Customs Source for ribbed exhaust tubing-ribbed lake pipes
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Feb 5, 2020.
  1. Okie Pete
    Okie Pete
    I wonder if the tubing could be capped on one end , then packed full of fine sand then capped. Then put into a lathe and have a aluminum wheel pressing against the tubing to form the rib ? Probably need a support wheel on the backside to keep from bending the exhaust tubing .
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    I found the other thread, look at page 2
    https://www.jalopyjournal.com/forum/threads/kickstand-lake-pipes.417489/
    54delray and Okie Pete like this.
  3. Okie Pete
    Okie Pete
    Or make a dull wheel for a pipe cutter like someone suggested. Mount the pipe cutter on the tool post on a lathe , drop in the tubing . Set the thread pitch on the gear setting , tighten up the cutter and turn on the lathe .
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, I ruined my pipe cutter trying this, It didn't work. I dulled the hell out of it and it still cut the pipe before it would put ribs in it
  5. Okie Pete
    Okie Pete
    Thank You for directing me to the other thread . I think a dull pointed wheel could be made to press onto a roller bearing or a needle bearing . That might form a rounder bend ? Used in a holder like the one You made for the roller bearing .
    Sancho likes this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe, I gave up messing with it when I couldn't repeat what I had done already a second time.. I think Tucks press and die idea has some merit, we are all holding our breath waiting...
    Sancho, 54delray, Just Gary and 3 others like this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I’m just as excited about this as you guys… holding my breath too-!
  8. Blue One
    Blue One
    from Alberta
    I still say hydro forming is the way to go.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    ok I just made a steel sleeve that I pressed on the bearing in my lathe tool. I had a small radiused point on it about .080 larger that the outside diameter, I put a pc of tubing in my lathe and the point wore down and flattened out without doing anything to the pipe. granted the pipe I was trying to rib was stainless and maybe that is why, now I am really done messing with this...
    Sancho and Okie Pete like this.
  10. jaracer
    jaracer
    I might be wrong, but it seems like an exhaust pipe bender is able to make crimps. You might see if that's possible.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    are you saying to put hydraulic oil under pressure inside the pipe and expand the diameter into a female die? man I think something like that may take more pressure than I would care to mess with... that female die would have to be 2 pcs so you could get the pipe out. maybe I don't understand...
    Okie Pete and Roothawg like this.
  12. Blue One
    Blue One
    from Alberta
    yes, that’s exactly what I’m saying.
    Hydro forming is used for making frame rails and lots of things by the auto manufacturers.
    It’s amazing.
  13. These Radiator pipes were done with a dull pipe cutter on Stainless Steel (exhaust Tube)
  14. Just Gary
    Just Gary
    Chris, could this be fabbed with a 3D printer?:confused:
    Maybe in 6" long segments, "welded" together to get the desired length?
    Maybe scan a corrugated radiator hose with correct ID to nail down the dimensions?
    Just a thought while Momma's watching another Hallmark Christmas movie. :rolleyes:
  15. Roothawg
    Roothawg
    Man, I dunno Gary. All those fancy gadgets are out of my wheel house.
    Sancho and Just Gary like this.
  16. Budget36
    Budget36
    I did some googling just now and came up with a site called bare knuckle performance who sells mild steel and SS up to 2 inch diameter. I didn’t dig deep as I’m heading to bed, but the pics of the the pipes they showed were around 100 bucks for 18-24 inches I’d guess and ***ume that was 1-3/4 Mild steel.
    Might be worth looking into.
    Just Gary likes this.
  17. Roothawg
    Roothawg
    Thanks. I'll check it out.
  18. Here
    Traditional Ripple Exhaust Pipe – Bare Knuckle Performance
    Sancho, Okie Pete and Budget36 like this.
  19. Roothawg
    Roothawg
    Yeah, we were discussing it offline. I think it's better than nothing, however, the originals had a more pronounced radius. I know, beggars can't be choosey.
  20. K13
    K13
    I mentioned them back on post #51. I emailed them but haven't heard back on if they actually have some stock.
    Sancho, Budget36 and Tman like this.
  21. Why yes you did! I don't mind the shape of them.
    Sancho and Roothawg like this.
  22. K13
    K13
    They got back to me but didn't say if they had anything. Asked what material and size I was looking for. Probably means they have limited supply. I replied back with mild steel and either 1 3/4" or 2" so we will see what they say.
    Sancho, 54delray and Tman like this.
  23. Roothawg
    Roothawg
    I would like to see one up close and personal.
    Sancho likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    the indents look too wide and flat to me.. Maybe we should wait for @Tuck
    Okie Pete, Sancho and 54delray like this.
  25. I'll see if they display at Sturgis next year. I got time.
    Yup, in no hurry at the moment. I want to see what he comes up with.
  26. Roothawg
    Roothawg
    Yeah, you and me both.....
    Tman and Moriarity like this.
  27. K13
    K13
    They got back to me. They make it themselves. Sounds like they make it to order.
  28. Budget36
    Budget36
    Sorry about that, I remembered reading this thread and was googling and just came to the last page to reply.
  29. K13
    K13
    No worries. I was quoting just to say that I had emailed them so we didn't inundate them with a bunch of people asking the same questions. LOL
    54delray and Budget36 like this.
