Technical Question about radiator for running 331 Cadillac in 1932 Ford
Discussion in 'The Hokey Ass Message Board' started by draggin49, Dec 15, 2022.
  1. draggin49
    draggin49
    I was trying to find out what radiator guys were using who are running 331 cadillacs in their 1932 fords . Are you using the corresponding Cadillac radiator that came with the 331 or does it not work size wise on a 1932 Ford ? I don’t have an old cad radiator to test fit so i figured I’d ask some guys who are running 331’s what they have found success using that works fitment wise. Thanks !
  2. 19Eddy30
    19Eddy30
    from VA
    If you plain to use 32 shell ,
    For stock 32 shell Standard Walker C or Z equivalent ,( z for big cid & ac ) Also Br***Works both $700- 1 K new
    Or Flea bay aluminum $200 one , but not Direct bolt in /fitment like original,
    I have ran the Flea bay on 600 hp plus with no problems
    I prefer copper and br***
    kadillackid likes this.
  3. cretin
    cretin
    My situation was a little bit different because I already had a radiator.
    I had a Walker radiator set up for a flathead. Since it was a good radiator, I had a local radiator shop change the inlets and outlets for me. But, it was a radiator for a '32.
    I would imagine the Cadillac radiator wouldn't fit in a '32 all that well.
    rod1 and draggin49 like this.
  4. draggin49
    draggin49
    That makes sense , I will see if I can have em modify my existing 32 radiator that was for a Flathead and change the outlets to the location needed for the caddy. Thanks !
    da34guy likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Why not cap off one on top & bottom?
    (Br*** freeze pugs)
    I did this to a 32 v8 rad because I change engine combos
  6. draggin49
    draggin49
    Oh ok, that sounds even easier . Just will have to get some different shaped radiator hoses to route to the new location
  7. I’m running a caddy in a 63 ford
    Radiator shop built me a 63 Ford radiator with caddy hose inlets and outlets
  8. MMM1693
    MMM1693
    I am running a 472 Caddy with a Br***works in a 32 shell. Lee put the Cad inlet/outlet on his core size for a 32 grille. Works great.
