Technical ***January 2023 Banger Meet Thread Another trip around the sun***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 2, 2023.
  1. Jiminy
    Jiminy
    Link to previous month: December 2022 Banger Meet Thread
    Coming Events: (PM Jiminy with additions/corrections)
    December 25th - Little Saint Nick visits
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    Adriatic Machine likes this.
  2. noboD
    noboD
    Time to sober up and get to work.
  3. 62pan
    62pan
    Another new year already.
  4. Another Monday.
  5. Checking in
    Thanks Jiminy
    So finished up coop rear
    Now need the time to install
    Jet96, Old Dawg, Stovebolt and 4 others like this.
  6. Crazydaddyo
    Crazydaddyo
    John,
    Is that a ring gear "snubber" on the axle housing? Does that center section not have a pinion shaft support bearing?.
    The ***embly looks great.
  7. Crazydaddyo
    Crazydaddyo
    Slow progress.
  8. Hey Dan,
    This is a 201 Halibrand (V8) with the straddle mount bearing and yes that is a snubber.
    Since these are '35 housings with the smaller bearing the snubber will take some of the load if I get too frisky with it.
    Can't wait to get it in and finish the new motor.
    Happy New Year All, J
    Jet96, Old Dawg, Crazydaddyo and 3 others like this.
  9. denis4x4
    denis4x4
    from Colorado
    Checking in
    winduptoy likes this.
  10. trikejunkie
    trikejunkie
    from Scotland
    Checking in .........made new head studs and nuts this week for my Thomas head on the B engine -anyone give advice on going "V 8 water pump conversion"? cheers
  11. winduptoy
    winduptoy
    Dan,
    Looking good...
    I'm back into mine after about 2700 miles (serial #140) the rear main started leaking. I had used a 'Detroit Diesel' silicone seal, not removing the lip spring like the ***embly guide recommends... bad idea in my mind.
    The seal was leaking at the bottom of the main cap, between the seal and the cap surface. On close inspection you could see where the cutting tool had made an ever so slight impression in the finish cut...I missed it on the initial ***embly. It was at 6:00, right at the 'bottom' of the cap. I also did not use any sealant on the seal as I ***embled it, as it has the factory coating to do that. I have re-installed a new seal and placed Loc***e 5699 sealant on the backside of the seal, and drove it all the way into the back of the bore to form a seal against those surfaces.
    I had torn down the engine entirely and the only thing that I noticed was that the main bearing shells were showing copper from wear thru at the tabs....I had critically looked at these on initial ***embly and had cleaned them up...but I guess, not aggressively enough. The remainder of the bearing surfaces looked good enough I reused them as is.
    You may or may not have the same situation with your engine, but it's a ***** to be pulling it right away for a rear main leak out of a "modern" seal.
    Good luck
    Jet96, Crazydaddyo and burl like this.
  12. walls
    walls
    Checking in for the new year
    Advice
    I ran one previously with a new aluminum head and new radiator. It never overheated without a fan. Wasn’t really a parade car though.
    The guy who wrote this article sent it to me a while back. I don’t remember if he posts on here or not.
    If you want to run a fan, could be worse options.
    I have a V8 pump for my recently acquired B engine.
    I plan to use it considering I need a pump and the new leakless model A ones have been out of stock for a long time now.
    we’ll see how it goes on my 2nd try.
    I’m a long way from running this engine though..
  13. Outback
    Outback
    from NE Vic, Oz
    I'm here nothing to report.
  14. I’m still here, still ac***ulating parts for a single seater but no actual progress as our house is on the market and the new hip is still a bit green.
    Outback likes this.
  15. Stovebolt
    Stovebolt
    My latest purchases.
    Just need a lhd brake cross-shaft to replace the multi-pieced unit, and its funky clamshell
  16. trikejunkie
    trikejunkie
    from Scotland
    THANK YOU....now I have an idea of whats required I can progress forward .
  17. Kiwi 4d
    Kiwi 4d
    Owner says 9N ford Willy jeep ?And forklift from a US aircraft carrier ? Not that i know but varies from what i expect of either 9N or ford willys jeep. We know over the years stories and information get mixed up. residing in a clark forklift at present. My pick is continental , Did see a 52 Kaiser on the weekend which from memory had the distributor in the head also . . 478ED017-69C7-42F8-8A14-EB9375B6A21A.jpeg
    Jet96 and Outback like this.
  18. Midnight Rider
    Midnight Rider
    from Australia
    Checking in for a summer of fun, hopefully.
    Outback likes this.
  19. Outback
    Outback
    from NE Vic, Oz
    @Midnight Rider hey mate, you should show us some of your treasures ;)
    Midnight Rider likes this.
  20. V4F
    V4F
    from middle ca.
    looks good john
    Old Dawg likes this.
  21. Crazydaddyo
    Crazydaddyo
    Thanks for the info. I'll make sure I address that at ***embly.
  22. Star 351
    Star 351
    Had my town sedan out for 10 days over my Christmas break, I've recently changed from a Stromberg 97 to a late larger 94 from a 272 yblock, I'm quite happy with the results, seems to be better on juice and it's low/part throttle response is way better i don't think it has made any difference power wise though 20221228_171157.jpg
  23. jim1932
    jim1932
    Time for winter projects.......
    fur biscuit, Jet96, Lil'Alb and 2 others like this.
  24. Dennis Gray caught these two shots of our car coming into; and out of the "Corkscrew" at last October's Velocity Invitational, Laguna Seca Raceway.
  25. jim1932
    jim1932
    Winter project #1 kohler brothers axle and roto flo shocks.
  26. Joebrownvw
    Joebrownvw
    Took mine out for a Boxing Day spin in the cold stuff! It was a blast and ran really well I’m the -10c temps although I did block off 2/3 of the rad to keep it warm
    Old Dawg, BeaverMatt, mvee33 and 6 others like this.
  27. winduptoy
    winduptoy
    IMG_20221227_093928385.jpg another finding from the tear down on the Burtz engine. The crank snout is just about .006 longer than the length of the front pulley so it doesn't seat tight against the crank timing gear. It was loose, front to back, in addition to being a loose fit in diameter. Repop parts on repop parts. Looks like I need to re look at the crank key size too....
  28. Dan from Oakland
    Dan from Oakland
    Did you remember to put the tin oil slinger washer on before the pulley?
  29. Jet96
    Jet96
    from WY
    Happy 2023 everbody, It hit -37 here at Christmas, haven't seen that in a while! Got a '31 project pickup, cleaned up the engine -found out it's a 1938 A diamond block, so pretty happy about that...
    winduptoy, Old Dawg, burl and 3 others like this.
  30. winduptoy
    winduptoy
    Yes, and yes I will again but thanks for checking
    Jet96 likes this.
