Technical analysis paralysis is kicking my ass!!!!! Opinions and help requested. (tire clearance issue)
Discussion in 'The Hokey Ass Message Board' started by timdhawk, Dec 12, 2022.
  1. timdhawk
    timdhawk
    Gentleman, I am 10 yrs into a 5 yr frame off build and am still only working on the frame! My issue is this: I have 1/4" gap between my front tie rod ends and the tire walls. (there's no rim clearance issues)
    I have one piece 1st gen Camaro disc brake spindles with 2" drop and the beefier upgraded Mercury steering linkage set-up. I'm running G78's on 15" x 6" rims with 3.75" back spacing. I tried 1/4" spacers but that bombed due to lug nut stud length not allowing nearly enough bite.
    Options I've garnered so far:
    1. Keep my G78's and get new 15 x 5" rims that will allow for smaller back spacing but possibly run the risk of fender clearance issues in the future (***uming I get that far someday!).
    2. Keep my current nice red powder coated rims and change all 4 tires to 710-15's which have a narrower width. (those *****es are pricey!!!)
    3. Try to find and replace wheel studs with longer ones that will allow the spacers to work.. That seems like a less desirable "fix" overall.
    Any other ideas or suggestions? Anything I'm missing?
    What is a generally accepted minimum clearance amount between tire sidewalls and tie rod ends?
    Thanx
    Lloyd's paint & glass likes this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    is the car a 50 Merc? I like 6.70-15's on Mercs
  3. timdhawk
    timdhawk
    yea, 1949 Merc.
  4. goldmountain
    goldmountain
    Get lug nuts for those old style ET wheels that ran that funny oval washer thing that could accommodate different wheel bolt patterns. They seat on that conical face and have a bit longer shank for your short wheel studs.
  5. Studs and spacers, and move on to the next hurdle...
    Butler 32 and timdhawk like this.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    When do you project the rubber will hit the road?
    Should give more clearance then the Gs
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    yeah, if it is going to be 10 plus more years I would not buy tires now. they will be 10 yrs old by the time you are going to drive it, and the tires these days don't seem to last as long as they used to. Also the 6.70's are better off on a 5 inch wide wheel (they will work on 6" though) ... Keep building, get the body and fenders and everything else on it at ride height and evaluate your options then
  8. squirrel
    ...and post some pictures.
    My guess is that the tie rod is real close to the rim, where the tire sidewall won't be able to flex, so 1/4" gap might actually be OK. But I'm just guessing, because you didn't give us any pictures.
    anthony myrick and Moriarity like this.
  9. Dan Hay
    Dan Hay
    I don't know what this means: "beefier upgraded Mercury steering linkage set-up. "
    Are the Steering Arms original Merc? What are they made of? If they are original steel I'd heat them up cherry red, bend in some more clearance and then shorten the tie rod.
    High test 63 likes this.
  10. timdhawk
    timdhawk
    Fair point:
    20221213_143724.jpg 20221213_143512.jpg 20221212_121837.jpg 20221213_143400.jpg
  11. timdhawk
    timdhawk
    That is truly a magical question that I wish I had an answer to. Hopefully no more than 5 yrs which, by that time will already be 15 yrs past the first time I said that...
    No, my steering arms are part of the one piece cast 1st Gen Camaro spindles.
  12. Dan Hay
    Dan Hay
    Somebody correct me if I’m wrong but I stand by what is posted earlier, heat ‘em, bend ‘em, shorten tie rods.
  13. Mr48chev
    I think that is about the same as I had on my 51 when I had the same front end on it. You can press out the studs and put longer studs in if you need to run the spacer though.
  14. Lloyd's paint & glass
    That wouldn't worry me in the least. After a spin around the block you'll be able to see if there was any contact, which I doubt there would be, but if so I'd go with a smaller tire.
    timdhawk, nochop and Moriarity like this.
  15. SDS
    SDS
    Try it out as-is first, the. Do what DH says
    timdhawk likes this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    He has Camaro spindles, I think they are cast iron, can't heat and bend those. 1/4 inch of clearance in that area should not be a problem, not much or any tire flexing that close to the rim...
  17. lippy
    lippy
    from Ks
    I see a dead end approaching. Lippy
  18. timdhawk
    timdhawk
    Care to expound?
  19. Aren’t the first gen Camaro steering arms bolt on?
  20. “At risk of fender clearance”
    Probably not an issue on a skinny tire.
    but I’d probably build the car and iron that minor issue out when the sheet metal is on
  21. oldiron 440
    oldiron 440
    Another reason to buy tires last is welding gas destroys rubber in tires, so if you have heavy bodywork (welding) you shouldn't have the tires your planning on eventually running running in the same room when fabricating. You should not store tires in a welding shop either.
  22. SDS
    SDS
    ****ysis paralysis, circling back around
  23. SDS
    SDS
    What kind of welding gas, shielding gas?
    caprockfabshop likes this.
  24. larry k
    larry k
    Been a certified welder all my working life , and never heard that welding gas story ???
  25. iagsxr
    iagsxr
  26. caprockfabshop
    caprockfabshop
    I've only heard about Cloroform being harmful to tires. Saw it on CSI back in the day...
    '28phonebooth and Bandit Billy like this.
  27. I’d build the car then do a couple Thunder Road maneuvers
    If the tires rub, then fix it :)
  28. 1-SHOT
    1-SHOT
    from Denton
    Has any one thought about STP Steering Ackerman Principle? You may have to correct the Ackerman to make it turn without scrubbing the tires
  29. jimpopper
    jimpopper
    Might I suggest a build Coach. Someone experienced to set goals and give advice to help you along.. You could start a build thread on here and get an occasional, "what's up?".
