Technical ***January 2023 Banger Meet Thread Another trip around the sun***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 2, 2023.
  1. I too have run into troubles with the keys and dampeners/pulleys/etc.
    I no longer run stock soft keys, I get alloy version from McMaster and double check for proper ***embly.
    Of course this is much easier if you do it before putting the front cover plate on.
    John
    Crazydaddyo, Jet96, ottoman and 3 others like this.
  2. walls
    walls
    Any thoughts on the pitting and, I’m guessing crack repairs?
    Big deal? Or not really?
    A4676FFE-7F99-45D8-9131-ED1F16858244.jpeg A5C663EA-FD26-4FC8-AE2D-88B588CCA2CD.jpeg
  3. Outback
    Outback
    from NE Vic
  4. walls
    walls
    No plan other than to run this engine as is hopefully.
    Looks like it was rebuilt at about 1000 or so miles ago(per the previous owner)
    It has a counter balanced crank. Everything else looks in order.
    It was running six months ago before it was pulled for a small block.
    I’m not looking to use this for touring, but wanted to put a nice head/carb/ignition and cruise this thing around.
    Would you say this thing is “good to go”? ‘I just don’t have any experience with flathead crack repair/pitting.
    Outback likes this.
  5. Outback
    Outback
    from NE Vic
    I'm not the most qualified to comment here but thought it would help to have the background story.
    I would suggest that if it's a runner then bang on those parts & enjoy it.
    I would also suggest that I wouldn't spend any real money on that block as there are much better ones out there...
    C/W crank is a real bonus.
  6. Made a few changes, oddly all banger related, just slightly smaller displacement and extra traction application devices. Over Covid I bought a pile of a CJ2A as a play structure for my son (cheaper than some wood and plastic contraption), and it was a hit. Then I decided to start working on it, last May when I was relocated from HTX to Tucson and significantly reduced garaging opportunities. Progress has been slow. The other day a friend called and he needed to part ways with his 2A, so...at the end of the month, I'll drive out to beautiful Portales, NM and pick up a complete and operational CJ2A. The second upshot was that I sold mine, emptied 2/3rds of the garage and started organizing. My better half was so proud...little does she know there is a speedster inbound once the snows p***
  7. Walls,
    Yes, pinning it an acceptable and preferred to welding to repair the blocks.
    The big IF is it must be done correctly and you have to stage the process.
    For instance, if the crack runs under a valve seat, you must replace the seat first and then pin, other wise the new seat can loosen the pins.
    But, I see more then just the pins, which look decent to me. The two head studs around #4 have helicoils and those will be a source of water leakage. Some of the old Permatex snot or other non hardening sealers must be used here to seal them up.
    As for the bore, with that much water, I would suspect the rings to be rusted into the piston and stuck.
    Take the pistons out and carefully loosen the rings, then decide if they need replacement.
    You should be fine up to about 75-80 HP, any more than that start looking for another block.
    John
    winduptoy and Old Dawg like this.
  8. Kevin Pharis
    Kevin Pharis
    from Califunny
    The crack pins and valve seats appear to have many successful miles on em… and so does the bore! Wouldn’t bother me for a stocker or moderate hop up
  9. Midnight Rider
    Midnight Rider
    from Australia
    I can't find the key to the vault at the moment. Will try and grab some old pics maybe.
    Thanks for the prod Outback.
    winduptoy and Outback like this.
  10. Outback
    Outback
    from NE Vic
    Looking forward to it!
    A yarn about your buck in a banger would be fun too! ;)
    winduptoy and Midnight Rider like this.
  11. Outback
    Outback
    from NE Vic
    Also out of interest, can someone tell me what the standard Model A Cam profile is? IE lift/timing
    I have a reground cam here but don't know what it's performance potential is.
    I expect there isn't much room for changing valve timing with a re-grind cam?
  12. When I get home, I can share what Dema did to the A cam that is going in my T. (It arrived!)
    as to valve timing changes, what are you thinking?
    Old Dawg likes this.
  13. Do a search for Brierley’s cam shafts in previous months
    It gives duration and lift
    J
    Old Dawg and Outback like this.
  14. Outback
    Outback
    from NE Vic
    Thanks,
    I am just trying to get a gauge of what this cam might be good for.
    3/4 Race is what I was told... not sure which 3 cylinders though!
    Jet96, Stan Back and Midnight Rider like this.
  15. 5280A2
    5280A2
    Here's the Brierly Cam list once again.
    51 mercules, winduptoy and Outback like this.
  16. Outback
    Outback
    from NE Vic
    Th
    Thanks so much.
    I had started looking but hadn't found it yet.
  17. What specific criteria are you using for the identification?
    J
  18. The F.A.S.T. Time Trials are slated for Saturday June 24th at the Historic Santa Margarita Ranch, California!
    GuyW, Crazydaddyo, Outback and 6 others like this.
  19. Found this little guy. Don't have much garage space, and not like it will do huge lifting. Will be nice to make bungs, plugs, odd bits, and so on. There is a 3 jaw chuck still available, so that will be inbound soon.
  20. Fabber McGee
    Fabber McGee
    Lots of little jobs can be accomplished with that machine. Need patience for making .010 or .020 cuts. But after all, you're probably not building a space shuttle on compe***ive bids. Good score.
    winduptoy, Jet96 and fur biscuit like this.
  21. Side driven water pumps… what do you guys know about them?
    From what I know so far, Frontenac and Ambler made them A2070983-469A-42C9-9FC5-DEB99EA15442.jpeg
    Jet96 and Old Dawg like this.
  22. studebakerjoe
    studebakerjoe
    @Retson the Racer that style of water pump was used on quite a few cars the Stutz a**** them. No doubt guys adapted some from other cars as they adapted the dual distributors you could also find on some Stutz cars.
  23. hotrodA
    hotrodA
    ^^^^ That’s a VERY cool piece!!!!
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    Spent yesterday building bellcranks for my carbs
    GuyW, Old Dawg, Crazydaddyo and 12 others like this.
  25. Outback
    Outback
    from NE Vic
    I haven't measured it properly yet but I know it has .325 lift on both.
    I was going to put a timing disc on it & plot it with a dial indicator. The card says .090 @ tdc In.
  26. PINEAPPLE
    PINEAPPLE
    Those are killer!! Do you have a radius turning attachment for the steel bit with balls? How do the ball ends pop in to the br*** and stay snug and swively? Fantastic work man.
  27. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Checking in, got the new finned cover from Retson. Did it up black and wiped the fins off to match the valve cover.
    I think it cleaned up the look alot.
    hotrodA, Old Dawg, Steves46 and 5 others like this.
  28. Outback
    Outback
    from NE Vic
    I haven't gotten too far yet. It has .325 lift on both.
    I was going to use a deg wheel & dial indicator to plot it. Says on card .090 @ TDC inlet
  29. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Looks like the repairs were done ok, I would tend to agree with others, run it and dont throw a ton of money at it but you can make some decent power with it without issue if its all good.
  30. Flatdash
    Flatdash
    Outstanding... Milleresque in the accomplishment.
    Outback likes this.
