Hot Rods Let's see your homemade speed equipment
Discussion in 'The Hokey Ass Message Board' started by Robert J. Palmer, Nov 26, 2014.
  1. Jethro
    Jethro
    I have admired those for some time now.....very nice!
    I remember seeing the original GTO vacuum operated mufflers in a Pontiac parts manual. I became a real pest to the parts man at the GM dealership , trying to get him to find me some 40 years ago......he basically told me to "get lost"
    Boneyard51 likes this.
  2. Boneyard51
    Boneyard51
    Maybe I a little dense, but I don’t understand the flow through this muffler. It appears to me that at high vacuum( part throttle) the exhaust cuts across from the inlet to the out let! Then at low vacuum ( wide open throttle) the exhaust is forced through the small pipe and then has to make several turns, by going into the middle pipe, before exiting through the outlet!
    Maybe I need some help understanding the flow of this obviously well made muffler!
    It appears to me that the valve or plate needs to be on the other side of the par***ion, to function properly. But what do I know? :rolleyes:
    Bones
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Vacuum applied in first pic...? I see a gauge.
  4. Boneyard51
    Boneyard51
    That’s how I see it! To me the valve should be on the other side of the par***ion , that way when you lose vacuum, ( WOT) the spring pulls the valve open, the exhaust can go the normal route and also cut across from inlet to outlet. In my small mind I see no reason to block the flow of the quiet route. That way, you have normal flow and cut across flow!
    Maybe I just don’t understand!
    Bones
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    I'm seeing...if vacuum is applied in the pic, exhaust is p***ed through muffs. When vacuum drops off, valve opens and exhaust is p***ed through the whole system, but also able to take the easy route straight to the outlet.
  6. TRENDZ
    TRENDZ
    Here’s a few things that I’ve made for my early hemi…
    main caps, rocker arms, block adapter… I have a lot more to do.
    Okie Pete, Deuces, saltflats and 7 others like this.
  7. Boneyard51
    Boneyard51
    That’s how I see it. But why make the exhaust turn three times at WOT? At WOT you should want a direct route, not one with three turns. To me you want the three turns at partial throttle, high vacuum!
    The OP has obviously made these before, I am sure I am just not seeing or understanding how this muffler works!
    Bones
  8. VOETOM
    VOETOM
    from MO
  9. 57JoeFoMoPar
    57JoeFoMoPar
    Impressive work
  10. VOETOM
    VOETOM
    from MO
    On muffler drawing, above, inlet is at top left. The valve is closed so all flow is through three p*** tubes and then out the bottom right. When the driver pulls the knob to open the exhaust, the valve pulls to the left closing off the center tube and the outlet tube and so the flow is through the big center port and into the four small 1" diameter ports in the outlet bushing. This is the OEM design; mine uses much better silencing material and much larger byp*** ports, a valve that opens farther, and all stainless materials.
    Even though it is tad newer than HAMB things, this is the real original ad car with my set on it. . .
    Here is the original ad and the original car, same as one in first video.
    SS327, Deuces, Boneyard51 and 2 others like this.
  11. Boneyard51
    Boneyard51
    Okay, where do you get the vacuum to operate the valves at WOT?
    Bones
  12. VOETOM
    VOETOM
    from MO
    The GTO has a HiC fruit juice sized can with a check valve under the driver's side front fender that is evacuated while driving. So, at WOT, it is ready to **** the two 4" actuators open. They work really well.
    SS327, brEad and Boneyard51 like this.
  13. VOETOM
    VOETOM
    from MO
    Joe Display Top copy.jpg Here are many of the parts on a display board.
    Okie Pete, SS327, chrisp and 4 others like this.
  14. Bump for an old thread.
  16. alchemy
    alchemy
    I’ve shown this on other threads but not this one yet. This is our homemade quickchange. Patterned after an ancient Frankland, with some Halibrand thrown in too. First one is done, and plan to make eight more if a certain HAMBer ever sends my pattern for the rear cover back to me.
    burl, neilswheels, fauj and 11 others like this.
  17. DDDenny
    OK, shameless repeat.
    The foot feed for my roadster.
    brEad, Just Gary, Okie Pete and 6 others like this.
  18. I found this drywall lift s****ping and thought it would make a great throttle padel! Six hours of cutting, working at the drill press, the lathe, and T.I.G. welding I think it came out pretty good!
    upload_2024-11-14_14-5-35.png upload_2024-11-14_14-6-3.png upload_2024-11-14_14-6-28.png upload_2024-11-14_14-6-54.png upload_2024-11-14_14-7-22.png upload_2024-11-14_14-7-50.png
    brEad, fauj, Just Gary and 6 others like this.
  19. I finally finished 2 of the 3 with the help of family friend Jeff Heger on the machine work I welded them.
    I need to finish the 3 one and find one more Hurst recap and groove all three, these are for display on my vintage stock car.
    upload_2024-11-14_14-14-4.png upload_2024-11-14_14-14-30.png upload_2024-11-14_14-14-55.png upload_2024-11-14_14-15-21.png upload_2024-11-14_14-15-57.png upload_2024-11-14_14-16-19.png upload_2024-11-14_14-16-56.png upload_2024-11-14_14-17-17.png upload_2024-11-14_14-17-47.png upload_2024-11-14_14-18-11.png upload_2024-11-14_14-18-36.png
    brEad, Just Gary, iagsxr and 7 others like this.
  20. alchemy
    alchemy
    It says Marshalltown on it. That’s where I’m from!
    Robert J. Palmer and tractorguy like this.
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  22. It’s an old Michigan Safety Racing Hub that somewhere along the line someone machined the drum off.
    I figured it would make a good wheel building/tire grooving jig….
    ….and maybe a good right front hub for those tight 1/4 mile tracks, nothing in our rules about having to have brakes on all four corners!;)
    Okie Pete and seb fontana like this.
  23. The swedges and zoomies I built
    upload_2024-11-15_12-26-59.png upload_2024-11-15_12-27-21.png upload_2024-11-15_12-27-43.png upload_2024-11-15_12-28-16.png upload_2024-11-15_12-30-44.png upload_2024-11-15_12-31-6.png upload_2024-11-15_12-28-42.png upload_2024-11-15_12-28-59.png upload_2024-11-15_12-32-19.png upload_2024-11-15_12-32-49.jpeg upload_2024-11-15_12-33-6.jpeg upload_2024-11-15_12-33-51.png
    brEad, Sharpone, iagsxr and 5 others like this.
  24. ROADSTER1927
    ROADSTER1927
    T cold or wet.jpg he intake on my roadster and most of the car LOL Gary
    Sharpone, Okie Pete and High test 63 like this.
  25. atch
    atch
    brEad and Sharpone like this.
  26. The belt sander at work.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Side draft intake for SU style carbs, and air filter box - uses Ford ****** element.
    brEad, Sharpone, Okie Pete and 3 others like this.
  28. -Brent-
    -Brent-
    The driver's side header to clear the steering box in my A.
    brEad, neilswheels, Sharpone and 6 others like this.
  29. patsurf
    patsurf
    what thickness is the flange?-nice!
    Sharpone likes this.
