big block in a model A
Discussion in 'The Hokey Ass Message Board' started by speed kills, Oct 21, 2007.
  1. mohr hp
    mohr hp
    from Georgia
    This system is generally for race cars. Doesn't work too well at low speeds.
    Greenblade likes this.
  2. harleyddad
    harleyddad
    IMG_0502.jpg BBC with Turbo 400 trans
    4" recessed firewall
    Short Corvette water pump
    Small top Mallory distributor
    working on rear brakes now.
  3. iafraser39
    iafraser39
    from Warmland
    I run a 425 nailhead with a full hood. engine set back 4 inches. P1010002.JPG
  4. JJonesey
    JJonesey
  5. Blues4U
    Blues4U
    from So Cal
  6. fastcar1953
    fastcar1953
    Since it's back up. What's people using for headers on fender less cars or trucks?
    Sprint style or roadster style? lake headers?
  7. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    You build the car around the motor. Best advice I can give.
      268.2 KB
  8. v8flat44
    v8flat44
    I knew a guy back in the 60s with an early Lincoln ohv in a Model A roadster pickup........so why not be just as nutz as he was......454 is ok, but those 348 & 409s look SO COOL.........
  9. swade41
    swade41
    from Buffalo,NY
    It reduces crankcase pressure, creates a vacuum and helps the rings seal better
