Projects built lots of cars, but never a 32 roadster...
Discussion in 'The Hokey Ass Message Board' started by SDS, Oct 14, 2021.
  1. NJ Don
    NJ Don
    Scott, what ratio are you running. I started with a 3.73 but the revs were quite hi on the highway. Went to a 3.25 and it's better but I wonder if a 3.0 would work? I can go from 1st into 4th and the car just pulls away. Still has plenty of snap with the 3.25 so I'll probably leave it alone. Get around 15 mpg around town with SBC. Just my $.02.
    pprather likes this.
  2. SDS
    SDS
    3.50... with tires this tall, that should cut some of the gear ratio out
  3. SDS
    SDS
    SEC trim black rattle can, $25 each, is worth every penny when it gets down to small parts
    shortypu likes this.
  4. DDDenny
    Great paint, yes, the price has gone up a bit, a couple years back it was on backorder, worth the wait.
    This replaced my old standby as ch***is black when Krylon changed their formulation.
  5. SDS
    SDS
    PXL_20221203_193117721.jpg Home at last
    shortypu, RockyMtnWay and Budget36 like this.
  6. RockyMtnWay
    RockyMtnWay
    Really enjoying your build thread. Three years(ish) from getting your frame back til you’re ready to start final ***embly is pretty dang quick for a project like this…especially compared to other projects I’ve seen here on the HAMB. :p
    Kudos.
  7. vtwhead
    vtwhead
    Looking good. Fun time now ***embling everything.
  8. SDS
    SDS
    I got the rolling ch***is back in December of 2020. Didn't start working on it until June of 2021, when I picked the body up at the NSRA show in PA.
    Thanks for the encouragement, I planned to drive it this summer, but paint took much longer than expected and life got in the way (have 3 small kids). It is all working out though, as a fellow builder says, I've had time to "fluff everything" and have focused on the details while the paintwork was happening. I'm super stoked to not have any more dirt, rust or grime to deal with - will be like putting together a big kit.
  9. SDS
    SDS
    Clean, buff, bolt on, repeat.
    Hopefully for good this time...
    PXL_20221206_165405306.jpg PXL_20221206_165410525.jpg PXL_20221206_165415074.jpg PXL_20221206_165716930.jpg
    This part is fun
  10. SDS
    SDS
  11. SDS
    SDS
    Took tomorrow and the week between Christmas and New Years off. In-laws will be here, so I'll be out in the garage getting this thing mostly ***embled
    brEad and Anderson like this.
  12. NJ Don
    NJ Don
    Scott,
    Hope to see you on the road in '23! Happy Holidays!
    DC
  13. SDS
    SDS
    No more blaming it on the paint guy...
    Merry Christmas everyone!
    31Apickup, shortypu, Bugguts and 3 others like this.
  14. NJ Don
    NJ Don
    Was the brown paint in post 227 just a primer or was black the color from the start?
    Happy Holidays by the way!!
  15. SDS
    SDS
    Planned it this way - frame suspension gas tank headlights tail lights and grill shell are all single stage gloss black... The body is a custom mixed color to look like old school red oxide primer base (which is more brown than current primers), covered with a sand clear coat
    05snopro440 likes this.
  16. SDS
    SDS
    Had a great day with my 12-year-old son today. We put most of the front end together...
    I introduced him to Never-dull, just like my grandfather did when I was his age. He was totally amazed at how bright it makes the chrome.
  17. SPEC
    SPEC
    Who makes SEC CH***IS BLACK PAINT?
  18. NJ Don
    NJ Don
    Scott,
    That color combination should be a nice contrast.
    All your gloss black parts are the same on my car except my body and grill shell are matte black.
  19. SDS
    SDS
    Securities and Exchanges Commission
    SEM
  20. SDS
    SDS
    Slow but steady, getting the details nice.
    PXL_20230115_234610146.jpg PXL_20230115_234602965.jpg PXL_20230115_182134416.jpg
    Bcap55, brEad and shortypu like this.
  21. alchemy
    alchemy
    Straighten out the lower shock mounts before you put the torque to the perch nut. That's always a detail that's nice.
    brEad likes this.
  22. SDS
    SDS
    Thanks - I will.
    Nothing is tight yet, I want to set it on the ground first.
  23. brEad
    brEad
    Details are looking nice indeed! Excellent work!
  24. NJ Don
    NJ Don
    Scott,
    I saw in another topic you were looking into an Auburn dash panel. Did you ever decide on one?
    Regards,
    Don
  25. alchemy
    alchemy
    You need one of these.....
    brEad likes this.
  26. NJ Don
    NJ Don
    Nice, but not an Auburn. It might look better with the wings on top?
  27. alchemy
    alchemy
    Sure, you could do it that way. A local builder installed one "upside down" before I told him they are designed to be installed wings down.
  28. SDS
    SDS
    Was able to accomplish the impossible today with some help from 3D printing and 2 heavy guys. ***emble a rear suspension with a 1200 lb. Posies rear spring ON the ch***is (without dis***embling the spring itself).
    We put jack stands under the spring eyes and I sat on one rear frame rail and my buddy sat on the other to compress it enough to get the shackles in.
    I 3D printed these little tapered slave/guides so that the misaligned shackles went in easy without pushing the back side bushing out.
    Worked great without a big deal.
    PXL_20230211_160529823.jpg PXL_20230211_160341602.jpg PXL_20230211_160310485.jpg PXL_20230211_160306028.jpg
    shortypu, brEad, rod1 and 3 others like this.
  29. vtwhead
    vtwhead
    Just curious, how long did the 3D thing take? And could you measure the distance between your rear spring hangars?
  30. SDS
    SDS
    I ended up getting one of these from a fellow HAMBer. I can't remember his name off hand - but if you search through my old posts you'll be able to find it. The quality is excellent and I didn't have to do any modification to the dash besides cut a hole.
