Technical 1954 Ford auto transmission filter number?
Discussion in 'The Hokey Ass Message Board' started by Kreampuffkilla, Jan 6, 2023.
  1. Kreampuffkilla
    Kreampuffkilla
    Trying to find the part number for a transmission filter for my 54 skyliner. Mine has the automatic ford-o-matic 3speed overdrive. And don’t know if it’s a one fits all for all crestline transmissions. Or is there a specific one I need.
    thanks for your help
    302GMC and Boneyard51 like this.
  2. Boneyard51
    Boneyard51
    Wow! That is a very unusual transmission!
    Bones
    jaracer, vtx1800 and jimmy six like this.
  3. Marty Vanin
    Marty Vanin
    Those filters were a screen mesh,usually br***.Take it out wash and blow out with air. Put it back.
    Kreampuffkilla likes this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Check in with the '52-'59 Social Group, I would think you will get a answer fast.
    You will have to join the social group, but there is a lot of information available.HRP
    Click here:
    Kreampuffkilla and pprather like this.
  5. jimmy six
    jimmy six
    If what you say about your transmission is true it is not original to the car when no automatic with an overdrive was available at that time. it maybe swapped for a more modern one. Is your engine the original 239 Ford Y-Block or a later upgrade?
    You need to look a the transmission pan shape and the amount and arrangement of the bolting. It may say “metric” on the bottom also. There are drawings of pan bottoms on the net which will help identify what you have.
    I found the 1954 Ford transmission gasket and filter by just looking up “1954 Ford Automatic Transmission filter”. It looked identical to the one that was in my 56.
    Good luck.
    Moriarity and Kreampuffkilla like this.
  6. Kreampuffkilla
    Kreampuffkilla
    yes, it’s a 239 Y block. It’s the original one. And I think I made a mistake on the overdrive. It’s just a three speed Fordomatic. I don’t know why I said overdrive.
  7. Kreampuffkilla
    Kreampuffkilla
    Thank you. I will definitely join one
  8. Kreampuffkilla
    Kreampuffkilla
    It's a3 speed fordomatic. I don't know why I said overdrive.
  9. Slopok
    Slopok
    Or you could just go down to your local Orielly's and tell them what you need! :rolleyes:
  10. jaracer
    jaracer
    Like someone else said, it has a metal mesh filter. If the fluid is in good shape you can just clean it in a little solvent. If the fluid is burned I'd soak it in some good solvent like acetone. If you want a new one, these guys are likely to have one http://txchange.com/ along with any seals or gaskets you may need.
  11. Fisrust
    Fisrust
    How does one join the 52-59 social group? I'm new here and have much to learn. Thank you in advance.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
  13. AldeanFan
    AldeanFan
    I’ve used these on the fordomatic in my ‘54 ford wagon
