Technical 32 ford grill/ radiator ?
Discussion in 'Traditional Hot Rods' started by ModelARon, Jan 6, 2023.
  1. ModelARon
    ModelARon
    The original radiator that came with my car has seen better days. I think its a modified 1932 radiator. I had the radiator shop test and fix it a few years ago but after one year of driving it has a slight leak and the brackets on both sides have cracked . So i am thinking of getting a new US radiator made. I have a stock height 32 truck grill.
    Is the 32 car grill the same dimensions as the 32 truck grill? I asked the radiator company and they had to check and get back to me about that. Will a 32 car grill and truck grill bolt up to the same size radiator? Trying to confirm the radiator is the same for both.
    IMG_3657.jpeg IMG_0542 2.jpeg IMG_6610.jpeg Thanks for the help.
    2Blue2, chevyfordman, 34 GAZ and 2 others like this.
  2. nochop
    nochop
    from norcal
    Get it re-cored?
  3. krylon32
    krylon32
    from Nebraska
    The 32 pickup truck ans p***enger us the same radiator shape. They both bolt on the same. I would contact Johnson Radiator Works if I were looking for a new radiator. Yours looks like a 4 cylinder radiator.
  4. alchemy
    alchemy
    Yeah, what Gary said.
  5. BJR
    BJR
    On your picture the fill neck is not in the stock position, to have a visible cap outside in the center of the shell.
  6. ModelARon
    ModelARon
    Thanks. I will call Johnson Radiator.
  7. V8 Bob
    V8 Bob
    I would also check with Custom Auto Radiator in your area. They built one for my '32 and '40, copper/br*** construction, and very high quality.
  8. Mo rust
    Mo rust
    If possible I would look for a radiator that's an inch or two shorter because the 32 cowl sits a little taller than the 31 and if it your grill looks too tall, you'll be able to trim the sides a bit and lower the shell. I'm dealing with the same issue right now.
  9. krylon32
    krylon32
    from Nebraska
    On the 30/31 Model A's with deuce shells I've always used a 2 inch shortened deuce radiator to get the hood to flow down hill.
    akoutlaw, lurker mick and Mo rust like this.
  10. 31Apickup
    31Apickup
    I would verify the height of your radiator before getting another, your grill shell may have been trimmed on the sides where it sits over the frame.
  11. Mo rust
    Mo rust
    On my current 31 build, I bought a radiator that is 28 1/2" tall and I'm wishing that I made it at least one inch shorter. I'm thinking about cutting my front crossmember to allow the radiator to sink down another 1/2 inch.
  12. ModelARon
    ModelARon
    The overall height of the grill is 32" . I don't think it's been cut down but this is the only grill i have seen up close.
  13. ModelARon
    ModelARon
    I feel the grill height seems to work with this unchopped car. But it could be that i have been looking at this car for a few years so it seems normal. Not sure if a shorter grill will make a big difference.
    I might mock something up to see how it looks. Do you have a photo of an unchopped car with a shorter grill?
  14. Fordors
    Fordors
    I like the overall look of the car but honestly I think the radiator and shell could be an inch higher, maybe even a touch more. I’d like to see the side view taken a bit lower to get a better perspective.
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Super Blue paint
  16. I concur.
  17. ModelARon
    ModelARon
    I will try to find a local shop that can do a nice job. Any one know of a radiator shop in the north jersey area that can make a new radiator?
  18. ModelARon
    ModelARon
