Hot Rods Who's building a BADASS DRAG INSPIRED HOTROD?
Discussion in 'The Hokey Ass Message Board' started by curbspeed, Nov 24, 2022.
  1. willys36
    willys36
    Did it many years ago.
    1-2018-nsra-western-street-nationals-bakersfield-april-27th-30th-2018-04-01_23-01-14_499110.jpg IMG_1856.JPG IMG_1860.JPG IMG_1865.JPG IMG_1866.JPG
    High test 63, Deuces, slayer and 16 others like this.
  2. rusty rocket
    rusty rocket
    My pops and I are building a 26 T roadster. It’s not really a bad *** race inspired car but the flathead we are using has race history. It’s a 296 cube 59 L that set an ahra record.
    When my pops was a teenager he had a group of older mentors that were in there twenties that had a race team. This motor was in three different race cars a 40 Ford, altered and a front engine dragster. 97524DCB-6266-4313-8B4B-7569F0EB7BFE.jpeg 2565366D-7131-433C-8AB8-1837A3392F7E.jpeg AF460437-52BF-4D88-9C70-D4294D90CBE2.jpeg AA1A9AEE-CEE0-461F-9B22-F237A837CB96.jpeg
    Deuces, slayer, chevy57dude and 15 others like this.
  3. curbspeed
    curbspeed
    shortypu and mad mikey like this.
  4. IronFord
    IronFord
    from NoDak
    I'm building an early sixties drag race/Bonneville inspired 28/29 roadster on 32 rails. I'm running a stroker 427 Ford FE with a Tremec TKO 600 and a 9". Filled and dropped Model A axle, homemade hair pins and batwings plans are for a fully chromed front end. Its only in mock up at the moment.
    rod1, shortypu, mad mikey and 3 others like this.
  5. curbspeed
    curbspeed
    Sounds great! Post pics of your progress when ya get a chance. Let's put some HOT back into hotrodding!
    mad mikey and IronFord like this.
  6. willys36
    willys36
    Lifelong journey of love. Started in '64 as a sophomore in HS, bought the car from grandson of original owner for $75. Vision of the final car never waivered.
  7. -Brent-
    -Brent-
    For me it's the fronts! Luckily, I bought my Halibrands at a fair price - which would be a steal now. I had given up my search for frontrunners for a bit, which was foolish because now they're 2x what was expensive a few years back.
    rod1, Deuces, slayer and 11 others like this.
  8. Barbarian
    Barbarian
    from New Jersey
    yea post a pic! I just picked up an old 28/29 roadster race car body to do the same. When my 34 truck is done , this one’s next. Plan is heavy set back 303 olds
    Just Gary, mad mikey and curbspeed like this.
  9. curbspeed
    curbspeed
    Good for you. Extra points for early Olds power.
    mad mikey likes this.
  10. willys36
    willys36
    Steelies are correct for Fords. Halibrand front runners fit Willys better.
    caseyajones and slayer like this.
  11. curbspeed
    curbspeed
  12. curbspeed
    curbspeed
    Ok. I sold a kidney. Fellow Hamber came through and helped me out. I need to redrill to early Ford but I’ll make a cover plate. Much better match. These are Romeo Palamides in magnesium. I’m stoked. Where does one find magnesium in plate form?
    Deuces, -Brent-, Marty Strode and 8 others like this.
  13. slayer
    slayer
    Wouldn't driling a new bolt pattern into the axles and drums be easier and look better then drilling the wheels and making a cover?
    shortypu, AHotRod, maneri and 7 others like this.
  14. DDDenny
    Wheels with multiple bolt patterns were as a common as a greasy track burger!
    I don't have a problem with them either.
  15. bowie
    bowie
    Nice pair!,They are only single drills once…
  16. curbspeed
    curbspeed
    I know. I have been contemplating the axle redrill too. My fronts are 5x5.5 and I was concerned about the large size difference visually. I'm all about aesthetics. I have time to figure it out. These are 5 on 4.75 Maybe it won't matter. Just happy that I was able to make a good trade to get them. I'm still planning on using a rear axle cover plate. I did find magnesium plate on Ebay. It seems it is all in metric sizes.
  17. curbspeed
    curbspeed
    Will I need tubes for these rims? My new Towel City slicks are radial casings. I would think it wouldn't be necessary.
  18. bowie
    bowie
    The old Ford pattern front and Chevy pattern rear gig has been done a lot over the years. I have gotten used to that look personally. Just sayn’ , it probably cuts the value of those Pal’s by about 50%; as a heck of a lot of them have been double drilled.
  19. bowie
    bowie
    I would put tubes in them, mainly due to how the fill hole was cast in them: F9746213-4EC2-4CF4-8184-A1238F0637C4.jpeg 022F74BF-4818-4776-8632-A364E7FB7A85.jpeg 2E40D565-BCC0-4A49-8302-5B4AA6539715.jpeg
  20. -Brent-
    -Brent-
    I'll take my chances.
    Deuces, mad mikey, EVL401 and 8 others like this.
  21. curbspeed
    curbspeed
    Ya, I agree. I was looking at that. I am going to redrill my axles instead of the rims. Still going to make cover plates for them as well. Now to find the correct tube to get valve stem in the correct position. Thanks
    mad mikey and bowie like this.
  22. telecaster_6
    telecaster_6
    Nitrous 351w/c4 w/brake 4.56 posi. Currently being run on the west coast running mid 10's consistently 2018-06-03 151337-1784603.jpg IMG_1190.jpg 2018-06-03 151803-1183141.jpg 2018-06-03 151749-1559514.jpg 4.png 3.png .
  23. telecaster_6
    telecaster_6
    Jimmy Huff built 351c, .720 lift roller, 11:1, H-beams/ross pistons, 650 dp's, tko500, magnesium winters champ q/c with 4.56 locker.
    31 coupe body, roadster quarters, chopped 5", header panel raised 2", 1.25" tubular inner skeleton
  24. DDDenny
    shortypu likes this.
  25. shortypu
    shortypu
    Curbspeed I agree with what your saying about 5.5 front wheels looking a little wide.I traded for some really nice wheels and tires that has a 15x5.5 front wheels and i think they look a little wide.I might try a skinner tire but for now i will keep the 15 x4s.Nice score on your wheels and you still got another kidney. IMG_2192.JPG IMG_2204.JPG
    Deuces, mad mikey, enloe and 4 others like this.
  26. shortypu
    shortypu
    Telecaster_6 that is just a bad *** coupe with a bad *** Ford motor.Great detail on both your cars.Your sedan is pretty cool too.
    mad mikey and telecaster_6 like this.
  27. curbspeed
    curbspeed
    My front rims are 15x4.5 I was talking about the difference visually in bolt pattern circles. Those last two pictures of rides are fantastic.
    mad mikey and shortypu like this.
  28. EVL401
    EVL401
    Hi all!
    Slowly built this roller up from bits I’ve collected over the years with most parts being sourced from USA & shipped to Oz. Hopefully it’s the start of my dream 60’s style drag roadster!!
    I’ve got a 31 model A cowl & 29 Nash roadster back I’m intending on mating together when time permits.
    Love the thread!! keep it going ⚡️
    Deuces, slayer, mad mikey and 8 others like this.
  29. Partypants
    Partypants
    B7FB3728-B639-491E-B9E0-DB865552FCE2.jpeg 91DF3DB4-5C9A-4B8E-8E7F-F61941B0BD44.jpeg A77741BC-06B6-46F2-81E6-3496F094BAAF.jpeg Love EVL401 (uncleshauno ?)’s gem. Also from OZ is my previously stalled bad***. Fenders and trunklid making way for “race weight” replacements floors and firewall nearing completion as is steering...
    IronFord, Deuces, EVL401 and 13 others like this.
  30. 20230122_111020.jpg As always, another drag inspired hot rod, although I'm not actually going to race this one.... 20221015_124430.jpg 20220830_112521.jpg
    High test 63, Deuces, slayer and 13 others like this.
