Technical ***December 2022 Banger Meet Thread - Sit Santa - Long list ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 1, 2022.
  1. callcoy
    callcoy
  2. What did you have to do to mount the engine with that stand? I'm looking to put one on a stand soon
    Outback likes this.
  3. 62pan
    62pan
    Walls, that's the dipper tray. That needs to hold oil for the rods unless you went full pressure. Depending on how long the motor sat water from condensation could cause rust pin holes. Better to find a good one if your not running full pressure to the rods.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    I believe you are looking for the what Winfield called the bell crank ***embly and bell crank shaft. I have not reproduced these as they are not necessary for all applications, and far more complicated to make than they appear. Please note that they are size specific. The center link will be stamped with letter “A” (for A and AA), “B” (for B and BB), etc…
    G Baese and Outback like this.
  5. walls
    walls
    I’ll get some pics tomorrow, but basically the pan side bolts are running at more of an angle than what you would guess.
    You have to compensate for the angle.
    I used some small ground down washers and drilled me holes into the mounting plate.
    Once it’s in front of you, you’ll understand what I mean.
    Easy enough to fab something, just took way longer than what I would have guessed.
  6. walls
    walls
    I think I’ll take your advice.
  7. walls
    walls
    I’m thinking that will be a tough one to find. Need a B size.
  8. fur biscuit
    fur biscuit
    For now, model T. A mildly worked over '16 engine, warford and a few other bits and bobs.
    Outback likes this.
  9. Outback
    Outback
    from NE Vic, Oz
    Nice, make sure you do a build thread!
  10. Outback
    Outback
    from NE Vic, Oz
    Kevin, I gather by your comments that you make repro parts for Winfield carbs?
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    Jet96, ottoman and Outback like this.
  12. Kevin Pharis
    Kevin Pharis
    from Califunny
    Sounds good to me! Keep up in the loop as you go
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Outback likes this.
  14. fur biscuit
    fur biscuit
    Will do, hell, it has so much room potential, even you might fit. Once I get farther along, I'll send Robin some pictures, the Warford came from him.
    Outback likes this.
  15. Star 351
    Star 351
    Here's a few photos of my a and my mums burtz bolted to a standard engine stand its not too hard to do 20220709_165928.jpg 20220711_134025.jpg 20200708_101545.jpg 20200503_183200.jpg 20200412_155137.jpg
    Jet96, Old Dawg, Lil'Alb and 3 others like this.
  16. Merry Christmas everyone
    Last month sent a teaser pic of axle housing in the lathe
    Here is some of the components
    Halibrand 201 QC V8
    35 axle tubes shortened with 56 truck ends and brakes
    Resplined and shortened 56 axles
    Ring gear and carrier modified with 19 spline side gears
    All of this to put under my coop and run std width 57” to get wheels back under the fenders
    I currently have 35 rearend and is too wide
    Added benefit is retained axles and Bendix brakes
    Jet96, burl, Old Dawg and 9 others like this.
  17. Outback
    Outback
    from NE Vic, Oz
    Nice, what are the side gears from? I have a set of f100 9" axles & am just thinking about options...
  18. The side gears are from the 56 truck to match the axles.
    There is a ton of machining to be done to fit them in the carrier.
    J
    Old Dawg likes this.
  19. Outback
    Outback
    from NE Vic, Oz
    Cool. Which center/crusifix did you use? 56?
    Barrelnose pickup likes this.
  20. Merry Christmas everyone! A buddy posted a photo with one of my basic cam covers!
    Hoping to get some new parts made soon! 7B7414E0-F5FF-4172-97B3-498AD2186693.jpeg
  21. Used later V8 to match the carrier ge****t
    The fun starts soon to ***emble
    Just have to make spring mounts
    J
    Old Dawg and Outback like this.
  22. Doug.
    Here's a shot of the "Willie Chambers Special" by Sherm Porter at the Time Trials held at the Santa Margarita Ranch. It has a Fronty T engine. I don't have a time result for the car! FASTSM-2 (2017_06_30 15_13_08 UTC).jpg
    Outback, Jet96, BeaverMatt and 2 others like this.
  23. denis4x4
    denis4x4
    from Colorado
    Is that the same Willie Chambers that worked at EELCO a hundred years ago and makes reproduction rubber for antique motorcycles?
  24. John,
    This is not the car Paul Allen has been working on, is it?
    I spoke with him at the RPM event the following week, I guess it experienced a rapid dis-***embly somewhere.
    John
  25. Dan from Oakland
    Dan from Oakland
    Yes- the same Willie Chambers of Eelco and Antique Cycle fame. Willie made a run of the Morton and Brett bodies by scaling the original patent drawings. The car is currently owned by a friend in Atascadero and has been run at FAST and RPM several years in a row. Back in the day, Willie ran it at the Long Beach Hill climb, so its been around for a few years. DSC00028.JPG The car actually has a B Rajo in it. This picture was taken when Willie was building the car back in 1973 in LA.
  26. fur biscuit
    fur biscuit
    Can't say how much I appreciate this image. Thank you for sharing. Do you have any other period imagery?
    winduptoy likes this.
  27. fur biscuit
    fur biscuit
    Great shot! Guess you didn't run against him?
  28. jim1932
    jim1932
    Is there a Jan 2023 Bangers thread yet?
  29. fur biscuit
    fur biscuit
    Tossed one up.
  30. Jiminy
    Jiminy
    Outback likes this.
