Features 1963 409 4 speed impala
Discussion in 'Traditional Hot Rods' started by halfsack, Mar 29, 2020.
  1. enloe
    enloe
    from east , tn.
    Awesome Car
    halfsack likes this.
  2. halfsack
    halfsack
    Well, all, as for another update. Sad to say, the recently rebuilt/repaired 409 didn't last but maybe 300 miles. So extremely disheartening. It has been pulled out of the car, and sent off to the place that built the engine in the racecar. Will probably need at least 1 sleeve, 1 piston, and if the heads aren't repairable, or the cost is too much to justify for stock heads, it will be getting a pair of bob walla aluminum heads. I really wish I knew what was causing this thing to self destruct. I mean I'd understand it if I was beating the snot out of it, but I was cruising on a back road in 4th gear at maybe 1900 to 2000 rpm. So hears hoping that the 3rd and final place can get this damn thing right. I have faith in the builder as he built us one hell of an engine for my racecar. Will try and keep you all updates as I find out.
  3. Damn that*****s, good luck on the next one
  4. halfsack
    halfsack
    Do you still have those covers my friend?
  5. yessir
  6. 427 sleeper
    427 sleeper
    I've heard some people say that 409's are tempermental, but this is ridiculous! What happens when it lets go, and is it the same thing every time?
    Maybe if you paint the engine orange it will stop******** on your leg! :D LOL! (Sorry, just trying to throw a little humor at a*****ty situation ;)) Looking forward to update's. :cool:
    Thor1, halfsack and Tickety Boo like this.
  7. Truckedup
    Truckedup
    409 can be tempermental with tune up like some other hi po engines back then..But driven within it's limits should cause no mehanical failures...unless there's sloppy workmanship...
  8. halfsack
    halfsack
    Keeps breaking exhaust valves. It was supposedly clearance due to the larg roller cam that's in it.
  9. 427 sleeper
    427 sleeper
    Is it breaking them due to lack of clearance or is it dropping them because of other valvetrain issue's?
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    Cruising along at 2000, rpm seems like a retainer must have failed, maybe check if the retainers you have installed are up to the roller spring pressures your running.
    They might crack after a few hard runs then fail :oops:
    Thor1 and 427 sleeper like this.
  11. saltflats
    saltflats
    from Missouri
    That's to bad your having so much trouble.
    These engines aren't that complicated but there are things that need more attention than some other engine platforms do.
    Thor1 and Tickety Boo like this.
  12. v8flat44
    v8flat44
    This Ford guy loves that "W Motor" & the car. You,ll get the valve thing fixed & have one sweet ride.
  13. halfsack
    halfsack
    Retainers are perfectly fine and not cracked. No spring bind either.
    Tickety Boo likes this.
  14. halfsack
    halfsack
    My guess would be lack of clearance. So I may even go to a smaller roller cam just to be safe. It has a crane solid roller in it now with .655 lift. I may just go with an old isky 505c-62 if I can find one. They're about .560 lift
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    On that cylinder did the valve bend or break, what was the condition of the exhaust valve keeper and retainer?
    427 sleeper likes this.
  16. halfsack
    halfsack
    For the longest time we were fighting cylinder #7. This time it was #5. The valve itself broke. The bottom half of the stem and head are gone. And like said prior, both were in good condition and in place as should be. Below is a pic of #5 exhaust. It blew up bad enough that it spit***** out of the exhaust. But some was caught at the bottom of the header dump. 20221210_112802.jpg
  17. halfsack
    halfsack
    I always try and be spot on tune up wise. I haven't even had a chance to even see what it's limits even may be.
  18. saltflats
    saltflats
    from Missouri
    Am I seeing a hardened seat in there, is that a coolant leak at that stain?
    If so, leaking on the exhaust valve stem could have made the valve hang open.
    Tickety Boo and Dick Stevens like this.
  19. halfsack
    halfsack
    That makes sense also due to corrosion on the stem.
  20. Dick Stevens
    Dick Stevens
    Good eye catching that!
  21. halfsack
    halfsack
    So im also****uming that the heads are now junk if they've had hardened seats installed? Which now would also make sense in why I kept getting moisture up in the heads.
  22. When I was playing with 348/409's I was always told to never cut for hardened seats. For this reason.
    427 sleeper and theHIGHLANDER like this.
  23. halfsack
    halfsack
    Great..... lol. I do believe the place it went originally put in hardened seats. It is what it is
    scotty t likes this.
  24. Almostdone
    Almostdone
    Post your info to 348-409.com if you haven’t already (I didn’t go through all the posts to check). Add a question to the Interact, Forum, 349-409 Engines forum. Great knowledge base there.
    John
  25. halfsack
    halfsack
    Welp, without any further words from the engine shop, here are my plans for the 409 for now if the block is savable. One sleeve, one piston, remove the crane .655 lift solid roller and go down to an isky 505c-62 solid roller, and a pair of bob walla heads with my current valvetrain.
  26. sunbeam
    sunbeam
    Another giveaway that it was not an original 409 no factory tach.
  27. halfsack
    halfsack
    Thats where you're wrong. I removed the tach because it did not work. See attached pictures.
  28. banjorear
    banjorear
    That’s your post? WTF, man? OP came here after having issues with two engine builds that are both heartbreaking and frustrating and you want to nit pick whether or not it was an original 409 car? Jesus, man.
    halfsack, SS327, impala4speed and 3 others like this.
  29. sunbeam
    sunbeam
    I applaud you for stating that it was not an original 09 car I was just pointing out things to look for when questioning a car that is supposed the be original I am so tired of I have a original 1961 409 Biscayne adds.
  30. halfsack
    halfsack
    Thank you. The only way to honestly tell if it is a real 409 car is to either have bought it brand new, or to find the build sheet. I do know for a fact that it was not a factory 425hp 409 car due to it being a factory ac/ps/pb optioned car. Now, the 340hp cars could come with those options as the block in the car is a QC code which denotes a 340hp 409. But anyways, enough about that. Thank you to those that are questioning the issues with the last two builds by two different places. I'm praying that the 3rd and final place is the winner of them all as I already have one of their engines in my racecar and it's a screamer.
    SS327 and Thor1 like this.
