Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. RICH B
    RICH B
    Heard from my friend, that he was able to pick up some of my parts from the paint jailer. Hopefully he can get the rear fenders tonight.
  2. RICH B
    RICH B
    Made some ghetto gizmos to hold the windshield garnish for our '47. I kept missing edges when hanging them vertical; now I can paint them flat, one side then flip them to do the other.
  3. charleyw
    charleyw
    Working on dash area, trying to hide as much as I can and still be practical. Heater in a ******* roadster? blood thinners say yes!
    TA DAD, lake_harley, LAROKE and 2 others like this.
  4. RICH B
    RICH B
    Cut up some ABS sheet for inner quarter panels. Held them with a couple screws until I can figure out the clips. I found that my sabre saw has a dial to limit speed; funny never noticed it in the twenty some years I've had it until today. Slow speed made sawing the ABS a breeze. Guess I should sort out all the parts, hardware, and boxes of misc that I've hoarded in it.
  5. RICH B
    RICH B
    Bought some bumper bolts, stainless caps were pretty dull so I thought I would buff them. Turned out they were so full of scratches and die marks that I had to resort to a 320 belt on the sander, then 400, 600, 1000 wet sanding before buffing. Came out ok. Buffed out the screws for the garnish while I was at it. Yeah, Phillips screws, I know. '47 leans that way, while the '35 is strictly straight slot.
  6. TA DAD
    TA DAD
    from NC
    Spent some time working on a mount for this killer Stahl cable drive tach I bought at a swapmeet Saturday. IMG_0798.JPG IMG_0803.JPG IMG_0802.JPG ay.
  7. Pontmerc
    Pontmerc
    from Finland
    Open a trunk, see huge rust hole.Open a door and look missing floor boards.Take a deep breath and walk away.
    TA DAD, '28phonebooth and hammer-time like this.
  8. WTF really
    WTF really
  9. jimmy six
    jimmy six
    Parked next to a real nice 55 second series Chevrolet pickup. 80A8C877-E4C7-40DE-9ABE-43CCDB949C95.jpeg
  10. TA DAD
    TA DAD
    from NC
    I got the tach mounted , now to switch out the distributor and run the cable. IMG_0808.JPG IMG_0811.JPG
  11. Cooon
    Cooon
    Popped the head off my F100 to see why it’s running average, stuck valve and several not seating properly. Least it’s had some engine work done with 30 over pistons etc
    D4FDD93F-B3F3-48D4-A910-6A0C1F9C68A9.jpeg 85CE0649-3B06-44AE-A2AB-F95155C3D83D.jpeg 523F7E2F-FBF2-4F13-824A-2748276DE798.jpeg
    Lil 32 and j hansen like this.
  12. TA DAD
    TA DAD
    from NC
    Broken valve spring ?
  13. JD69
    JD69
    from Hockinson
    Today I swapped stall positions in garage with my daughter's OT bracket car and put the 40 on the lift so I could have good look and add to my winter "to do" list. 20221214_200611.jpg
  14.  Finished welding up the exhaust, mandrel bent summit 3" aluminized pipes, summit brand 2 chamber mufflers and flowmaster reducers,flowmaster 2 1/2" tailpipes. Hopefully it sounds great.
    mad mikey, TA DAD and j hansen like this.
  15. hd1084
    hd1084
    Painted my ribbed valve covers.
  16. JD69
    JD69
    from Hockinson
  17. ken bogren
    ken bogren
    I patted the Falcon on the roof as I walked by to get to the snowblower ! :)
  18. mad mikey
    mad mikey
    Got the body work done on the old dragster scoop and applied 3 coats of high build primer. Almost ready for paint. WIN_20221216_16_15_06_Pro.jpg WIN_20221216_16_15_28_Pro.jpg
    RICH B, 210superair, Jkmar73 and 4 others like this.
  19. 4speed411
    4speed411
    Triangular four link added to the '34 frame, getting motor and trans mount locations figured out and cut the floor out of the three window body PXL_20221215_222713465.jpg
    RICH B, LAROKE, Lil 32 and 5 others like this.
  20. 4speed411
    4speed411
    Out in the shop early, set the body, ready to start the new floor structure PXL_20221217_143258026.jpg
  21. Zax
    Zax
    Drained and flushed the radiator in my Roadster. It had strait water and I needed to add some antifreeze just to be safe. It's gonna get pretty cold in the south this week.
    mad mikey, RICH B and j hansen like this.
  22. Mike Miller
    Mike Miller
    Worked on the floors.
    mad mikey, LAROKE and j hansen like this.
  23. Jkmar73
    Jkmar73
    from Tulare, CA
    I’ve been working on wiring my model a. Using an American Autowire kit to do it. It hasn’t been too bad, just taking it one circuit at a time. Although, this last Friday, I was able to get the starter circuit completed and spin the motor over.
  24. Pontmerc
    Pontmerc
    from Finland
    Polishing my very rusty cads wheel covers. 16714603370601164854961322456188.jpg
  25. RICH B
    RICH B
    My buddy recovered my fenders and front pan from the painter Saturday and went on to spring John's Rambler from another paint jailhouse. I don't envy him taking off the year+ old masking tape.
  26. RICH B
    RICH B
    Managed to get one fender on and the other hung on by a couple bolts. I have to drill several holes as they were lost when I patched the rust holes in the wheel wells.
    TA DAD, WilliD, Hamtown Al and 5 others like this.
  27. NasT
    NasT
    from MD
    Hammer forming trunk bead on a 30 coupe
    66178E20-4916-4B5C-9B64-862EEB4F0D9D.jpeg 344C369A-568F-4ED8-827F-ADDD63678DB2.jpeg 587A1B72-461D-47A0-B991-E009B4E86B59.jpeg
    -Brent-, TA DAD, simplestone and 12 others like this.
  28. WB69
    WB69
    from Kansas
    Washed and tucked in bed for the winter.
    mad mikey and 210superair like this.
  29. ssffnomad
    ssffnomad
    Worked on getting our 35’ 5W ****oned up, and rolling.
    Soon 4 sale on the H.A.M.B. F6A04F0A-23B1-4C3C-9205-FB9391300416.jpeg A4AB5929-8475-4951-8642-741BB5A6682B.jpeg 402BE2EF-3862-4D62-801F-E439B77721E3.jpeg 74065D18-04FF-401A-9ECE-B613088B1BF4.jpeg
    TA DAD, simplestone, RICH B and 5 others like this.
