Projects 1950 Mercury Rusturrection
Discussion in 'The Hokey Ass Message Board' started by Aussiepete., Dec 13, 2022.
    Was looking for some 1951 mercury fender skirts and Robin from Koop de Gl*** in New Zealand supplied me with a few sets.
    Robin even delivered them free of charge when he was visiting Brisbane on holidays
    Top bloke.
  2. 1672724738588.jpg Found a front set and will retrim to suit rear seat 1671023365104.jpg
  3. aussie57wag
    aussie57wag
    from australia
    Cool car. No at all reason you couldn't do long interstate runs with a y-block or hemi. They would be equally as dependable.
  4. Cheers mate and agree with you.
    The hemi is earmarked for my hotrod.
    316599358_911311323333686_5988046096602404823_n.jpg 318929418_667689091670699_6687669952618038728_n.jpg
    A good friend Cusso Allan is going to help out with fitting an engine and suspension work
    So taking the car to his workshop with the use of his awesome 1960s f350 ramp truck
  6. aussie57wag
    aussie57wag
    from australia
    Cool. What hot rod will you build?
    Aussiepete. and chryslerfan55 like this.
    Given the front end a good clean and paint .
    Getting ready to fit jamco front suspension kit.
  8. Did you use one of those rust converter chemicals?
    Aussiepete. likes this.
  9. Wire wheel the surface first.
    Yes a rust converter was used Lucius.
    54delray and 51 mercules like this.
    Jamco suspension fitted.
    Went in pretty easy and happy to have disc brakes on the front of the car.
    drdave, Okie Pete, 54delray and 7 others like this.
    It's time to fit the engine and just wanting to give a heads up to anyone fitting a 351 cleveland/windsor. Please ask for the long frame pearches not the short ones Jamco supplied. Three guys in Australia all had the same problem.
    Not sure why this happens but jamco are quick to respond to the situation.
    Okie Pete, 54delray, X38 and 2 others like this.
  12. Hot Rods Ta Hell
    Hot Rods Ta Hell
    I agree with Squablow, we need more Merc build features. Great looking ride, I'll be following along!
  13. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Great progress Pete, enjoying the build tremendously. I'm a Ford in a Ford fan, so good on ya. I'm particularly fond of a 408 Windsor with some finned vintage VCs and and a big '50s air cleaner housing. Best of both worlds.
  14. Cheers mate & thanks .
    I'm Ctravy bout a mercury .
  15. Thankyou I'm glad your enjoying the build.
    That engine of your sounds awesome. I'm looking at modifying a 50s oil bath air cleaner for a better look. Post a pic of your engine if you like
  16. [​IMG]
    Here is a nifty little item you may want to check into. Ford oil filters in stock form can be a problem with the Merc frame. In the 70's Ford made this item as a stock item for the early Vans and some Trucks. It turns the filter 90 degrees and lets it rotate on a wet bolt. I found it to be the cure for lack of space on several builds. We used to be able to get them out of the wrecking yard for $5.oo and $10.oo. Now you can still get them through most aftermarket suppliers like Speedway, Summit and Jeg's. Just thought I'd throw that in your hat for info.
  17. That is perfect for what I'm doing and will look into getting one . Cheers mate
  18. Cheers mate looks great . Thankyou.
    Fits pretty good.
    A f100 4x4 rear sump was used and the engine was pushed back as far as it can go . Cusso Allan will modify the trans tunnel for better clearance as I'm using a c6 transmission.
    Pretty much using 1978 f100 running gear.
    351 + c6 + 9 Inch.
    Thanks for advice everyone
  20. rusty1
    rusty1
    ...sketchin one up,...always liked those Mercs
    Aussiepete., chryslerfan55 and e1956v like this.
  21. 51 mercules
    51 mercules
    Thank you!
    Trans cover has been modified to cover the large c6 transmission. Firewall was trimmed a small amount aswell.
    It's hard to see but the part at the top has been extended forward .
    Front ends back on a beginning to look like a car again .
    Panels all line up way better than before .
    Radiator will have to be moved forward for fan clearance.
  24. CVF 302-SHORTY-ALT-SYSTEM Ford 289-302-351W V-Belt System - Alternator Only, Shorty Water Pump
    I believe this system moves the fan blade back 3" Might be worth looking into,
    chryslerfan55 and Aussiepete. like this.
  25. Great information will look in that system thankyou.
  26. lippy
    lippy
    from Ks
    Man I can't get over how solid that car is! Been following along and thats gonna be a wonderful merc! Lippy
  27. Cheers man appreciate the comments.
    I love the car and it's been pleasure to work on
    Squablow and chryslerfan55 like this.
