Hot Rods ROLL BARS?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jan 7, 2023.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I remember watching seat belt tests in the Body Engineering Lab at Ford. If belts were mounted to the seat they had to withstand 30Gs, meaning that the weight of the dummy and the seat was subjected to 30 x (driver+ seat ***embly).
    So for a 350 lb combined weight that seat anchor had to withstand 10,500 lb load. The tensile testing rig was pulling through holes torched in the firewall while the car was anchored to the test bed. The machine literally pulled the floorpan inside out before failure.
    Thereafter, I tried to use very large cupped washers welded to the underside of my floors or install an outrigger (inrigger?) on the frame rail to handle the load.
    Another eye-opener for me, unfortunately, was when I crashed my old Logghe roadster head-on into the concrete guardrail at Norwalk. Although I was belted in with a 5-point harness and helmeted I bent the 1" chrome moly front seat crossmember brace forward an inch or so. Fractured L4 and L5 vertabrae and temporarily lost my vision. That gave new respect for following NHRA minimum guidelines.
    chevy57dude likes this.
  2. Then use DOT approved harnesses
  3. using a “body reinforcement” isn’t a bad idea.
    The term roll cage gets the engineers and race guys stirred up about rules and such. Those are important on the track. The body reinforcement I’ve done wouldn’t meet any race spec. But the door alignment was more consistent and hopefully prevented the coupe cracks due to ****** flexing. Probably helped in a moderate side hit or possible roll over.
    I’ve never seen a car denied insurance for a cage. I’ve put both custom built and bolt in cages in cars insured and street driven with race harnesses.
    ekimneirbo likes this.
  4. spanners
    spanners
    Not really applicable to the question but for general knowledge. In Australia you won't get a modified car engineer approved with a rollcage for street rego.
    GlassThamesDoug likes this.
  5. GlassThamesDoug
    GlassThamesDoug
    20221126_151837.jpg When my Dad and I took the Thames to DMV to get a VIN, street legal ***le in a very small town. After all safety checks, DMV Inspector said (75+yr old) ..Y'all built a real nice car. (What ever this is) And I am not going to ride in it for road worthyness portion of test. I will just take your word for it. VIN and ***led.
  6. Bandit Billy
    Bandit Billy
    I insured my OT dune buggy through Haggerty and they requested photos. When they saw the roll cage they almost didn't insure it. It had wheelie bars when I bought it and they definitely nixed that, which was okay since they were the first thing off the car. What we may tell our wives are safety items the insurers see as high-risk, racing accoutrements.
  7. called my insurance person. Gave em a vin and done.
    Thing could of had wings with rocket launchers
    Tman and Bandit Billy like this.
  8. twenty8
    twenty8
    Just curious, have you ever had to make a claim?
    Would they quibble about this sort of stuff when it comes time to cough up some money?
  9. Nope. So far so good.
    I fix my own ****. If they get close I’m good
  10. twenty8
    twenty8
    This from another thread is very apt.......
  11. Dave G in Gansevoort
    from Upstate NY
    Schroth (spelling?) make a 4-point harness they call a harness belt, that is also DOT approved. Very spendy, more than a quality race harness, but uses good engineering to make them effective without the 5th strap. It has to do with one of the shoulder straps having a fold sewn into it in such a way that in an accident the strap allows the person's upper body to rotate, causing the abdomen to "lock" the lap portion down to the hip bones. This keeps the belts from riding up and the body from submarining.
    The reason those belts are DOT approved is the buckle. It looks just like a new car push ****on buckle. Just what rescue people are looking for if they have to get you out of the car. SCCA used to allow them for track day events. No idea what NHRA has to say...
    They had inertia lock devices, but I don't know if they still do. These allowed you to move around in the car just like in new cars. And they locked up with very small decelerations.
    I'm planning on using them in the Whatever project if they are still available in the near future.
  12. Sometimes. Depends on the customer.
    Ive seen ins pay off on rides wrecked on tracks.
    I’ve fixed several.
    Also seen em not pay.
  13. spanners
    spanners
    Not quite the same but my avatar was insured with Shannons for theft or damage while in transit to and from events as was the race trailer. The racecar was covered up until I entered the staging lanes or after the return road.
  14. X-cpe
    X-cpe
    When it comes to sanctioning body roll bar specs and general safety rules, most are written in blood.
  15. Ned Ludd
    Ned Ludd
    Four-point harnesses with inertia reels are not unknown in light aircraft installations. Interestingly, the shoulder straps are often mounted to the aircraft's roof, contrary to the common requirement in racing rules that the shoulder straps should mount lower than the driver's shoulders. The anticipated emergency situations are, of course, very different.
    I found this description of the Schroth ASM feature:
    "Schroth ASM stands for 'Anti Sub-Marining' - a feature built into street harnesses that prevents the occupant from sliding under the lap belt in a crash (submarining). In a race car this is achieved by using a sub-strap (crotch belt) that mounts to the floor and is routed through the racing seat to the buckle. That's not possible or safe to do on a factory street seat. Schroth's solution is ingeniously simple and has proven effective in testing and the real world: ASM is an extra few inches of belt that is folded along the inside shoulder belt and hidden under a plastic cover. In a frontal accident the extra belt length is released and allows one side of your body to fall further forward than the other side. This causes your torso to twist, which prevents you from sliding under the lap belt. The ASM is on the right shoulder for a driver and the left shoulder for a p***enger (in a LHD vehicle). This also has the benefit of forcing each occupant away from each other. ASM is a standard feature in all Rallye 3/4 and Quick Fit harnesses, as well as on the special Profi II ASM belt. The system is redundant in a Compe***ion harness since those are designed with a sub-strap."​
    So it's basically an engineered stretch zone, like a reverse crumple zone.
  16. jnaki
    jnaki
    Hello,
    HAMB era hot rods? If the goal is to have one that looks the part, there are no qualms about the style of the build as per 1959-60 builds. Anything that was supported to the frame and covered the driver/p***enger seems ok. Sometimes, the single point roll bar was strictly for the driver in his position of a coupe/roadster or off to one side. But a street purpose hot rod was ok to not have a roll bar other than it was welded to the frame.
    The rules did not mention that a gas coupe or sedan + street roadsters/RPU trucks had to have a roll bar as they were stock street legal hot rods.
    So a designation has to be made. If today’s hot rod had to have a roll bar, a dual bar cage is not HAMB rules appropriate. Then again, you may not be able to run certain events. But, at least you will be designated HAMB appropriate.
    Thank goodness for safety inspection technicians. The modern day roll bar requirements are for the safety of the drivers. In the old days, it was the same. If your head was under the point of the roll cage, then it met the safety rules. These days, no way it would p***.
    Jack Chrisman in Ed Losinski’s Hemi FED checking on his opponent in the next lane… roll bar? Isn’t there one back there above my head??
    H&H Garage... Tets Ishimaru Supercharged MEL FED race car
    Jnaki
    In 1959-60, the safety standards were created for the racers.
    By today’s standards, not even close…
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    That sounds like a recipe for years of spinal physical therapy.
  18. Blues4U
    Blues4U
    from So Cal
    It could depend on the installation. Incorrectly mounted or installed belts may be worse than none, I'm not really sure; but I do recall a local organization that hosts track days at local road race tracks; and if you've installed 4-point belts they state the car will have to p*** inspection. Factory installed 3-point belts are fine and need no inspection. Not really the same thing as your comment, but I think it shows that how the belts are installed is important.
    Or he's just a ****....
    That comment and the post by @DDDenny about the belts mounted to the seats instead of the floor reminded me of a prior discussion we had around here on whether it's best to mount the belts to the floor or to the frame. In the case of an accident where the body is sheared off the frame it would truly **** to be strapped to the frame! I'd rather be strapped to the body as it bounced away; though I guess you're unlikely to survive that severe of a crash in any case.
    Terms can do that. I attended training with Mack more than a few years ago, on their MP series of engines, and the trainer told us they don't use the term "firewall" to refer to that section of metal that separates the engine area from the p***enger compartment. He was serious, "don't call it a firewall". The term makes lawyers and marketing people nervous, it's like you're acknowledging the potential for fire damage, which could be held against them in a lawsuit. I don't recall the term he used, but the cl*** all got a kick out that and making jokes about it during the several days of training.
    anthony myrick likes this.
  19. Blues4U
    Blues4U
    from So Cal
    That's really the rules for some sanctioning bodies? I thought it was pretty common knowledge that shoulder belt mounts need to be elevated above the level of the shoulders to prevent compression damage during an accident, which can lead to severe shoulder and spinal injuries.
  20. Marty Strode
    Marty Strode
    NHRA rules, shoulder belts will be mounted level to the shoulders, and up to 4" below. I mount them 4" below.
    Ned Ludd and Blues4U like this.
  21. DDDenny
    My best effort.
    19Eddy30 likes this.
  22. dreracecar
    dreracecar
    from so-cal
    show me a racing type harness that has a DOT rating before making a statement like that. Not saying that they will target you for a harness type system, but if they are writing you up for many infractions because you were acting a fool, they could write you up for not wearing a DOT seat belt even tho you had the harness on--- laws have strict interpretation, Dont like it, you are given the opportunity to fight it to court
  23. https://www.thedrive.com/guides-and-gear/want-to-put-a-racing-harness-in-your-car-read-this-first
    lot of the junk built here never came with belts from the OE anyway.
    I’m could care less about the seat belt ticket if it keeps me from launching thru the windshield.
    I’ve never seen someone get a ticket at a parking lot or track event.
    I have watched the cops do burnouts at some “cruise in”.
    They were also nice enough to let us help them test their radar guns a time or two.
  24. dreracecar
    dreracecar
    from so-cal
    If my shop installed a roll bar in Johnnys street car, and Johnny lost control on a wet curve going to fast, and got hurt or killed, who do you think the family is going to go after???
    Now I have bent many roll bars for people---its a service and not a product and they have to find a way to have it installed/welded. Some may not like my position on this, But its me who has to deal with your family when you are injured or dead
    Blues4U likes this.
  25. Friend of mine re-skins old NASCAR ch***is with old sheet metal
    Uses the vin for the tag.
    Cruises em on the street.
    Sounds fun
    Ned Ludd and Tman like this.
  26. squirrel
    I seem to recall that one of the guys on Drag Week kept his original 3 pt seat belt (in his off topic later model car) and used it on street drives, but used a 5 point racing harness at the drag strip.
    But all this talk about DOT approved seat belts, is kind of off topic, isn't it?
    Blues4U and mad mikey like this.
  27. dreracecar
    dreracecar
    from so-cal
    Looked into them, glorified OEM with standard buckles and not a 3" webbing latch and link or turnbuckle as most of us would call a racing harness
  28. Sure they are. Might not fit your rules but they fit some others
    We have harnesses in our school supported “race cars” that top out about 40mph. :)
    Lots of different forms of racing and automotive compe***ion.
    I had a racing harness in my first ever compe***ion built ride.
    A down hill beast built out of an ironing board. The safety harness was made from webbing from an old lawn chair.
    Bent nail mounting. Was perfectly legal by the sanctioning body (my dad) and worked great.
    We even tested it.
    The sanctioning body cl***ified the pipe that went from the floor to the roof in my bus as roll over protection.
    Factory lap belt = racing harness
    A helmet and radiator puke tank and I’m a race car driver.
  29. Rocky
    Rocky
    Classified Editor
    my 34 ran 9.57 at the HAMB drags ..........ok, ok. That was in the 8th mile. I built a 4 point roll bar that's bolted to the frame. It sits well back from my head. I use it because it looks cool and it should help in case of a roll-over accident. I never gave a thought about it's legality but I did take my insurance guy for a ride in it. He's a car guy and never said a word about the bar. I also use 3" race car lap belts with the flip-over latches. 34hambdrags19_2.jpg 34inside11_13.jpg
  30. When ya build em tight to the body and attach the B-posts and package tray area to em. it becomes a anti-coupe crack body stiffning device.
    Or a body wood retrofit.
    Tomato potato
    “Sir is that a roll bar”
    No officer, it’s designed to stiffen the body to prevent cracks and keep doors in alignment.
    Plus the x brace holds the spare tire
    Ned Ludd, X-cpe and seb fontana like this.
