Hot Rods Hollywood Spring Company
Discussion in 'The Hokey Ass Message Board' started by krylon32, Dec 29, 2022.
  1. krylon32
    krylon32
    from Nebraska
    Does anyone know if Johnson's Hot Rod Shop has ever gotten the Hollywood Spring Company up and running? I'm having a struggle finding the right springs for my deuce roadster. Thanks
    Carter and chryslerfan55 like this.
  2. sdluck
    sdluck
    What do you need?
  3. low down A
    low down A
    i don't know about hollywood spring, but there is a interesting post going on , can you build a new 32 for 50 grand? you would be the perfect one to answer beings your building a 32
  4. krylon32
    krylon32
    from Nebraska
    Tried working with Eaton Detroit Spring but they wanted a detailed blueprint of the spring, something that is beyond my capabilities.
    Carter likes this.
  5. larry k
    larry k
    Try St. Louis spring ??? In well , St Louis Missouri !!!
    hrm2k likes this.
  6. stuart in mn
    stuart in mn
    Another possible source is Espo: https://www.springsnthings.com/
    For that matter there are many local spring shops around the country, you may be able to find someone local. Many of them deal with heavy trucks, but are also able to build springs for cars.
  7. krylon32
    krylon32
    from Nebraska
    According to their site ESPO does not do leaf springs.
  8. krylon32
    krylon32
    from Nebraska
    Someone just posted a reply about a spring company in California then deleted it. I failed to write the companies name down before the delete. Could you re post it please.
  9. HSF
    HSF
    from Lodi CA
    Dentonis in Stockton California does a lot of springs.
    Budget36 likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. Phillips
    Phillips
  12. Godfrey Brake up here in Rapid City can make springs, or did
  13. kabinenroller
    kabinenroller
    Phillips likes this.
  14. I thought Posies can make custom springs?
  15. krylon32
    krylon32
    from Nebraska
    The Posie spring I am waiting on is a production spring listed in their catalogue. They have had production problems for the last couple years. Again this morning I talked to them and they said they were doing some rework on the springs but still could not give a definitive answer as to when they will be shipping this particular spring. I guess I am to **** about my hot rods but I have always shot for a certain look.
    Kelly Burns likes this.
  16. What about the Suspension Shop in Omaha - he builds tons of stuff for 4wd guys so not sure if he can get what you want. I usually buy mine too. 4402-331-0129
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Stoggie , hope your tag line excludes doctors , their mistakes get buried !
  18. Carter
    Carter
    Does anybody know if any of the spring suppliers mentioned here can do tapered leaves?
  19. krylon32
    krylon32
    from Nebraska
    I have contacted several spring manufacturers and the response I got from all of them is they only do a stock width A rear spring and non of them will do a rolled and tapered end on the spring leaf ends.
  20. alchemy
    alchemy
    Have you called St. Louis Spring? They made a custom front spring for my brother, but it didn’t have rolled ends. For something weird like an A rear, they may want you to send a sample or tracing.
  21. dirt car
    dirt car
    from nebraska
    The Suspension shop wasn't of choice for the early stuff but was very helpful to provide info. for other resources
  22. larry k
    larry k
    St. Louis spring , has been in the same place , doing the same spring work , for over 100 years ,so “yea” they know their **** !!!
  23. krylon32
    krylon32
    from Nebraska
    Contacted St. Louis Spring and they do not offer the product I am looking for.
  24. dirt car
    dirt car
    from nebraska
    krylon32 sent you a pm
  25. krylon32
    krylon32
    from Nebraska
    Yesterday I was contacted by Johnson's Hot Rod Shop/Hollywood Spring Company and they are still in the R&D phase with the spring business. They did have a timeline for production.
    Carter likes this.
  26. abe lugo
    abe lugo
