Technical Need new gas tank (65 Mustang style)
Discussion in 'Traditional Customs' started by bartmcneill, Dec 11, 2022.
  1. bartmcneill
    bartmcneill
    from Ada, OK
    A lot of you guys have built or seen a lot of cars built, so I am asking for input. I would like to install a gas tank in my hot rod that has a surrounding lip mount like a 65 Mustang or an early MGB. I just don't want to use hanger straps. What all car's gas tanks have the surrounding lip gas tank that you know of? I appreciate the help. I installed a tank from a MG midget and it is only 7 gallons so wanting to go larger. After I learn about other tanks then I can research and get the right size that will fit. Thanks a bunch.
    jimgoetz likes this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    How about a Falcon? HRP
    alanp561 likes this.
  3. rockable
    rockable
  4. hotrod37
    hotrod37
    from Indiana
    1970 Mustang bolted down on each side to make floor of trunk.
  5. 51504bat
    51504bat
    Tank in my '54 Ranch Wagon didn't mount with straps. Bolted with tabs front and back.
  6. bartmcneill
    bartmcneill
    from Ada, OK
    Nope, same as Mustang which is too big.
  7. X38
    X38
    Perhaps you could provide dimensions of the space you have available? A photo would also be good.
    alanp561 and lothiandon1940 like this.
  8. 34Phil
    34Phil
    call tanksinc.
  9. rudestude
    rudestude
    A tank for your Hot Rod....gee a bit more info might help , a picture possibly?, type of car.. oh ya hot rod, some measurments or even a sketch, location?
    VW bug tanks are flange mounted
    lothiandon1940 and X38 like this.
  10. rudestude
    rudestude
    Well I did a Hot Rod fuel tank search and this is what they showed. 16708398401583180478466962741025.jpg
  11. indyjps
    indyjps
    Mustang tank is too big ? What dimensions work for you ? Mustang and Jeep tanks are 2 of the most available replacement fuel tanks.
    This is a Jeep tank, which probably mounts on straps, but 15 gallon and taller / narrower than a mustang tank.
    Bob Lowry, ramblin dan and alanp561 like this.
  12. jimgoetz
    jimgoetz
    I used a VW tank from around mid 60s I think. Only about 10 or 12 gal. though. DSCN1176.JPG DSCN1182.JPG
  13. ramblin dan
    ramblin dan
    I used a 48 to 52 pickup on my Deuce. Flat side against the back of the seat and it is only 9 inches wide. You might have to relocate the filler neck though. 48 to 52 pickup.jpg
  14. 1971BB427
    1971BB427
    from Oregon
    Falcon and Mustang tanks are identical except for volume size, so either works well. The advantage of either is the flange that it bolts in with is at the top, so the entire tank hangs below the flange, not up into the trunk space. They're also cheap and plentiful from numerous sources found on the internet. They'll have a 70 ohm Ford sending unit, so you'll need a gauge for that resistance. Last one I bought was about 7 yrs. ago and it was $115 delivered to my door. Likely much more these days, but I'd expect around $150 with sender now.
  15. Used a 55 t bird tank in a 64 ford truck 33.5 x 23.5 x7.5 deep 17 gal . I drilled thru the flange and bolted it in .
