Projects S.E.G.A. Olds build
Discussion in 'Traditional Hot Rods' started by Saturn V, Oct 11, 2021.
  1. Saturn V
    Saturn V
    from Killen AL
    I do agree, I found that back angle helped the most on a ported Olds cast iron head. Chevy, Ford, and Mopar it hurt. All I could figure it liked the valve angle on the Olds.
    AHotRod likes this.
  2. Saturn V
    Saturn V
    from Killen AL
    I got to work on my engine this weekend. Was able to get the line bore and hone finished. IMG_20220813_093303536.jpg IMG_20220813_103636311.jpg
  3. Saturn V
    Saturn V
    from Killen AL
  4. 425 was ‘65-‘67 same as the original 400.
  5. Saturn V
    Saturn V
    from Killen AL
  6. Saturn V
    Saturn V
    from Killen AL
    Been trying to get a pay job done to help pay for the 56 cosmetic transformation
    Just Gary, brEad and bobss396 like this.
  7. LTM75110
    LTM75110
    Looking forward to seeing this car in action. S.E.G.A. is some of the best drag racing on earth . I met you guys at the Cracker barrel in Birmingham earlier this year. This was my second time to attend the g***er drags and can't wait to go again next year. Good luck with this project...
  8. That’s an interesting way of doing a girdle with the welded pan rail supports. Is that something you did or somebody else’s work. Haven’t seen welded before, always one piece or bolt together in the past. That also looks like maybe a 455, boat motor?
    chryslerfan55 and Saturn V like this.
  9. AmishMike
    AmishMike
    ^^^ like silverjimmy says, curious to see oil pan welded up so no leaks at the step join over brace. ****ers always want to leak anyway
    Saturn V and mad mikey like this.
  10. Saturn V
    Saturn V
    from Killen AL
    This engine is going in a 55 Olds g***er out of Texas.
    The girdle set up is one of **** Miller's parts. It's not too bad a looking part. I'm curious to see how it works out!
    chryslerfan55, bobss396 and AHotRod like this.
  11. OahuEli
    OahuEli
    from Hawaii
  12. Saturn V
    Saturn V
    from Killen AL
    It's been a while since I've posted. Plugging away at the paying jobs. Finally have the 455 finished. Heading to the dyno in 3 weeks. IMG_20221223_150904154.jpg
  13. Captain Chaos
    Captain Chaos
    from Missery
    Hell yea, keep those rockets flying. I started this one and havent touched it in a year, plan to get back to it in Feb.
  14. 6sally6
    6sally6
    Got any theories WHY back cutting valves on Ford stuff it hurts?....
    You certainly would know more than me.
    6sally6
  15. Saturn V
    Saturn V
    from Killen AL
    The angle that I use on the Olds hurt the flow on a set of Ford heads I did yrs ago. Best I can remember I changed the back angle to something a little steeper and they picked back up.
    Sorry for not making myself clearer.
    I know there's a lot of variables to make a head flow. Port design, runner CC's, air velocity. Valve shape and angles. Even the seat angles. That's the reason they make so many different shaped cutters.
  16. mongo4u2
    mongo4u2
    from sparta
    Is that your front end mold for the olds ? How long did it take to make ? Dave
  17. 427 sleeper
    427 sleeper
    No Sir... Not Me.
  18. Saturn V
    Saturn V
    from Killen AL
    The mold that has already made is for a 55. The one for the 56 will be started this month. I've got no clue on how long the process takes. I do know they are having to get the metal cap worked out before the mold can be started.
    seb fontana and 427 sleeper like this.
  19. 55Belairretrorod
    55Belairretrorod
    from Australia
