Art & Inspiration Engines: Lying in Wait
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Dec 30, 2022.
  1. Dedsoto
    Dedsoto
    from Australia
    Red Ram's Loaded, Firedome is empty. Waiting for the banger in my roadster to quit
    aussie57wag, rpm56, Deuces and 21 others like this.
  2. bchctybob
    bchctybob
    A straight 8, a Caddy flathead and some baby hemis.... excellent!
    aussie57wag and Jet96 like this.
  3. fastcar1953
    fastcar1953
    A lot of hoarders on here. :D
  4. lake_harley
    lake_harley
    I have a dis***embled 241 Dodge Hemi. The block is under the workbench on a storage stand, heads are on a shelf and other parts are in boxes on other shelves. Block has been cleaned, measured and crack checked. Now it waits.
    I bought it about 1 1/2 or 2 years ago from a hoarder friend just because I never owned a Hemi. I guess I'm the hoarder now? Picked up an Offy 4 barrel intake for it last year(?) at the Pate swap meet. Had planned to build the engine for another T roadster but have myself sidetracked from that idea right now. I've also considered taking the 2.5L Iron Duke out of my Model A coupe and swapping in the 241 Hemi, but don't know if I want to tear the coupe apart that much again since it took longer than expected to get it put together the first time.
    A guy does have to have some inventory for inspiration and dreaming.....right?
    Lynn
  5. RDR
    RDR
  6. bchctybob
    bchctybob
    Holy moly.... That's a heap o hemis!
    Lynn, everything in my shop, including the cars is for dreaming. I enjoy just being out there surrounded by old hot rod stuff and if I'm accomplishing something, even better!
    rod1, enloe, Dedsoto and 3 others like this.
  7. oliver westlund
    oliver westlund
    Where to begin...cpl hemis, few 21 stud flattys 59 ab, 8ba and 3 292 y blocks...oh and a 4 banger 20221206_100943.jpg 20221206_100952.jpg
    Then theres my 1950 303 thats gonna go in my 33 dodge... 20211126_175933.jpg
  8. bchctybob
    bchctybob
    So that’s where all of the Y blocks are hiding…..
  9. bchctybob
    bchctybob
    Not under the bench, but under cover. A 0.030 over ‘67 Pontiac 400, 11.5:1 TRWs, big Crower solid lifter cam. It’s supposed to go into my ’62 Tempest, along with a 4 spd and the Corvette rear end in the background, if I ever get to it.
  10. Micael Lundh 1961
    Micael Lundh 1961
    Nailhead 401 with a couple of hundred miles when it was lifted out of a -65 Riviera just waiting (10 years) to get in to the Deuce Tudor. More engines to come……. D6247073-F494-4D2E-8F18-14567DD4A4B0.jpeg 48AF1180-C473-4846-8957-DCB2F03744CF.jpeg
    aussie57wag, rod1, rpm56 and 15 others like this.
  11. tombstone
    tombstone
    from sk.canada
    04DA975F-34D5-48E9-93C2-EE0DA32EB87F.jpeg How about a Pontiac OHC 6 .....
    SS327, Deuces, aussie57wag and 16 others like this.
  12. saltflats
    saltflats
    from Missouri
    1965 409 truck block with fresh .010 bore.
    20221231_085013.jpg 350 .030 bore 14.5 to1 bowtie for digger.
    1958Dodge 354 and a 400 SBC with fresh .030 bore a nd splayed 4 bolt mains. 20221231_084920.jpg
    SS327, rod1, Deuces and 21 others like this.
  13. PhilA
    PhilA
    318, waiting for the other one to go bang.
    Deuces, lemondana, Rickybop and 3 others like this.
  14. 4 pedals
    4 pedals
    from Nor Cal
    I've been trying to cut down on stuff I don't actually have an intended use for...Had quite a few engines, down to just a few now...
    Bare 427/454 block, have all the pieces to put it together but nothing to go into
    Standard 283 w/ steel crank
    532 BBC 800 horse race engine...was going to go in my Henry J but sold that...
    Devin
    alanp561, UNSHINED 2 and bchctybob like this.
  15. dana barlow
    dana barlow
    from Miami Fla.
  16. theHIGHLANDER
    theHIGHLANDER
    2 364 nailheads, 1 with a dynaflow still on it. Also a 350 .010 good running long block. Got a 700R4 in a corner too, a complete rebuild with 2000 miles on it before the engine blew. Sorry, no pics. Gotta trust me...:D
  17. 1946caddy
    1946caddy
    from washington
    sbc's not shown.
    Deuces, CSPIDY, osage orange and 8 others like this.
  18. SS327
    SS327
    2, 250 hp 327s and 2, 455 olds 1, 425 olds and a 429 Cadillac. And a couple of 4 bolt 350s.
    Deuces, alanp561 and bchctybob like this.
  19. swade41
    swade41
    from Buffalo,NY
    I used to have several 454's and 350's laying in wait for some day but cleaned house and let someone else that actually needed them use them. One of the well built 355's I just gave away to my friend that needed an engine for his model A build, which was much better than it sitting in my dusty corner.
    Anyways after the clean out, in this corner we have a 489, 383, 454 and a 355
    The only other I have not sitting in a vehicle is a nicely built couple thousand mile 11-1 355, that unfortunately had been sitting uncovered in a dry garage, so it'll need dis***embled and cleaned before use. This engine is a perfect example of karma though, a friend gave me this after he heard I was going to pull the hot 355 out of the t-bucket to put into the 57 pickup, just like when I gave the 355 to the other friend for his model A
    Deuces, CSPIDY, enloe and 12 others like this.
  20. Russ B
    Russ B
    11 years Old photo, ‘57 392, and a ‘63 327 small journal, both are dual quad, and still not in use. Now I have a new four cylinder Burtz block Model A motor in progress as well. It may be the first to get back on the road. The table has a 45A body on it now, and the cabriolet body that was on it is now a finished car.
    Deuces, CSPIDY, INVISIBLEKID and 6 others like this.
  21. 1biggun
    1biggun
  22. 1biggun
    1biggun
  23. Pontmerc
    Pontmerc
    from Finland
    Lets see....305sbc, 455olds, two 460 fords, a 390fe and about some between 10-20 oldsmobile 350 diesels.
    Deuces and alanp561 like this.
  24. bchctybob
    bchctybob
    A Pontiac 6 cammer, if I had one of those, I'd hold onto it too!
    Haven't seen a 351 Cleveland in a while. I knew Swade41 had a cool stash from the background of other pictures he's posted on other threads. Thanks for sharing.
    Anthony, I thought I had a mess.... Did you know you have a hemi hiding under there? Lol.
    SS327 and swade41 like this.
  25. bchctybob
    bchctybob
    Nice Buick. I see an old Olds lying there also.
  26. Budget36
    Budget36
    I sure enjoy coming to this thread, good idea Bob!
    427 sleeper and bchctybob like this.
  27. blue 49
    blue 49
    from Iowa
    Just an old 283 I hope to save some day. I'd put it in my '36 Ford pickup but there's nothing wrong with the 305 in it now and I doubt any one would notice the difference anyway.
    Gary
    Deuces, alanp561, Rickybop and 4 others like this.
  28. tubman
    tubman
    aussie57wag, Deuces, 40FORDPU and 3 others like this.
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    A Ford 243 six pulled from my son's '48 Anglia. I added a home made tri power and now it's ready to go into my '49 Anglia project.
    aussie57wag, Deuces, CSPIDY and 13 others like this.
