Projects Banger Speedster project
Discussion in 'Traditional Hot Rods' started by Brendan1959, Dec 21, 2021.
  1. Brendan1959
    Brendan1959
    I have been following the young fella on "Micro Machines" for a couple of years he has great skills and I go back and re watch some episodes for inspiration. He has just finished his degree and has picked up a job at space X , Elon must be watching him as well, so his speedster is on hold for a while.
    Make it custom looks good as well, I have looked at a couple of his now.
    I find YouTube a great resource as someone has usually done it before, we are lucky to have it.
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Thank you for these, got em saved.
    Stogy, Ziggster and brEad like this.
  3. Brendan1959
    Brendan1959
    EB27E342-00F1-4AD9-B791-B5BBE0C8DA60.jpeg C65A139A-4877-4683-8D3F-763EEF219795.jpeg 30CB0DD5-37BC-4521-B52F-613F8E1B2B6B.jpeg CBCFAE79-04A9-43D8-9E68-7CC509165CFE.jpeg 3CB1EDCD-2A19-455C-824C-DD350DBBF527.jpeg 30CB0DD5-37BC-4521-B52F-613F8E1B2B6B.jpeg CBCFAE79-04A9-43D8-9E68-7CC509165CFE.jpeg 78CFF6B2-EAEB-4C62-ABB7-66DB07F72C75.jpeg E3DE0C1F-F90D-4FAF-8EA0-238B3FA18B62.jpeg A bit more progress
    Made up a fire wall frame, I was going to try bending the square tube, but made up a box instead, much easier, fuel tank turned up as well, hopefully 40 litres will be enough!
    Deutscher, Squablow, Stogy and 7 others like this.
  4. Ziggster
    Ziggster
    I just saw that macromachines vid. It was in my suggested feed for a while but I didn’t bother until a few days ago. Can’t believe it’s been 4 yrs. Sad to see him park his project, but life goes on.
    Stogy likes this.
  5. Brendan1959
    Brendan1959
    Deutscher, Squablow, Stogy and 5 others like this.
  6. Brendan1959
    Brendan1959
    A bit more progress 48C0CED4-E74B-4854-8F35-A5290CA7FB7F.jpeg 2DD9D43B-2BA9-49F4-9EB2-BCEBF87D660B.jpeg 8539352E-F384-4E3D-9548-1E92D062F60F.jpeg 2C91F9A8-3658-4715-A4B7-429B2E6B085A.jpeg
    Deutscher, Squablow, Stogy and 6 others like this.
  7. Brendan1959
    Brendan1959
    not much progress just mocking up the dash
  8. Brendan1959
    Brendan1959
    AB5C6260-8978-4735-BFDF-9A755786E8FE.jpeg How come 10 minut jobs take several hours?
    Outback, Deutscher, jet996 and 5 others like this.
  9. Dave G in Gansevoort
    from Upstate NY
    Well, first you have to figure out what you're going to make. Then decide on the material. Then look thru your stash for something close, so that you don't spend hours cutting it down. Then determine what tools you have that will get the job done mostly.
    Now you're ready to start, but first you have to establish dimensions. Then cut off the material a little bit oversized just because. Start the machining. Realize that you don't have a sharp drill bit. Then decide on getting a new one or sharpening the one you have. Both take time.
    Now you start making progress. Oops, should have cut a little closer to the final dimensions, as it takes extra time to shorten it up.
    Finally, it's done, only 7 more to go. 6...5...4...3...2...final one. Done!
    Let's see, 10 minutes, plus 5 1/2 hours for the setup and all that...
    Yeah, we've all been there! Time well spent
    Outback, Deutscher, Stogy and 3 others like this.
  10. Brendan1959
    Brendan1959
    floors roughly in
    rwrj, Ziggster, Deutscher and 8 others like this.
  11. Dave G in Gansevoort
    from Upstate NY
  12. fur biscuit
    fur biscuit
    Good looking build! The world needs more boat tailed bangers!
    Stogy and marioD like this.
  13. Dan from Oakland
    Dan from Oakland
    Tell us about that bench vise in the earlier pictures- looks kinda special and unique!
    Stogy likes this.
  14. Brendan1959
    Brendan1959
    Ok there is a story to the vice.
    As an apprentice electrician for REPCO an Australian car part manufacturer, now only retail, training was taken seriously so all fitters received 12 months full time training on machine work, and so the sparkies could be multi skilled we got 6 months full time training on machine work. Our final module was turn up a bottle jack which had left hand and right hand, inside and outside multi start square threads.
    Fast forward 10 years I was working at some research laboratories, and we had a great workshop with lathes and mills, our metal work guy and I were talking one day I said I needed a vice for home and was thinking about making one as they are expensive and I could not afford to buy one, he said its not possible and could not be made successfully, challenge accepted!
    Started with turning up a square thread shaft and nut, welded up the rest out of stock steel and machined in br*** sliders and br*** jaws.
    The vice has been on my bench for 30 years and has been abused hundreds of times and is still going strong, it opens wider than most vices and has a little anvil on the back for extra abuse. I could now afford a brand name vice but I still get a smile when I think of the challenge I accepted, It may not be the pretist tool in my shed but it is definetly the most used. upload_2022-12-31_13-24-19.png
    GuyW, rwrj, Deutscher and 12 others like this.
  15. Brendan1959
    Brendan1959
    Not much progress
    Been a bit distracted with this
    GuyW, rwrj, Deutscher and 4 others like this.
  16. Brendan1959
    Brendan1959
    I have made a simple stand for my shrinker!
    Ziggster, Deutscher, CSPIDY and 4 others like this.
  17. Brendan1959
    Brendan1959
    Ziggster, Deutscher, Jeff34 and 5 others like this.
  18. Dave G in Gansevoort
    from Upstate NY
    So is this backup for the rare occasions when the banger won't run? Like the little rowboats pulled behind bigger sailboats?
  19. Brendan1959
    Brendan1959
    Its a 1942 English paratrooper welbike quite rare, and apparently valuable.
    Deutscher, jet996, loudbang and 2 others like this.
  20. Dave G in Gansevoort
    from Upstate NY
    That's neat! But my warped mind immediately jumped to Monty Python, and could picture the group of them split up into opposite sides jousting!
    You need to make dimensional drawings of it for us all to make modern interpretations of the thing. I'm sure that more than a few would build one.
    jet996 likes this.
  21. Brendan1959
    Brendan1959
    Not sure my skills are up to aluminium, 2 but welds many hours and 1/2 a bottle of gas.
    I may be better using sheet steel.
    rwrj and Deutscher like this.
  22. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Almost thinking you need to invest in a spool gun for your mig welder and run co2 shielding gas. I think that would fix your welding issue... You got alot of puddle there that you were chasing for sure.
  23. Brendan1959
    Brendan1959
    Been stalled on this for some time, so I decided to work on the easy bits, cycle guards on and wired.
    PGA STUDIOS, rwrj, Ziggster and 5 others like this.
  24. Brendan1959
    Brendan1959
    Change of plans!!!
    It's now going to be a roadster pickup.
    Went to a swap and bought the rustiest bits and pieces of a pickup, but it was cheap. photo_2026-01-31_15-53-22.jpg photo_2026-01-31_15-53-26.jpg photo_2026-01-31_15-53-32.jpg photo_2026-01-31_15-53-36.jpg photo_2026-01-31_15-53-38.jpg photo_2026-01-31_15-53-41.jpg photo_2026-01-31_15-53-44.jpg photo_2026-01-31_15-53-48.jpg photo_2026-01-31_15-53-50.jpg photo_2026-01-31_15-53-56.jpg
    PGA STUDIOS, Outback, rwrj and 3 others like this.
  25. Ziggster
    Ziggster
    Geeze, forgot about your build. That’s quite the change in direction.
  26. Outback
    Outback
    from NE Vic, Oz
    glad you are still moving forward, there's a fella in Broadford who is selling repo model A beds & can backs. quite reasonably priced
  27. Brendan1959
    Brendan1959
    Thanks
    I have him saved in FB incase I can make them work.
