57 Chevy BelAir Gasser Build
Discussion in 'The Hokey Ass Message Board' started by KrucksGarage, Jan 9, 2023.
  1. KrucksGarage
    KrucksGarage
    I have been eyeing this 57 for a few years sitting at a friend's house. Long story short, I met the owner through the purchase of something completely different and happened across this sitting on the property. I of course inquired about it but it was a sensitive subject at that time and sentimental to him. He always wanted to restore it but wound up taking the route of buying a restored 57 (beautiful car) and recently let this one go. I've had it around a month now. It was his mother's car and had been sitting under a tarp for the last 40+ years! I also picked up two parts cars in the sale that had been sitting on the property for 25+years, a wrecked 2-door Belair post, and a 4-door 210. I parted out the post car and plucking a few things from the 210. The floors are in pretty tough shape and will be replaced, but the outer skin throughout the whole body is in great shape. I plan to make a few initial frame modifications like pocket the rear springs, and stiffen the frame rails. I'm also going to replace the entire floor and trunk pan, and install mini tubs or modify the rear fender wells myself to align with the outer frame surface. Then I'll probably clean down and do the best preserving job I can of the original patina, since it has the factory onyx black paint still mostly in tact and untouched, and mount it back on the frame before going after the front end and lopping off the front horns. I'm looking for a 55-59 Chevy drop front solid truck axle.
  2. KrucksGarage
    KrucksGarage
    Here's a few more pictures of the first day of ownership. Definitely a solid start to this project. I've had this idea in my head since childhood and excited for the build. I can remember the admiration for these cars growing up going to the drags, Super Chevy Sunday events, nostalgia events and friends with these cars.
    PXL_20221210_181413861.jpg PXL_20221210_183037697.jpg PXL_20221210_183134162.jpg PXL_20221210_174431609.jpg PXL_20221210_173247669.jpg
  3. KrucksGarage
    KrucksGarage
    Here's a few photos of the interior and transitioning into the shop before and after removing the seats and panels. Original interior as well on this car. I have every piece. The owner started to dis***emble things like the dash cluster many many years ago so the car was full of boxes and cans of parts and hardware when I got it. The boxes fell apart when I handled them. He did a decent job tagging pieces 40 years ago but the paper tags and masking tape was pretty brittle and not legible.
    PXL_20221212_052009886.jpg PXL_20221212_051114535.jpg PXL_20221212_051936958.jpg PXL_20221212_052103855.jpg PXL_20221212_035630822.jpg PXL_20221212_052014298.jpg PXL_20221212_052019859.jpg PXL_20221212_035646948.jpg PXL_20221212_052051543.jpg
  4. KrucksGarage
    KrucksGarage
    Pics of beginning dis***embly and pulling the trailer hitch, gas tank, bumpers, engine and trans. 283, 3-speed column shift with the under dash cable actuated overdrive. Engine and trans with OD is for sale!
    PXL_20221220_235756367.jpg PXL_20221221_001405684.jpg PXL_20221221_001415399.jpg PXL_20221220_213729299.jpg PXL_20221220_235519339.jpg PXL_20221219_031800188.jpg PXL_20221221_201631445.jpg PXL_20221219_031810879.jpg PXL_20221221_044829572.jpg PXL_20221221_044857513.jpg PXL_20221221_042047524.jpg PXL_20221219_032124297.jpg PXL_20221221_045717030.jpg PXL_20221220_210401701.jpg PXL_20221221_044903100.jpg PXL_20221221_045624643.jpg
  5. KrucksGarage
    KrucksGarage
    Body is off the frame, deleting spring hangers to move towards pocketing the leafs in the frame, and removing rear engine mount frame horns.
    PXL_20221230_000617694.jpg PXL_20221230_000627739.jpg PXL_20221223_015744205.jpg PXL_20221230_001821147.jpg View attachment 5615607 PXL_20221230_001851158.jpg PXL_20221230_001859851.jpg PXL_20221230_002137766.jpg
    winr, lucky ink, El Caballo and 18 others like this.
  6. KrucksGarage
    KrucksGarage
    Frame is all stripped and initially cleaned up. Now this is on hold until I order the pocket kit from Woody's or decide to fab up my own parts.
    I'll be moving to floor replacement in the body, but need to decide on my method of how to have the body sitting. I have the option to borrow a rotisserie from a friend while it's available but I think I might just leave it as is on the stands and go for it. I'll have to build some bracing before cutting that much steel out of the body.
    PXL_20221231_003851503.jpg PXL_20221231_011900623.jpg PXL_20221231_011919176.jpg PXL_20221231_013957995.jpg PXL_20221231_014049569.jpg PXL_20221230_224220138.jpg PXL_20221230_224445957.jpg
  7. pprather
    pprather
    Welcome to the HAMB from Illinois.
    Nice '57 project.
    Deuces, mad mikey and KrucksGarage like this.
  8. KrucksGarage
    KrucksGarage
    I have a couple different weapons here to choose from and would love any input. I had this Muncie M21 rebuilt and ran it in my El Camino behind a 454 big block for a short while but didn't like it with the gear ratio in the rear end at highway speed with the 1:1 fourth gear so I installed a Tremec 5-speed in that car for the OD. Nice gear box though. This other one is a top loader Dearborn out of an Olds 442. Still a 1:1 fourth gear, but a 3-speed. They ran these FoMoCo iron cased 3-speeds in a few GM cars, I believe Pontiac, Buick and Olds starting in 65 to get away from the 4-speed insurance issues and other reasons and the Saginaw GM 3-speed boxes were subpar for the HP of some of those cars so this trans was sourced for a while, and I guess they're pretty stout. I think I'm going to run it in the 57 and kind of excited to run something a little odd and different. The mount face at bell housing, to the aft end of the output shaft is only 1/4" different with the Muncie bring that much longer than the Dearborn.
    So if you have input, my intended use is just casual cruising, taking the family to car shows and events to barking tires and a few burnouts with the occasional run down the local track for fun, nothing crazy compe***ive. I'm looking at TBS's (the blower shop in Idaho) 6V-71 modified (15" to 12" reduced rotors) 6-71 blower to build into a 383 small block. I still have a lot of planning to get dialed in on HP goals. Think they Dearborn will be up for it? The testing discussion I've seen from back in the day sounds like they went through some pretty harsh things without failure back in the 60's.
    winr, -Brent-, lucky ink and 13 others like this.
  9. Pretty solid car , interesting thread!
    KrucksGarage likes this.
  10. 57 HEAP
    57 HEAP
    Built in California. Where are you?
  11. KrucksGarage
    KrucksGarage
    Washington State, Olympic Peninsula
    El Caballo and chryslerfan55 like this.
  12. DDDenny
    daniel wilson and chryslerfan55 like this.
  13. KrucksGarage
    KrucksGarage
    This car does have the one-piece "california style" bumpers, but I have the two piece seamed frame. I have all VIN and body tag manufacturing information processed, but I'll have to go back and review it to recall where the car was made. There were various locations that applied the one piece bumpers as I understand. Would be nice to have the one piece frame too.
  14. catdad49
    catdad49
    Considering how long it was sitting (outside?), it looks pretty solid. Have Fun with your project, Carp.
  15. KrucksGarage
    KrucksGarage
    True. Yea it was outside tarped up for 40 years or so. I guess it moved around the property a handful of times so hard to say 100% what it's been through but yea very solid other than floors. It'll be easiest to just chop and drop those out and replace the whole bottom side at the pinch welds.
    SS327 and chryslerfan55 like this.
  16. chevy57dude
    chevy57dude
    Very cool. You'll probably need inner rockers as well. You may be able to find your V.I.N. on top of the frame while it's all apart.
    COCONUTS, Deuces, SS327 and 2 others like this.
  17. KrucksGarage
    KrucksGarage
    Yea I bet I'll be doing rockers too! I'm looking forward to getting these floor pans cut out to see what I'm working with. I have the VIN, it was on the pillar like usual. Also have the body tag from the firewall. Here's the VIN info:
    (So it is a California car with "California bumpers")
    1957 Chevrolet Belair Sport Coupe VIN:
    VC57O146000 ABCCDEEEEE
    A: V=V8 B: C=2400 Series, Belair Models CC: 57=Year D: O=Oakland, CA EEEEEE: 146000, Production Numbers begin with 100001 for 57 model year
    Cowl Tag:
    Style: 57-1037O 57-1037=210 and Belair 2-door Hardtop Body Style, O=Oakland, CA ***embly Plant Code
    Body No: O 6475 O=Oakland, CA, 6475=***embly plant sequence or rotation number, not same as VIN sequence.
    Trim: 670 670=Black/Silver interior with Cloth/Vinyl Model Code 1037D
    Paint: 793A= 793=Black Onyx, A=Single paint color ACC: None
  18. KrucksGarage
    KrucksGarage
    Spending a little time getting inspired this morning with my coffee, reviewing the Woody's catalog, ordering parts and reading some of my old magazines and just getting fired up about 57 G***ers! I recently joined the American Trifive ***ociation, and bought into some com Southeast G***ers swag too. This old Trifive magazine is from January 1982. Love looking through these, have a big collection of oldies from my dad, uncle, friends and estate sales.... I bought the diecast online and what a cool model! Well made. The picture of the g***er with red gl*** I found online, but don't know much about it. That's the type of direction I'm going to go, minus the colored gl***. More of a "g***er inspired" build than a track car with all the perfect period parts and weight cutting, but we'll see where it goes. I don't plan to trim the rear wheel openings, I love the factory lines, and might even run the smoothie front bumper. That's a tough call on that one.
    Screenshot_20230103-220619.png PXL_20221031_230210869.jpg PXL_20221031_230203738.jpg PXL_20221221_215326904.jpg PXL_20221031_231704332.jpg image.jpg PXL_20221031_231609041.jpg PXL_20221031_231558771.MP.jpg PXL_20221031_231542957.MP.jpg PXL_20221031_231731102.jpg PXL_20230101_171631590.jpg PXL_20221031_231121496.jpg PXL_20221031_231108423.jpg PXL_20221031_230413817.jpg PXL_20221031_231139974.MP.jpg PXL_20221031_231131089.jpg
    winr, lucky ink, El Caballo and 17 others like this.
  19. gconnsr
    gconnsr
    from AZ
    What a score, to be honest with you I kinda liked the stance it had when the front tire was flat.
    Hollywood-East and KrucksGarage like this.
  20. catdad49
    catdad49
    Wow, seems as though you have a case of “57 Fever”! My Dad bought a Sport Coupe similar to the one on the Hot Rod cover (283/195 HP w power glide).
  21. KrucksGarage
    KrucksGarage
    Yea me too!!
  22. Super/Stock Poncho
    Super/Stock Poncho
    from Missouri
    If building a period G***er, got to delete front bumper. I Love Tri-five G***ers! Good luck with your build.
    mad mikey and chevy57dude like this.
  23. KrucksGarage
    KrucksGarage
    Yes pretty much no option huh?! The 55's look pretty cool without the bumper, 57's are a little tougher to get to look right but I think I have a solid plan! Thanks!!!!
  24. 40FORDPU
    40FORDPU
    The great thing about these tri five Chev's is there are so many ways to go with them.
    Seems you have dialed in a plan for yours, now just a matter of making it happen.
    Thanks for sharing, good luck.
  25. mad mikey
    mad mikey
    I have been in love with 57 Chevy's ever since I was a little kid, our neighbor had one, he was a street racer. Congratulations on getting this car and have fun with the build.
    Deuces, rod1, chryslerfan55 and 2 others like this.
  26. If you go with the 3-speed, I'd keep that a tree shifter.
  27. fordman1
    fordman1
  28. KrucksGarage
    KrucksGarage
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
  30. choptop40
    choptop40
    they look like they are going 200 mph -------- standing still !!!
    Deuces and KrucksGarage like this.
