Technical Best Glass Packs
Discussion in 'The Hokey Ass Message Board' started by TheSteamDoc, Dec 26, 2022.
  1. TheSteamDoc
    TheSteamDoc
    I'm wanting to run some gl*** packs on a car. What's best ones for sound and longevity. I'm in a humid environment. I'd like some stainless ones. After a good throaty roar with the dreaded droning.
  2. jaracer
    jaracer
    I've got a pair of Porter's that I'm pretty happy with. They have a nice mellow tone, no droning.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Porters, they are steel packs, they do make a stainless version too.
    I have em on my corvette
  4. TheSteamDoc
    TheSteamDoc
    Very nice sounding Vette! Running the short ones or standard length?
  5. ray
    ray
    from colorado
    Porters are perhaps the most beautifully obnoxious muffler there is. i have them on a later motor(rhymes with "hell-yes") and they have a nice smooth steel pack rumble at idle and low cruise, but it's like flipping a switch when you roll into the throttle and make them rap at will, better than any gl***pack. downshift a gear and you will end the cell phone conversation next to you.
    the secret sauce to the Porter sound is the inner core of the muffler is a stainless coil spring that moves with the exhaust pulses.
    alanp561, 38Chevy454 and caseywheels like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    14 inch cores. They make them with stainless steel wool for packing. Back in the old days they were packed with lathe shavings. My pal Clark was making them and I asked him if I could get mine the old fashioned way with shavings. He said if you want that you have to come down here and pack them yourself and you have to bring your own shavings. So, that is what I did, I hand packed 2 sets, one pair is on my 40 and the others are on my Corvette
  7. VOETOM
    VOETOM
    from MO
    Stainless Works makes some good ones.
    Elcohaulic likes this.
  8. blazedogs
    blazedogs
  9. blazedogs
    blazedogs
    This a good question What muffler is the best. Each person has their own idea on what sounds best ,how load they should be , how throaty/ mellow they sound etc. Besides what the owner thinks ,the engine ,the way the exhaust syst is set up etc ,all have a bearing on your question, I am still struggling with this myself My Car is too load ,has a drown when cruising, has a raspy sound and am very dissatisfied My mufflers are the longer ,new dual porters)
    Several suggestion I have received ; try a 2 chamber style muffler. That all straight through will be likely too loud. many of you have mentioned : how the exhaust system itself is designed, will effect the sound and the loudness So I'm still working on a answer to this question How much money has be spent on experimenting to get the perfect loudness and sound Gene in Mn
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    have you tried an H pipe? that will calm it down a bunch
    dwollam likes this.
  11. abe lugo
    abe lugo
    I have porters on the Cadillac.
    https://www.jalopyjournal.com/forum/media/cadillac-500-dual-porters-2.575392/
    Hit the center of the video to play.
    I have smithy on my 57 Hardtop and they still rumble over 20 years old.
    The 57 country Sedan has longer generic gl*** packs. They have a hood rumble but also a common Y-block sound to them.
    I most likely got with porters on all of these when they get replaced.
    alanp561 and Truckdoctor Andy like this.
  12. Bandit Billy
    Bandit Billy
    Someone say Stainless Steel Porters? Here's a pair on my PU. They sound great and polish up real nice!
    WC145, warbird1, ramblin dan and 3 others like this.
  13. I have the long [ 26in?] Smithy's behind my straight eight . About 20,000 miles. Good rap, no droan. Firing order makes a difference in sound.
    Ben
  14. AHotRod
    AHotRod
    I've been using Cherry Bombs for 50 years now, and I like them. I try and make the exhaust system so I can use the longest ones whenever possible and get them as close to the header collector as I can, which in my opinion gives me the sound I'm looking for.
    Adriatic Machine, WC145 and reagen like this.
  15. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Smithy’s and Porter’s
    Bandit Billy and egads like this.
  16. Squablow
    Squablow
    I've always used Cherry Bombs because when I'm not broke, I'm cheap. I like the sound but I'm pretty sure they don't come in stainless.
    I recently scored a set of unused Smithy's from a garage cleanout that I'll be using on the next project but I won't know what they sound like until this summer at the earliest.
    That's hard-core attention to detail, I love it.
    Moriarity likes this.
  17. MMM1693
    MMM1693
    My first choice is the Brockman Mellowtones then the Porters.
    Steves46 likes this.
  18. Dan Hay
    Dan Hay
  19. cederholm
    cederholm
    I LOVED Porters on my twin exhaust Chevy IL6 235. I'll run them on my '53 Ford flatty when the time comes.
  20. I run Walker gl***pacs (branded Thrush - original Thrush weren't gl***pac) on my '63. I think they sound great. They are at the rear of the car with tail spouts out past the bumper. Loud when you step on it hard, but you can cruise it on the highway all day without objectionable sound level and no droning.
    I had some generic straight through steel mufflers on my '50 that I thought sounded too raspy and they were too loud at highway speeds. They are mounted midway under the car with tail pipes past the bumper. I cut them out and put the same Walker gl***pacs I have on the Galaxie. Much improved sound, different than the Galaxie but the cam is stock and well, ... it's a flathead and it sounds like a flathead should sound. Overall I'm pretty happy with the sound of both cars, and the black '63 I'm currently building already has a set of Walker gl***pacs behind a stock 390. It sounds pretty good too. :cool:
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    2.5" Flowmasters with an H pipe here. I don't like the modern gl*** packs with fibergl***, just lacking. The porters and smithys are a good mix and I agree with Moriarty, the H pipe mellows the harshness you can get in higher compression.... Something to think about is pipe diameter makes a difference in how noisy things can get also.
    Here is a walkaround of my chambered mufflers on the 56...
    alanp561 likes this.
  22. Bandit Billy
    Bandit Billy
    Yep, I have Smithy's on my roadster. They sound better now than when new, its like the flathead is in the process of tuning them.
    Max Gearhead and LOST ANGEL like this.
  23. warbird1
    warbird1
    I'd vote for the stainless Porters; put a pair behind the Cad in my '40 and they sound great...
    egads likes this.
  24. Lone Star Mopar
    Lone Star Mopar
    Call Brockman Mellowtones,tell him what youre working with and what sound you want and theyll build em to suit your needs. Good service, good price, great sound.
  25. custom_lettering
    custom_lettering
    from Wall, NJ
    x2 Brockman Mellowtones I called and told them the sound I was looking for and they built the perfect gl***packs for my Merc.
  26. chopolds
    chopolds
    from howell, nj
    I have stainless exhaust systems on my 47 Chevy, and my 56 Olds, but I use Brockman Melowtones on both, even though they are not stainless. They sound THAT good!
  27. theHIGHLANDER
    theHIGHLANDER
    I'm hiding behind a wall saying this so throw all you got. "Gl***pack" mufflers are nearly all the same and yes Porters are engineered different. I installed a set of generic Walkers on my 39 but I can't tell ya what they sound like yet. A hot engine makes a lotta noise, mufflers have less to do with the rap than compression. A few years back I installed a pair of small Magnaflows on an OT rod. Heaven. Sweet and smooth cruising, get the women and children off the street when you smack it. I will indeed put those on my GTO. Rat-a-tat-tat is kool...maybe twice. Well unless you like that sorta thing. ANYTHING is better than the tin can Flowmasters. Hate those ****s now, loved em before. The best? Ever? EVER?? The OG Thrush. Gone now, but nothing ever sounded like those and still doesn't. My opinion is worth exactly whatcha paid for it, and that was even less than my $48 pair of Walkers.
  28. marfen
    marfen
    from sask
    I run stainless Porters on my 32, I got the longer quieter ones they sell and they sound great...and electric cutouts for when I p*** EVs on the hwy.
    WC145 likes this.
  29. BamaMav
    BamaMav
    from Berry, AL
    Last ones I bought were Flo Tech Red Hots. Like theHighlander said, they sounded just like Cherry Bombs or any other gl***pack, but were cheaper to buy.
    My Lincoln has some kind of generic oval chambered mufflers that were on it when I got it. Very short, about 12" or so. They sound decent, not too loud, no drone. Pipes exit under the rear bumper. Thought about going to gl***packs, may still do it later on, but these have offset inlet/outlets, and only others that might work would be the harder to find ones with the angled ends.
  30. Taboo56Chevy
    Taboo56Chevy
    Running Summit special Stainless gl***packs on Taboo. They sound good and you can still hear them over the gear drive.
