Technical Cured My Flathead’s Occasional Overheating (The Hard Way)!. Updated 1-30
Discussion in 'The Hokey Ass Message Board' started by hotrodA, May 28, 2022.
Which project?
Poll closed Jun 17, 2022.
  1. 40 coupe: Replace blown flathead with on hand 283 and all the parts. Drive by Aug.
    42 vote(s)
    68.9%
  2. 41 pickup: Get back on Desoto hemi powered pickup and let coupe sit. Drive by ???
    11 vote(s)
    18.0%
  3. Have a pre-estate sale and take up model railroading.
    8 vote(s)
    13.1%
  1. Beanscoot
    Beanscoot
  2. Bandit Billy
    Bandit Billy
    brando1956 and Desoto291Hemi like this.
  3. hotrodA
    hotrodA
    HA! That’s some funny ****.
    Maybe some day over an adult beverage. It moved me up on the dumb*** award list quite a ways.
    That could be mis-construed as a positive.:rolleyes:
    Bandit Billy likes this.
  4. Bandit Billy
    Bandit Billy
    Or possibly a false positive
    Or a true negative. Not sure, made sense earlier. Not do much now. I’ll take you up on that zesty beverage. I promise not to laugh
    …much
  5. hotrodA
    hotrodA
    After all, “It’s only sheet metal”. Plus some Benjamin’s.
    Sounds good! Tipping one with you would be a positive, positive. Providing that you buy.:D
  6. hotrodA
    hotrodA
    Sorry, nothing to report.
    Been sick with Covid(?) or some other alien crud respiratory plague.:mad:
    Put in a couple hours yesterday and it about whipped me.
    Fiddled with the new Borgeson box and CE mount and started cleanup on the SP Delco.
    Baby steps for now. :(
    Bandit Billy and alanp561 like this.
  7. TomT
    TomT
    Just picked up on this thread so I am a bit late. Sorry for your troubles but it sounds like you are getting better and everything is squared away. Get healthy so you can “have at it” once again and have it back on the road ….
  8. hotrodA
    hotrodA
    Thanks, Tom!
    Getting better, just not much energy at 75 and 11/12.
    Did feel good enough to make one good Delco single point out of two donors.
    Glad I saved those NOS Delco points.
    Get that dialed in next week.
    TomT and Desoto291Hemi like this.
  9. hotrodA
    hotrodA
    Wrapped up the rest of the ignition parts on the list, plug wires arrived, and got some gaskets.
    Time for more cleanup, derust and start the paint job on the 283.
    What color? White firewall and inner fenders. Thinking red, like the deceased flattie.
    A memorial of sorts. HA!
  10. hotrodA
    hotrodA
    No, not red.
    Decided on black with off white VC script to match the under hood colors.
    Well, after hours/days of getting the 283 stripped and cleaned, I had today to get it painted before more cold and rain, followed by Christmas.
    It was one of the nastiest engines I've ever had the displeasure of doing!
    Three Chevy orange paint jobs plus one blue job, paint over rust!
    Leaked bad it's entire life apparently, which doesn’t account for the rust, and had caked crud from top to bottom. Original gaskets from the 60's!
    Still have to put color on the bolt on pieces: VC's, WP and timing cover.
    Stay tooned.
    20221215_192351.jpg .
  11. hotrodA
    hotrodA
    Back it up a couple days.
    The pig after several days of labor and a bunch of Scotchbrite discs and wire brushes. #%!@!!&:mad:
    Unfortunately, more to do!
    Had a spare chain set in my parts.
    It BAD needed it. Should really scream now!:D
    Finally!
  12. alchemy
    alchemy
    Not that it matters much now, but your flathead doesn't have sleeves in it. Those little grooves at the top of the cylinder is where the top lip of the original Ford sleeves used to sit. The 40 engine came stock with tin sleeves in it. It was common to remove the tin sleeve, cleanup hone, then install bigger pistons.
    And that crack could probably be pinned, then a regular style sleeve installed in that cylinder. Flathead blocks aren't disposable anymore. Having one sleeve is not a reason to turn it into dishwashers.
  13. hotrodA
    hotrodA
    Thanks, Alchemy!
    Good point about the sleeves. When I get it out and tear it down, I will know more.
    I have several sets of new pistons, including some for a 4” crank I have. Opportunities await.
    I do have two more if this one is history. It’s all about time and energy these days.
    gary macdonald likes this.
  14. jimmy six
    jimmy six
    I really like what you a doing using the 2barrel and all. I see from the rear photo it has the stock PCV system too. It’s nice to double the original horsepower with what Chevrolet used for almost everything from 57 to 67. Cruising down the hyway will probably get 20 mpg too.
    winduptoy and hotrodA like this.
  15. SPEC
    SPEC
    looks great, hopefully I will see you at the Nashville swap meet.
    hotrodA likes this.
  16. TomT
    TomT
    When the sleeves are removed I think the are .083 pistons out there for them or are they for the thicker sleeves?
  17. hotrodA
    hotrodA
    Thanks @jimmy six. Here’s hoping.
    Hey David @SPEC . Undecided on N’ville. May just go to look and buy.
    Last year was too much by myself, and I was stuck to the space all day.
    Thanks @TomT, I’ll check that out.
    Merry Christmas everyone!
  18. joel
    joel
    Just curious; was the cam gear you replaced aluminum with molded plastic gear teeth? I'm glad you're getting the 40 back on the road. I'd suggest finding a different rear end ratio.
  19. hotrodA
    hotrodA
    @joel, nope the gear was iron, but with a good bit of wear and a lot of chain stretch.
    I’ve looked for some time for a replacement center section, and I have another 3:00.
    They’re pretty pricey when they turn up, and if I can ever get to it, probably just buy a new R&P
    and rebuild one of them.
    The most pop that this engine will get is a set of “PowerPak” heads, a C4B and small 4 bbl, and maybe a slight cam improvement.
    Keeping in mind that the trans now is 41 pickup open drive, what ratio would YOU suggest.
    If I go that route, I may get a low enough gear and add a T170 3+1 that I have.
  20. joel
    joel
    By coincidence, I have a T170 3+1 going in my 41 pickup. I have a 3.78 banjo rear and 8.20x15 rear tires. I am ***embling a 59A +.080 engine for it. As you know, the 283 and FH have different operating
    ranges. For example , I put an L79 cam and Carter AFB on my sisters 57 BelAire Power pac and ran it over 75 going back and forth to school with 3.70 rear and 14in. stock size tires. The chart shows running at 3500 rpm or above. To reduce the flathead rpm at that speed, I can run a 29 in. tall rear tire and the .78 od in the T170. those 2 things should keep me between 2700 and 3000 on the highway.
    I think you could run the 3.70 with a non OD trans and larger diameter rear tires, but I also think you would love the 3.70 and T170 combo. The only real downside is the 3.00 first gear ( compared to 2.54 first with a T10 wide ratio 4 speed.) Check my truck thread to see how I managed the T170 mount in a fairly stock frame.
  21. hotrodA
    hotrodA
    @joel
    Good info! Thanks for the suggestions and the link on the trans.
    Bill
  22. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    If u really get serious about the h20 overheating in a Flathead, here is something I will do on a serious build. Take a coat hanger(straighten in2 one long rod) make a true 90 degree bend on one end and sharpen the end of the short 90 to a very sharp dagger or point. Insert the pointed sharpened end in 2 the large holes where the h20 pumps would attach and DRAG the pointed end in2 the silt,dirt, and **** that has ac***ulated in the pan rail. Even after a machine shop SOAK, you will be surprised how much “schmegma” will be pulled out. Keep pulling out stuff until it comes clean and continually flush with water along the way. When u are satisfied it is clean, stand the empty block on its end and push it over with a heavy hand on an old piece of plywood getting more “schmegma” out of the pan rail area.I have had 8-9-10 hot rod fords(always strong flatheads) and have NEVER had a fan of any kind—mechanical or electrical. A mechanical fan takes 5-8 hp away from a not so powerful flathead. I have a very accurate S W water temp gauge and my motors(using stock radiators) will idle at 180-185 for a long time b4 starting to build heat. Get ‘‘em rolling at a few mph and the temp comes right back down. People at the shows always ask”where is your fan”— I tell them I don’t have one and they argue u have to have a fan—I tell them I haven’t run a fan in 60 years and they don’t believe me!! Flatheads Forever!! B0389DB6-5443-4551-93A0-8FEF0067A57C.jpeg 9026C3F9-4E3D-481C-8050-307290719272.jpeg 55F3C3A0-BB4B-4E7D-AAA1-6E63222DFCBA.jpeg 97535160-D28C-402E-A2A7-B5BD6DC9E4FF.jpeg AEC185F7-A668-4E56-A71C-6EB8973AE3F6.jpeg E65B7492-8B51-4686-8AD8-056AB2ACEB19.jpeg C50C988C-4A84-41B6-9DD0-8081D4B239AA.jpeg 087850F0-6916-4325-99C4-F7A6318F2312.jpeg C4B2AB9C-7AAC-42E8-811D-13037B0725FE.jpeg C33C873B-51F7-47D8-9793-55177838B0E1.jpeg
    gary macdonald, TomT and winr like this.
  23. hotrodA
    hotrodA
    Been gone for Christmas, but tested out the alt. mount and belt tension.
    A new 45" OD. belt I had adjusts tight at 50% of the slot.
    We'll see when I put it back on the test stand to check for any leaks and put some revs to it.
    winduptoy likes this.
  24. joel
    joel
    Will that alternator clear the front cross member or front fender brace? I couldn't figure a way to mount it down there. I have it just above the valve cover, but have to swing it out of the way to remove the valve cover and adjust the lifters.
    40FORDPU likes this.
  25. hotrodA
    hotrodA
    @joel
    Hmmm. Good point! I’ll double check, before I go any further. Thanks!
  26. hotrodA
    hotrodA
    @joel
    Back to the drawing board, i.e. a top mount.
    Jitney Jake (if available), VintageAir, Alan Grove
    Thanks for the heads up!:( Better now than after the engine’s in.:mad:
  27. hotrodA
    hotrodA
    Decisions...decisions...decisions
    Painted...
    Edelbrock...
    Cal Custom...
  28. Hillbilly Werewolf
    Hillbilly Werewolf
    I like script best, followed by Cal custom, but which ever way you go, it is going to look great!
    hotrodA likes this.
  29. TomT
    TomT
    This is a short water pump, right.? Looks like the stock swp ps pump setup would fit right in there from the 60s?
  30. hotrodA
    hotrodA
    @TomT. I threw in the towel and ordered a VA upper alt. mount for early SBC. Ran out of patience.
