Technical Rotary table/welding positioner conversion
Discussion in 'The Hokey Ass Message Board' started by Plasmaman, Jan 5, 2023.
  1. Plasmaman
    Plasmaman
    When I got a bigger, newer rotary table, I tried to sell my old 9" Troyke on eBay with little luck. I decided to use it as a rotary welding positioner with parts from an old drill press. It tilts up to 90 degrees, and uses a variable speed 12 volt dc motor. Three clamping shaft collars and some s**** steel bar make a sturdy adjustable hand rest.
    0 degrees.jpg 45_degrees 1_3mb.jpg 90 degrees 1mb.jpg brass rod.jpg controls.jpg hand rest.jpg 1st attempt.jpg
  2. Bentrodder
    Bentrodder
    from Cotati
    That's really cool. Nice work!
  3. gimpyshotrods
    gimpyshotrods
    Can we get some details on the motor and speed controller?
    I have a positioner that is missing some parts.
  4. Plasmaman
    Plasmaman
    Motor is a 12 volt dc 100 rpm gear motor from https://makermotor.com. Speed controller is from https://lnztech.com. Since my rotary table has a 40:1 worm drive reduction, your speed requirements will undoubtedly be different than mine.
    Power supply is an older 8 amp 12 volt dc unit from Radio Shack. I picked it up on eBay.
    saltracer219 likes this.
