Technical 1926 Model T Ford Roadster Sub Rails "Help Needed"
Discussion in 'Traditional Hot Rods' started by chev34ute, Jan 8, 2023.
  1. chev34ute
    chev34ute
    Hey Guys. l picked up these panels over NYE with the intention of creating my own Roadster body. 7960325A-B9D6-447A-A697-255F5C47927C.jpeg
  2. chev34ute
    chev34ute
    I already have a cowl and doorsand the idea is for me to use the other panels as patterns to create new one ones out of steel. Everything from the cowl back will be new incuding the doors. 97E27A92-728B-4AA1-98A4-F489BE590D6D.jpeg
    Tman likes this.
  3. chev34ute
    chev34ute
    The reason i am fabricating all the panels is beacuse its virtually impossible to find these original panels here in Australia, the second reason is i dont have the funds to purchase a fibregl*** body, nor do i want one. One thing i do have is the equipment and resources to fabricate a body from flat steel. This is the Model A Roadster body i have been working on. 087D31CE-943F-4F03-A58F-13EABF50A95F.jpeg
  4. rusty rocket
    rusty rocket
    There was a picture here on the H.A.M.B. where they took the front half of a T roadster and graphed on the back half of a model A sport coupe rear quarters.
  5. chev34ute
    chev34ute
    The most important foundation for any project as extensive as this is to have a solid set of subrails. I constructed these ones out of 1x1 and 2x1 Rectangular Hollow Steel, while much cheaper than reproduction sub rails , RHS based sub rails are actually much stronger as well. 6DC227BE-66CE-4412-8411-D5850A4AF38A.jpeg
    Tman likes this.
  6. chev34ute
    chev34ute
    I will be constructing the subrails for the Model T Roadster using the same material. The subrails shown above will be used as a jig for the Model T ones.
  7. chev34ute
    chev34ute
    So the only thing holding me back is a lack of measurements. 4731C696-DB9D-40A0-8642-17A847B9CE76.png
  8. chev34ute
    chev34ute
    I found these images courtesy of google but i have been unable to source any of the sub rails on their own. A77D1D61-E4D4-438A-8958-302664AF8FBB.png
  9. alanp561
    alanp561
    Did you try the Wescott Model T frame drawing. Frame measurements and a scale to work off of for the subrail.
    upload_2023-1-8_21-56-22.png scale to
  10. chev34ute
    chev34ute
    Using Gridpaper i was better able to illustrate the measurements i require.
  11. chev34ute
    chev34ute
    Thanks for the feeback but im actually building the body to sit on a Model A frame as its more rigid and will offer more leg room.
  12. chev34ute
    chev34ute
    This measurement is perhaps the most important. Its the distance between the rear crossmember and the middle crossmember, the centre tub fastens to.
  13. chev34ute
    chev34ute
    The other important measurent is the distance between the left front corner and right rear corner taken from the inside. This will insure a square frame. B0F5286B-B4D2-4224-BF15-CAA3FF04069B.jpeg
  14. chev34ute
    chev34ute
    The overall length taken along the centre.
  15. chev34ute
    chev34ute
    The final one is the width of the middle and second last cross members.
  16. randombob
    randombob
    Try the below, let me know if I missed the mark. There is pics of the sub frame in the thumbnails, excuse the mess. All measurements in imperial, sorry. 1926 Model T roadster body.
    edit: I'll get overall in a little bit, just noticed that
    rusty valley likes this.
  17. Shadow Creek
    Shadow Creek
    upload_2023-1-9_20-11-5.jpeg Not sure if this helps or not, I saved this a long time ago
    chev34ute likes this.
  18. Gofannon
    Gofannon
    Depending on what style build you're aiming at, you might want to consider shortening the deck a little to get shorter wheelbase and better proportions. Also, you don't need a full cowl. Subframes were often cut away or discarded entirely.
    anthony myrick likes this.
  19. Gofannon
    Gofannon
    Navarro's T
    rusty valley and chev34ute like this.
  20. chev34ute
    chev34ute
    Thanks for that.
  21. manyolcars
    manyolcars
    The subframe shown here is for roadster pickup, not the same as coupe
  22. randombob
    randombob
    The T mentioned was a roadster, otherwise I wouldn't have jumped in.
    I still owe you overall! 88.5" from front to outside, on a 1926 roadster body.
