Projects 1938 chevy gasser
Discussion in 'Traditional Hot Rods' started by Oldskooloval, Jan 3, 2023.
Tags:
  1. 1971BB427
    1971BB427
    from Oregon
    I'm not a fan of the extreme nose high stance on these old coupes (or anything else too!) so I lik the drop I beam axles. I also like the looks of the I beam axles, and especially with some lightening holes drilled to add to the look.
    I'm using a '55-'59 Chevy truck axle in mine, but I did have to narrow it 5" to make it fit the car's width, and that also made the springs align perfectly with the rails.
  2. Looks Great in white!
    Stogy likes this.
  3. Rockchip
    Rockchip
    Nice start on a great project. '37 - '38 Chevrolet coupes make great hot rods. I've had my '38 for fifty years. Recently I learned something new about their frame wall thickness. Back in the late 70's I installed a 327 four speed in mine. I fabricated front engine mounts and secured to the frame rails with four nutserts per side feeling I had made a very solid cradle for the new motor. Many miles and years later, this summer I heard an odd noise under the hood. It was the fan ticking the lower radiator hose. Either the core support had move up, not likely, or the engine had moved down. It was the latter and further investigation revealed that over time, torque had worked the factory frame side wall on both driver and p***enger sides enough to shear a nice "smile" under each of my home built mounts. See photo. No fix for this one except to blow it apart and weld it up. It's on the way back together now with a few updates but my 2 cents for your project is to design your front mounts with this in mind.
  4. Oldskooloval
    Oldskooloval
    Went ahead and started the sheet metal work with the firewall. Going to locate the brake and clutch pedals
    saltflats, Stogy, roddering and 3 others like this.
  5. deathrowdave
    deathrowdave
    from NKy
    That is the stock Chebbie axle , at least it is the same axle that was in my 37 Coupe
    Stogy likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    Those top hat style frames are just sheet metal . I always added tubes through the frame to strengthen my mounting surface . Ladder bars of some type are a must , I twisted a NOS set of rear springs into a nice S shape easily . My thoughts were the torque tube was , there to stop twisting of the axle / springs . No torque tube = ladder bars
    Stogy likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I never care for the look. Especially when some one builds something that did not start life with a solid front axle then get’s a van/truck axle then uses blocks. I’m just that way.
  8. Oldskooloval
    Oldskooloval
    Bending the roll cage, had to set the body back on the frame so I can fit all the bars tight.
  9. Oldskooloval
    Oldskooloval
    Stogy likes this.
  10. Oldskooloval
    Oldskooloval
    Thank you! I will for sure
    Stogy likes this.
  11. 1971BB427
    1971BB427
    from Oregon
    The stock frames are much thicker than sheet metal, but not as thick as a C shaped frame rail. There have been numerous big hp cars running the drags in past years and using the stock frames. The issue is the mounting points really need to incorporate the bottom of the frame rails where the thickness is doubled. My motor mounts are welded to the inside of the boxed frame, but also to the bottom frame rails so they get support from below and from the side.
    Stogy, mad mikey and greasemonkey54 like this.
  12. ebs121781
    ebs121781
    from Spring, TX
    Glad to see some progress on this one!
    Stogy likes this.
  13. swade41
    swade41
    from Buffalo,NY
    Nice work man, a 38 chevy coupe is a car I've wanted for a long time but have never managed to get one, I was a FCH from buying this one a couple weeks back, but I'm just out of room for it and not willing to sell anything to make the room.
    A 37 would be just as nice but I like the 38's horizontal grill bars better for whatever reason.
    I have many photos of 37-38's saved but I really dig this yellow one.
    echo ed, saltflats, Stogy and 14 others like this.
  14. Rockchip
    Rockchip
    Agreed 1971BB427, and my revised design incorporates just that support from the bottom. Never too old to learn.
    Stogy, mad mikey and 1971BB427 like this.
  15. Oldskooloval
    Oldskooloval
    I know! It’s about time
    Stogy likes this.
  16. Oldskooloval
    Oldskooloval
    Thank you, that yellow car is very cool, the six cylinder just makes it plain awesome
    Stogy likes this.
  17. Flogknaw
    Flogknaw
    from Texas
    9B1C04FE-F770-4354-8CD5-88C1B35BD217.jpeg CE71DF74-274B-44C4-9AD7-BCD09733C514.jpeg 0AA63846-FE60-4747-9294-53650E0640B4.jpeg
    My grandpas 37 Chevy in 68-69
  18. Oldskooloval
    Oldskooloval
    Stogy likes this.
  19. Oldskooloval
    Oldskooloval
    Bent the roll cage tubing and tacked into place
    saltflats, Stogy, Manostihl83 and 3 others like this.
  20. Oldskooloval
    Oldskooloval
    Going to remove the body for welding and finishing
  21. Oldskooloval
    Oldskooloval
    Cut the original floor down the sides and removed the body 9640CE66-C33B-47B4-9993-C3CB7A707CBD.png
    saltflats, Stogy, Manostihl83 and 7 others like this.
  22. Oldskooloval
    Oldskooloval
    Cage is completely welded. Next up is some custom made brake and clutch pedals D189032D-DDDC-4C41-A242-BFD506153ED4.png
  23. I am sure you checked to make sure the body fit after the roll cage was constructed;!
    Stogy likes this.
  24. 1971BB427
    1971BB427
    from Oregon
    He built it inside the body, and then removed the boy to finish welding. Check his earlier posts.
  25. Of course,Hambers know what they are doing;!
    Stogy likes this.
  26. deathrowdave
    deathrowdave
    from NKy
    Looking great . My HS Buddy , his Dad has a ‘38 with blown Pontiac in it . Raced it for years . It left such an impression on me that I looked for years and found my 37 Coupe .
    Stogy likes this.
  27. Oldskooloval
    Oldskooloval
    Sounds like my story! Had a buddy in high school his dad had a 38 chevy coupe race car, 265 with dual quads. We would go over after school and see it in the garage, never saw it run and I’m guessing it’s still there! Never forget it had two cams sitting in the front seat in boxes, I had never seen a roller cam before.
    Stogy and guthriesmith like this.
  28. Eddie
    Eddie
    from Georgia
    As thin as those top hat frames are, I would wrap those bars totally around the frame with some plating or strapping.
    Stogy likes this.
  29. 1971BB427
    1971BB427
    from Oregon
    Not necessary if you make sure the mounts are tied to the lower flat part of the top hat frames. The metal is double thickness there and will hold anything any other type of frame holds. I always make sure my motor mounts, or any suspension, trans mounts are bolted or welded to the bottom part of these frames. That's what Chevy did with the entire front suspensions, and people have put hemi engines in without wrapping these frames and never torn out the frames.
    Stogy likes this.
  30. gearheadruss
    gearheadruss
    from Seattle
    Al Guerrero and Ben Liesmaki 37 Chevy with a fibergl*** tilt nose. Did anybody notice they spelt Liesmaki's name wrong on the driver's door. Ben was great at building 6 cyl engines.
    Stogy, Manostihl83 and swade41 like this.
