Projects 1938 chevy gasser
Discussion in 'Traditional Hot Rods' started by Oldskooloval, Jan 3, 2023.
Tags:
  1. Oldskooloval
    Oldskooloval
    This is the beginning photos of my 38 chevy coupe g***er build, have had this car many years in storage. This build will not be a street car, this will be for race only. 305CE9A5-930F-4FE5-9716-24A8C828B592.jpeg
  2. Rickybop
    Rickybop
    '38 Chevy G***er Coupe.
    One of my all-time favorites.
    Have fun good luck keep us posted.
    roddering, 427 sleeper and Stogy like this.
  3. 57Fury440
    57Fury440
    The first 38 Chevy I saw in person was at Islip speedway in 1964. It was running in a gas cl*** and had an injected small block Chevy in it. It should be cool when you're done.
    Stogy likes this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Drop axle and blocks? Any plans to go straight axle instead? FD2F38D9-F976-4902-953F-97F7B507D906.png
    Stogy and X38 like this.
  5. Oldskooloval
    Oldskooloval
    Used a mock-up engine and a speedway front engine mount B9988F20-8EFB-45BF-95A6-7696867F42AB.png to locate the mounting points on the frame
  6. Oldskooloval
    Oldskooloval
    Those were from the original car, will be going with a straight thick .375 axle
    Stogy likes this.
  7. guthriesmith
    guthriesmith
    I have a buddy with a 42 Chevy g***er and Sid Drapal “un-dropped” an axle like that for it. It worked out well.
    Looks like a cool project! I love 37 and 38 Chevy coupes as g***ers. :cool:
    Stogy likes this.
  8. Oldskooloval
    Oldskooloval
    Going with a 9 inch rear,old style tube brace, 35 spline strange axles and center section. Built the housing from a old Edsel rear center and some new 3 inch axle tubing. 8EE87F06-F5AB-4B84-8484-C567A9798C81.png 535FCF4F-BE87-420B-9373-F34997E3492F.png 49AAAEE6-72DD-4823-A86B-E5E163146D21.png
  9. Oldskooloval
    Oldskooloval
    26E9482B-B838-4F1B-AA8F-33D2D035B5E4.png 21B10A36-C1C4-462A-A377-AB39A9617286.png Center section with a 35 spline spool and strange axles
    saltflats, pila38, swade41 and 3 others like this.
  10. Oldskooloval
    Oldskooloval
    Bought some new Afco leafs in the stock length and mocked up the rear
    saltflats, pila38, SS327 and 3 others like this.
  11. Oldskooloval
    Oldskooloval
    Started making the ladder bars
    saltflats, pila38, swade41 and 2 others like this.
  12. Oldskooloval
    Oldskooloval
    Cut and threaded all the ladder bar ends and tig welded them into the bar ends
  13. Oldskooloval
    Oldskooloval
    Ladder bars fully welded
  14. Oldskooloval
    Oldskooloval
    Started out by bending the ladder bar crossmember and making the front ladder bar attachment plates, housing floaters will go on after the the bars are attached
    saltflats, pila38, roddering and 5 others like this.
  15. Oldskooloval
    Oldskooloval
    Frame supports and rear transmission crossmember tacked into place. The frame will be put on a frame jig for final welding
    saltflats, pila38, swade41 and 4 others like this.
  16. Oldskooloval
    Oldskooloval
    Will be posting my progress photos from about 6 months ago to current, then plan on doing the photos as I go
  17. Oldskooloval
    Oldskooloval
    I can’t wait!
    Stogy and SilverJimmy like this.
  18. Oldskooloval
    Oldskooloval
    Thank you!
    Stogy likes this.
  19. You going to run the Richmond? 3 pedals rule!
  20. wheelguy
    wheelguy
  21. Marty Strode
    Marty Strode
  22. Dan Hay
    Dan Hay
    4F045D93-E68D-4C6C-9D6D-7D385F4CB224.jpeg 13DB4AEF-95DF-4567-AFA7-D4EFC1D31193.jpeg Subscribed! I built a 38 G***er model a while back. Here’s some inspiration
    vtx1800, saltflats, pila38 and 16 others like this.
  23. Oldskooloval
    Oldskooloval
    3 pedals all the way!
    saltflats, pila38, SS327 and 4 others like this.
  24. Oldskooloval
    Oldskooloval
    Dan Hay, guthriesmith and Stogy like this.
  25. Oldskooloval
    Oldskooloval
  26. Oldskooloval
    Oldskooloval
    SS327, guthriesmith and Stogy like this.
  27. Stogy
    Stogy
    Bring it on Oldskool...the late thirties Chevys are naturals for this role...looking forward to the journey...
  28. Love where this is headed. Following !
  29. rusty1
    rusty1
    ...love this thread; my old 37...
  30. Jalopy Joker
    Jalopy Joker
    not equal to any of the race g***ers but, in High School days there was a wicked 38 coupe that cruised the main weekend cruise nite. Jacked to the sky, headers, etc. had a big closed end round rear bumper. easily pulled the front wheels off the pavement. really " *****in' "
    Manostihl83 and Stogy like this.
