Technical 40 ford, how low can I go with banjo rear end?
Discussion in 'Traditional Hot Rods' started by Busmania, Jan 11, 2023.
  1. Busmania
    Busmania
    from Denver
    I have searched and read just about every thread google can come up with but figure I need to ask as my specific info is not out there. I am looking to lower the car. The front I seem to have worked out (probably buying a posies kit). For the rear, I am confused as to how low (and as to HOW to get low) I can go while still using the banjo rear end with a driveshaft conversion. Help? Thank you!
    I'd rather not put in a new floating leaf spring axle but will consider it IF there is a rear end that fits well (same width left to right and center differential). Does this exist? I am not afraid of some fab work but don't want to modify axles and such.
  2. Nailhead Jason
    Nailhead Jason
    you can get the banjo as low as you want pretty much by using dropped rear spring and long rear shackles to drop it even more, but the long shackles really affect handling., but the big deal you will have is if you are making it an open drive, you will need to re-engineer the rear suspension as the torque tube locates the entire rear suspension. You could modify the original rear wishbones into ladder bars, and use them but don't use just the rear wishbones with out beefing them up, they will break.
    I removed the banjo from my 39, and installed an early bronco 9 inch, they are 58 inches wide, and i hung it with a set of ladder bars from R jays speed shop. I have detailed pics and process in my build thread below. I used the same rear spring i had on the banjo and spring hanger brackets on the rear that moved the shackle location up another inch for a little more drop. Here are some pictures of how mine sits it it was only about 1.5 inches higher with the banjo, that was entirely because of tire height and spring hanger differences on the rears.
    19A8558E-A05B-4456-8FA2-B2400C39AB66.jpeg D4367E4E-DDC8-463C-8047-2F67DF10EC7F.jpeg 5924917B-9F58-467D-BB0A-D61485BED69F.jpeg
    hfh, Okie Pete, theHIGHLANDER and 7 others like this.
  3. hotrodA
    hotrodA
    The cheapest and easiest way is dropped rear spring shackles. They come in several lengths.
    Then remove a couple leafs and dearch the rest.
    Presume that you talking about that 40 Standard coupe in your avatar (not the van) I
    Are you leaving it stock torque tube?
    Late model swap to parallel leafs is bolt in but requires a lot more info, choices, parts and $$
    This will help in your search. Also search HAMB for 40 rear swaps. There’s a ton of info.
    My coupe has a Maverick, my pickup has a Bronco. Both on Ch***is Engineering parts
    There are several other quality suppliers.
  4. jimgoetz
    jimgoetz
    My 47 was lowered with a couple of leaves removed and long home made shackles. Had kind of funky tube shock mounts too. I changed to parallel leave springs with a TCI kit and lowered it with 3 in. blocks keeping the torque tube banjo rear. It sits about the same but the handling and ride is very much improved. The front has a dropped axle and reverse eye spring.
    Packrat, Okie Pete and Nailhead Jason like this.
  5. Busmania
    Busmania
    from Denver
    Can I keep the torque tube if I drop it about 4-6” or do I need to conver to open style with the speedway conversion (but keeping banjo rear end)? Does the crossmember that the torque tube sits on have to be cut so it can drop down?
  6. alchemy
    alchemy
    Why convert to open drive? Cause someone said it was cool?
    The torque tube design is perfect. No need to change unless you are using a late model transmission. And if you are doing that, I’d recommend using a modern 9” rearend.
  7. Tim
    Tim
    from KCMO
    The torque tube and an open driveshaft occupy the same space. You’re not going to gain any clearance changing it.
    as already mentioned you can get that car 4-6 lower with a spring and shackle change. If you wanted to put in more effort and lose some trunk space you could flatten the rear cross member and damn near put it on the ground
    Okie Pete likes this.
  8. Busmania
    Busmania
    from Denver
    No! I'd rather not convert to open drive. I actually asked because someone told me I HAD to convert to open drive if I lower more than about 2" which I plan to do.
  9. Should be able to do this
    hfh, Okie Pete, rattlecanrods and 7 others like this.
  10. Busmania
    Busmania
    from Denver
    Anthony that looks sweet. Any specs? Pm me if you'd rather not share? Tire size? Suspension? Frame mods etc?
  11. Last edited: Jan 11, 2023
  12. okiedokie
    okiedokie
    from Ok
    Local guy used parallel leafs with the banjo rear in his 39, sets pretty low. Don’t know who makes the setup but it was a “kit” type deal.
    jimgoetz likes this.
  13. alchemy
    alchemy
    I can't think of any good reason to keep a banjo rear if you need to switch to parallel springs. Doing it for looks and tradition? Don't the parallel springs spoil that? A banjo rear is too expensive to rebuild if you aren't going to do the whole traditional scenario.
    Whoever says you need to use an open driveshaft on a banjo rear just because you lower the thing is wrong. Maybe a guy ought to use some kind of seal at the rear of the torquetube, but removing the torquetube is dumb and costly. The torquetube rearend has perfect geometry, no bind at any height, and is stronger than any ladder bars unless you are building some hundred pounders.
    If you want a low in the rear 40 you can flatten out the rear spring and get rather low. If you want extreme you're might want to flatten the rear crossmember a couple inches. These will probably require a C notch over the axle. If you want to "lay frame" you could Z the rear of the frame, but not needed for a normal car.
  14. Dan Hay
    Dan Hay
    17707740-5ED1-4CC2-B505-33335DB4363B.jpeg Here’s my old 40 sedan I built. It had a banjo and torque tube. It was pretty low in the rear, but the huge 750s gave it some rake. The spring was a posies reverse eye with a few leaves removed. Stock shackles, no long ones needed. Frame was not C’d and it didn’t bottom out, but I only carried kids back there not any weight really. I used a drake sway bar kit for the rear and the car rode and drove as about as good as an early Ford can.
    I agree with what’s been said, either stick with the entire banjo and torque tube or do parallel leaves with a 8.8 or 9” or?
  15. Busmania
    Busmania
    from Denver
    thank you! That is good info! I really would rather keep the banjo and torque tube and honestly got a little discouraged when told I’d have to make changes to it so I’m back to being excited. Haha. I have no need to go to parallel leaf springs.
    Dan, good info! Any idea on front tire size in that photo?
  16. Dan Hay
    Dan Hay
    The tires on that car were 500/525 16’s on the front, and 750 16s on the rear.
    if I had to do it again I’d go with 550 16s on the front. Two reasons: I think the slightly bigger tire would fill the wheel opening better, and the 500/525s have such a narrow contact patch the the front brakes would lock up really easily, and they were sketchy on wet pavement. I would be interested to see how much better the 550s would perform since they have a wider contact patch.
    I looked it up, 550s have a 4.25” tread width, 500/525s have 3.75” tread width. That’s a full inch more grip in total over both fronts. That’s gotta help.
    Tim likes this.
  17. Dan Hay
    Dan Hay
    Also, I used a 4” narrower axle on the front of that car to get the tires tucked in so it would sit low. That involves a narrower spring, splitting the wishbones and then heating/bending the spring perches on the wishbones back to parallel. I have a build thread on that car. Search for “the Varmit” and you’ll find it.
    anthony myrick likes this.
  18. Hold tight to your choice and decision there. Parallel springs bring their own issues to deal with.
  19. Dan Hay
    Dan Hay
    4D45A6D4-62C6-49A7-9FAF-0FDDA12E11B2.jpeg For reference, I didn’t build this car, but it was mechanically identical to the patina 40 I built and posted above. SBC mated to the original 39 trans and banjo rear ended. All stock except lowering spring and tube shocks in the rear. The front had a Nostalgia SIDS dropped axle, Posies spring, Lincoln brakes, and Pete&Jakes Sway bar. I wanted to lower it more but I would have had to buy smaller tires and the tires on it were near new. Sold it in October to another Hamber locally.
  20. I’ve wondered how common modifying or flattening the rear x-member was. Seen a few done here.
    as far as the torque tube. If not using a lot of HP and or happy with the stock trans, a torque tube seems like an easy set up to lower. These ch***is look like a very straight forward setup to lower.
    I’ve been curious about these ch***is hoping to build one eventually.
  21. Dan Hay
    Dan Hay
    There is a lot of room above the rear crossmember to the floor so flattening the crossmember is an option if you want a taildragger, but a bolt in spring will get it plenty low so it’s not with the extra work on a hot rod. Plus, stock springs are really stiff so you pick up ride quality with a lowering spring usually.
  22. jimgoetz
    jimgoetz
    The only reason I went to parallel springs was because the original lowered set up was kind of hacked up. No sway bar, bad shock set up with shocks blown out, ect. By using the kit from TCI I solved all of my problems at one time and got new shocks and proper mounts too.
    joel and Dan Hay like this.
  23. 100% Matt
    100% Matt
    joel and Nailhead Jason like this.
  24. Stan Back
    Stan Back
    How low can you go with a banjo rear end?
    The lowest I've seen is 4.44 to 1.
    dmar836, tippa77, Tim and 2 others like this.
  25. hotrodA
    hotrodA
    The previous owner of my pickup thought that this was a good idea!
    DO NOT, DO NOT try this.
    Look past the rear late model Ford p/u frame clip and springs.
    Look past the absence of shackles.
    Rather......
    Look AT the still in use torque tube.
    Look AT the different pivot points of the front spring eyes versus the front of the torque tube versus the solid **** welded wishbones.
    Not at all how a triangulated torque tube rear end is supposed to work.
    He definitely DID NOT know about the HAMB.
  26. theHIGHLANDER
    theHIGHLANDER
    Short of doing a limited use taildragger show car there is such a thing as too low on these. I must be a **** for reals. I ended up RAISING mine. It had long shackles and reverse eye spring. It also had less than 2 fingers clearance from the axle tube to the bump stops. I live in Michigan. Our roads really **** in some places. I put stock shackles back on front and rear. I know I hit the stance just right AND I have bump stop room. These cars lose a little ***y when they're too low. This is purely my opinion but I think they need some space between the running boards and the road and when they're too low the roof looks too high. To me, to my eye. I apologize in advance for all those who might now say "...**** I never noticed that before but..."
    warbird1, dmar836, tippa77 and 2 others like this.
  27. Tail draggers need to drag
    VANDENPLAS likes this.
  28. [​IMG]
    In order for this to work it needs Shackles on both ends of the leaf springs. It actually was done in production on different brands. That lowering block is my #2 bark about all bolt on leaf spring "KITS" for the early Fords. Piss poor engineering Period.
    Bandit Billy and rattlecanrods like this.
  29. If you want to do leaf springs on early Fords do this and s**** the Kit Brackets. Then you don't need lowering blocks to get a nice stance.
    Bandit Billy, Okie Pete and Russco like this.
  30. neilswheels
    neilswheels
    from England
    I originally pancacked my rear crossmember, dropped it a treat, but the floor needed clearancing. I made a jig to cut it uop and keep it all square, I have heard of other people pancaking the cross member in the car.
    I wentwith the crossmember to keep the stock spring and shackles. Long shackles allow the body to move side to side over the axle, so a panhard is a good idea. The rear crossmember was the only mod I did to get to sit like this, stock spring and shackles.
    Frtpont was a posie 'in da weeds' kit woth a superbell axle and split bones. You dont need to split the bones if you use a 36 wishbone, but theres loads of info on here
