. 1320 Fan
    1320 Fan
    There are many distributor rotors that burn through under the center coil contact blade causing a short to ground through the distributor shaft. Check this after you verify power to distributor as Moriarity suggests.
  10. 51504bat
    51504bat
    I'd start with the rotor. They work fine one moment and literally the next don't.
    belair likes this.
  11. Flathead Dave
    Flathead Dave
    from So. Cal.
    I had this happen to an OT car with electronic ignition. It turned out to be the wires inside of the distributor and under the coil pac were old and brittle and had broken and not making contact. Easy fix if this is the case for you.
    My car would suddenly lose power while driving or start up. You can tell an electrical issue from a fuel issue while driving.
    It's a very sharp loss of power as if you turned out the lights.
  12. squirrel
    Don't they make a pill for that now?
    sorry, looks like the other guys have you pretty well covered for getting the ignition figured out.
    ottoman, MMM1693, '34 Ratrod and 11 others like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’s a wonder Morairity and Jim have not said you need one of these. :) 961BC907-5684-45A3-B829-D2C295D27AE3.png
  14. The truck had been sitting in a cold garage for a month before this happened.
  15. Mouse built a house ?
    Chevy HEI is pretty reliable till it’s not .
    module is the usual culprit
    after cap and rotor .
    the coils are pretty resilient and reliable
    could be the little wires that connect inside the cap or body of the distributor .
  16. Driver50x
    Driver50x
    It was also common for the wires to break at the pickup coil. Those wires have to bend every time the vacuum advance moves. Give those two wires a gentle tug and see if they break off.
    ottoman, impala4speed and Moriarity like this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, good old points ignition. the most reliable system ever. When I was a mechanic back in the late 70's and 80's these Hei's were almost new and were terribly problematic. Typically when the rotor burns thru and shorts to ground the reason is that a plug wire has gone bad and the voltage is forced to find a new path. Also as someone else stated the wires to the pickup coils are prone to break because it moves every time the vac advance moves the plate. They look like they are connected but the copper is broke inside, a gentle tug on them will tell. the distributor needs to come out to change the pickup. as stated earlier too the modules are subject to having problems too and a lot of people carry a spare because of it. All of this combined with the fact that these are the ugliest distributors ever made make me wonder why anyone who cares anything about a traditional looking engine compartment would ever want to run one
  18. fastcar1953
    fastcar1953
    How many carry extra points? Why are we even talking about hei here?
  19. Any recommendations for a quality replacement kit?
  20. Last edited: Dec 11, 2022
  21. 19Eddy30
    19Eddy30
    from VA
    all mention above ,
    Let us know witch it was ,
    If 12v present , more likely
    Module or burnt rotor .
    Module will go bad with out any warning.
    VANDENPLAS likes this.
  22. 427 sleeper
    427 sleeper
    Self contained- No power wire needed. Properly maintained, will provide years of trouble free service. :D:rolleyes::cool: s-l1600 (1).jpg s-l1600 (1).jpg
  23. hemihotrod66
    hemihotrod66
    As fare as HEI systems go the GM unit is pretty good.... The only thing that people forget to do is when they replace the control unit they forget to coat the base of it with dielectric silcone grease... It keeps it cool...
    19Eddy30 likes this.
  24. Driver50x
    Driver50x
    I’ve worked on many of these things, and I personally like them. But……they don’t fit the HAMB timeframe…..I’m a little surprised this thread is still here…….
    ProtoTypeDesignFlauz likes this.
  25. alchemy
    alchemy
    The best way to test the condition of an HEI distributor is with a flotation test*. Remove the complete distributor from the engine and take to a nearby body of water like a pond or lake. Maybe a deep river will work. Your kitchen sink is not good enough.
    Take the distributor in your right hand, and will a full forward motion, throw it to the middle of the water. The test won't work at the edge of the water.
    Can you still see the distributor floating on top of the water? If yes, the distributor is no good. If you cannot see the distributor, it was operational.
    *flotation test procedure taught by Bruce Lancaster.
  26. squirrel
    Isn't that how they decided if someone was a witch? in a Monty Python movie?
    VANDENPLAS, Blues4U, 19Eddy30 and 2 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    We extort and pilfer, we filch and sack
    Drink up me hearties, yo ho
    Maraud and embezzle and even hijack
    Yo ho, yo ho, a pirate's life for me
  28. Budget36
    Budget36
    I’m guessing the movie borrowed the idea from history;)
    egads and squirrel like this.
  29. 19Eddy30
    19Eddy30
    from VA
    Why all the hate for GM HEI !?
    Sense the Introduction in 70s having own 30 plus GM HEIs & fleet repair maybe only had / seen 5 failures in some way not related to cap & rotor maintenance,
    Only complaint big & bulky,
    Several times I have test fire engine on the Ground by just dropping in HEI and Supplying 12vs
    '28phonebooth and G-son like this.
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No hate. Just a matter of era correctness.
    egads, 19Eddy30 and Moriarity like this.
