Technical Width of Ford 8" Rear End
Discussion in 'Traditional Customs' started by Chop50, Jan 9, 2023.
  1. Chop50
    Chop50
    Anyone know the general width of a Ford 8" rear end? Or would it depend on what it came out of? Good fit for a shoebox?
    Thanks, Steve
  2. squirrel
  3. bill gruendeman
    bill gruendeman
    I believe an 8 inch out of a maverick is 56 wm to wm .
  4. 51504bat
    51504bat
    56.5 WMS to WMS for the Maverick and that's the narrowest one IIRC.
  5. gimpyshotrods
    gimpyshotrods
    Also magically the same width as a square body (1990-1992) Ranger 8.8.
    jimmy six and Budget36 like this.
  6. krylon32
    krylon32
    from Nebraska
    I have an 8 inch Maverick rear in my 40 with 7 inch wide wheels. It is perfect.
  7. flatout51
    flatout51
    If you're running skinny bias ply tires 65-66 mustang 8 inch works well too. Little wider than maverick but far easier to find
    51504bat likes this.
  8. And again... The Maverick 8" is 56.5" WMS to WMS. Move the spring perches in 13/16" on each side, and it is a bolt in for the shoebox. Even the emergency brake cables work. The 5 lug one came in two versions 70-73 had a 2-3/8" register, 74-77 had a 2-3/4" register, so the drums differ. The rear is getting a little harder to find, but still out there. A good alternative, as @gimpyshotrods stated, is the Ford Ranger 8.8, which can be converted to disc brakes easily. The only downside to the 8.8 is ratio- finding one in the 3.08 range is harder.
    Tony Ray likes this.
  9. I have a Granada rear in m 47, and I believe it's 58(1/2) WMF to WMF. Seven inch wide wheels work well, and CE sway bar clears the inside of wheels. Shoebox, as mentioned above, may need the narrower rear.
  10. Budget36
    Budget36
    Maybe not easy to find, but a lot easier than finding a Maverick rear;)
    irishsteve likes this.
  11. Slow down
    Slow down
  12. Mr48chev
    The big problem with 8 inch rears now is that donor cars are few and far between and many have hit collector car status rather than donor car status.
    lothiandon1940 and gimpyshotrods like this.
  13. gimpyshotrods
    gimpyshotrods
    There are about 45 of them within 100-miles of me.
    The same cannot be said for a Maverick.
    Budget36 likes this.
  14. nosford
    nosford
    That same chart that has been going around for years with the 67 Fairlane with coil springs and 63.5 inches wide, it does not exist. Most of the 9 inch axles you can find now are F100 units with 5.5 inch bolt circle and 61.25 inches wide, also have the spring perches on top of the axle for spring over axle mounting. Other than the spring perches they fit a 46 - 48 Ford fine with stock wheels. The 8 inch axles are harder to find, I bought a wrecked half parted 75 Comet (same as a Maverick) to get the last one I bought.
  15. gimpyshotrods
    gimpyshotrods
    On the topic of 8.8 rears:
    They were used in a whole lot of vehicles, in a bunch of different widths.
    The 4x4 site The Ranger Station has a comprehensive list of axle shaft lengths, so it is possible to roll your own ready-to-narrow package before even leaving the self-service yard.
    https://www.therangerstation.com/tech_library/Ford-8_8-axle.shtml
    Scroll down for the axle shaft chart.
    No need for custom axle shafts. The popular one is to get an Explorer 8.8, and ditch the "long side" axle shaft in the yard, putting another short one in for the ride home.
    If you are not adventurous enough to try narrowing a housing, or don't have the tools, any shop with a jig can do this job easily.
    If you bring me a well-cleaned housing (and you can even leave the pinion in, and set), $50, and go get me a burrito at the joint on the corner of my block, your housing will be done and cooling by the time I am eating.
    The 8.8's often have a bit of pinion offset. While this is not an issue, you can "edit it out" or drastically minimize it with the right narrowing job.
  16. gimpyshotrods
    gimpyshotrods
    Oh, and an Explorer 8.8, with one shortened tube, and two "short side" axle shafts is 56.62".
  17. ramblin dan
    ramblin dan
    Axle widths flange face to flange face. axle widths flange face to flange face.png
    MO_JUNK likes this.
  18. blue 49
    blue 49
    from Iowa
    How wide is an early 60's Fairlane? I bought one once and couldn't use it for what I was doing. At the time I thought it was narrower than the Maverick I'd used before.
    Gary
  19. gimpyshotrods
    gimpyshotrods
    Both the Ranger and Explorer numbers on that chart are incorrect.
  20. Tony Ray
    Tony Ray
    D7271C95-123B-4156-93C2-7D7315F1A839.jpeg I have a 73 maverick 8 inch rear in my shoebox. Believe it’s 56 1/2 from wheel mounting surface to wheel mounting surface.. It fits you just need to push the leaf springs apart some to bolt then to the perches. Wasn’t a big deal. I used the maverick rear with shoebox centrals 3 inch lowering springs, and 3 inch blocks on my 51 coupe.
    LSGUN and MO_JUNK like this.
  21. Chop50
    Chop50
    As you look at my Shoebox you will see the stance with 4" blocks in the rear. Two issues with this are the ride is not great and I have to deflate the rear tires, unbolt the shock to be able to get the tire off. I have a stock 51 Ford rear in it with 56 7/8 flange to flange. From what I am seeing there is not a stock rear end that will work. That being said I have a 9" rear that I am preparing to shorten for this application. Interestingly the tire rubs on the quarter panel side of the fender well, and I do have room to move the wheels inward..
  22. gimpyshotrods
    gimpyshotrods
    Chevy S10 2WD rear is 54-1/2 to 54-3/8" depending on the year, and which drums.
    The 4x4 one is wider.
  23. Tony Ray
    Tony Ray
    Unfortunately I doubt you’re going to find a rear unless you really shorten it, that you can put in a lowered Shoebox that lets you take the tire off with out rubbing. This is due to the shape of the shoebox’s rear wheel well. There is another option if you are still doing body work to it though.. Raise the wheelwell up. Everyone I talked to had to unbolt the spring or shock or jack the car up by the frame and then use a bottle jack to jack down on the leaf spring to swap a tire out. On mine, I knew I wanted to run 51 mercury skirts, so Chopolds raised my wheel well up just under 2 inches. The 51 mercury skirt fits perfect then(without the stock side trim) and the wheel goes on and off with out touching the wheel well. F717E444-BE63-4210-B55A-2D0AAAF54D50.jpeg C58F1FD2-9274-4637-9D06-FBFA721D9CD6.jpeg 989C24FF-C3B5-4AE9-9BF6-56FE76A701C6.jpeg E31CC18F-05EA-4F20-AECF-9ED7FAABE8F5.jpeg B0EAF731-9902-4A71-A9D2-11275DAB8A90.jpeg
    Algoma56, X-cpe and Budget36 like this.
  24. Chop50
    Chop50
  25. Chop50
    Chop50
    I had been thinking about raising the fender well. I have Foxcraft skirts on it, I will have to go out to the shop and measure the distance between the lip and the edge of the shirt. How much did you lower the rear end?
  26. Tony Ray
    Tony Ray
    I have the 3 inch lowering leaf springs and the 3 inch blocks.. I can easily do the 4 inch blocks if I wished but I was worried about hitting the trans tunnel
