Projects 1930 roadster-esque pick up
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Oct 10, 2019.
  1. Mart
    Mart
    I can't keep track!
    Looks good.
    Reminds me of when I pieced Old Rusty together.
    Mart.
    cactus1 and loudbang like this.
  2. sloppy jalopies
    sloppy jalopies
    Joe dropped off the A frame, heavy dents behind the xmember, both horns tweeked, couple cracks but will be good to put under the truck,
    with the A frame I won't need to cut up the underside of the '31 wide bed...
  3. loudbang
    Are those frames mating? :rolleyes:
    kidcampbell71 likes this.
  4. sloppy jalopies
    sloppy jalopies
    I hope not... a half chevette, half escort … repulsive ! … Although the Ford "is" on top !
  5. Atwater Mike
    Atwater Mike
    Love those '27-'32 Chevy frames! Little bobbed off the rear, 'A' front cross member...Chevy center cross member can be slid forward or back, and used.
    I traded a 3.0 ratio '63 Ford 9" 'pig' straight across for 2 Chevy frames, a '28 and a '31. Used one under my '27 tub. Nice side rails...nice kickup.
    kidcampbell71 and loudbang like this.
  6. sloppy jalopies
    sloppy jalopies
    Agreed... but I would have to separate them and only use the rails... seems a little to wide...
    they have about 9" to much wheelbase to run a stock hood, I could slide the rear axle forward about 5" but still it is a little long...
    I have a pair of '30 one ton rails 5' long, and a narrowed '41 frame cut off 75" forward of the center of the rear axle, they are about the same hight 5" and change...
    the only problem I see so far is that the frame kick up over the rear end is long, starts at the doors...
    12" more kick forward of the rearend than the GM. and about 3" more hight … ? ? ?
  7. sloppy jalopies
    sloppy jalopies
    I decided to cut off a pair of A rear wishbones at the union with the cast ends... about 26" long...
    by cutting along the top and bottom a couple inched and bending the sides out 90* I will make a top and 2 side flanges …
    they will bolt /tack weld to the top and rear edge of the A rear crossmember...
    I will mount them inboard of the subrails, and run a cross piece between them, they will help support the rear 2/3 of the model A bed so I won't have to bolt it down just to hold it there...
    just need a little more "roundtoit"...
    loudbang and brEad like this.
  8. sloppy jalopies
    sloppy jalopies
    Cut, fit, welded the trimmed wishbones to the rear crossmember to support the A bed...
    fabbed up a wishbone mount so I can roll it around...
  9. sloppy jalopies
    sloppy jalopies
    Welded up some scraps to make legs with skids on them so the new owner can move it around...
    now I need to have the roadster-esque pick up sheet metal hop up onto the frame...
    If they are not sequestered, $5 each gets the boys down the street to give me a hand...
    the odd angles are so one could use a nut welded into a pipe, welded horizontally to the union of the legs and have them under the crossmember, then you could bolt plywood wheels to them..
    to roll it around the shop...
  10. sloppy jalopies
    sloppy jalopies
    Only cost me $10 but the pick up is on the frame...
    add a grill, lites and a hoodtop and she is for sale...
    . DSCN6100.JPG DSCN6101.JPG DSCN6103.JPG DSCN6107.JPG DSCN6108.JPG DSCN6109.JPG
  11. OFT
    OFT
    If I was miles and miles closer (currently in Idaho), I'd be interested!!
    sloppy jalopies and loudbang like this.
  12. sloppy jalopies
    sloppy jalopies
  13. sloppy jalopies
    sloppy jalopies
    yea... if I were any further east I would get my feet wet... thanks for liking it...
  14. sloppy jalopies
    sloppy jalopies
  15. Mart
    Mart
    Looking good.
  16. A Boner
    A Boner
    Looking great! Fantastic job of slicing & dicing.
    As she sits, what is the asking price, if I may ask.
  17. sloppy jalopies
    sloppy jalopies
    asking $2500 American … got a few throw ins...
    biggeorge likes this.
  18. sloppy jalopies
    sloppy jalopies
    got a ford car rearend for it last night... 51.5" backing plate to backing plate...
    going to cut the skids /legs down to weld the rearend to them...
  19. sloppy jalopies
    sloppy jalopies
    hamber wants info ...
    ccain likes this.
  20. :cool::cool::cool:
