I'm hoping someone on here knows someone parting out a Lincoln 317 engine. I need the oil tube from the pan to the pump. Also, is this part engine size specific or can I look for other sourced?
https://www.facebook.com/groups/339532373332259/?ref=share&mibextid=NSMWBT There is a guy in California parting out a 317. About 3 or 4 posts down.
I believe you showed both ends and a twisted up pipe on another site. I would put the pan and pump on and make what you need. Get the correct diameter steel tubing and perhaps some factory made close 90 or 180 degree bends and weld one up to fit. The oil pump end slides to fit on a rubber wide o-ring that looks to be the same as the Ford. Maybe with some work and a vice you could get the bent up part to work again. Save the ends and weld in a piece of tubing in the middle. It’s suction line and unless your planning on winning best of show at Pebble Beach it doesn’t matter.
