Technical How do you remove baby moon caps?
Discussion in 'The Hokey Ass Message Board' started by '29 Gizmo, Jan 12, 2023.
  1. '29 Gizmo
    '29 Gizmo
    from UK
    I have got 7.5" baby moon caps on smoothie steel wheels. How the hell do you get them off without chipping the paint on the wheel. There is no gap between the cap and the wheel to get a prybar in and its even slightly recessed so there is no lip to get hold of.
    Only other options are some kind of suction cup or strong magnets.
    Anyone else got ant tricks?
  2. 302GMC
    302GMC
    from Idaho
    Plumber's friend ...
  3. Paul
    Paul
    Editor
    google hub cap tool
    lots of versions available
    chryslerfan55 and Atwater Mike like this.
  4. BDUB77
    BDUB77
    I've had good luck with plastic trim tools like above
  5. ramblin dan
    ramblin dan
    Don't have picture of it but I use a plastic drywall mud spreader. They come in all width sizes so I use a narrow one with a handle.
    clem likes this.
  6. Mr48chev
    Hubcap bar (older than I am) with duct tape on it.
    Those plastic trim tools from HF are handy for alot of things though and should work.
    This isn't the one I mentioned above but I have used this style in every shop I ever worked in and some padding in the right spots will help keep from scratching the wheel. Just don't use it to install the baby moon. Screenshot (891).png
  7. '29 Gizmo
    '29 Gizmo
    from UK
    Tried everything, apart from the plastic trim tool. The problem is the way they fit the wheel. No gap and nothing to get hold of so conventional hab cap tools dont work.
  8. silent rick
    silent rick
    i've used those cheap plastic kitchen cake frosting spreaders, slips behind the hubcap, protects the painted surface and then can pry off with a screwdriver. or i've used bondo spreaders the same way.
  9. RockyMtnWay
    RockyMtnWay
    Cheap, easy, and what’s not to like.
    As they crack/chip, I just shave em down.
    clem, chryslerfan55 and VANDENPLAS like this.
  10. Anderson
    Anderson
    exactly these. They take some wiggling but work great.
    chryslerfan55, Cosmo49, egads and 6 others like this.
  11. catdad49
    catdad49
    I use the ones above, it usually takes at least two at different locations.
    Joe Blow likes this.
  12. proartguy
    proartguy
    from Sparks, NV
    For the tightest ones these gl*** tools work great, even better when the edge is sharpened.
  13. Bandit Billy
    Bandit Billy
    I was parked next to a little roadster at a car show last summer and while I was kicked back in my chair, working on my tan and a bottle of grandpas special coke (as we like to call it), I noticed the 10" wide, deep reversed, painted steel wheels with baby moons. I asked him how the hell he gets those off and he showed me a plastic tool that he made sort of like the 3rd one from the left.
    chryslerfan55 and Joe Blow like this.
  14. Joe Blow
    Joe Blow
    Same as above.
    This...with a couple of raps with this.....using the 90 degree end.
  15. '29 Gizmo
    '29 Gizmo
    from UK
    Thats great.. thanks guys some stuff to try out.
  16. 327Eric
    327Eric
    I took a flat blade screwdriver, heated the tip and bent it at a 90
  17. olscrounger
    olscrounger
    Plastic tool shown and tap with hammer--works great
    Cosmo49 and Joe Blow like this.
  18. rockable
    rockable
    Use the plastic tools suggested and try different spots around the hub cap until you find a place you can get the thin part started. Do not try to hammer the tool into a space it doesn't want to go or you m will be buying another hub cap. Ask me how I know. :D
    catdad49 and Joe Blow like this.
  19. 57 HEAP
    57 HEAP
  20. sheet metal screw and a slide hammer? :D
  21. Find a road with a railroad crossing and hit at high speed, pretty much guaranteed at least three come off :D
    You are very welcome ... as for all this "non marring polyurethane coated surgical tooling" .... that AIN'T old school my friend ;)
    Cosmo49 likes this.
  22. Budget36
    Budget36
    The station I worked (so many years ago) had a very similar tool.
    Worked great.
  23. Rickybop
    Rickybop
    Drive by my house real fast a couple times. Lay on the horn when you do and I'll come out and pick 'em up for you.
  24. wicarnut
    wicarnut
    THEN, put them back on without denting them, I had different sets years ago, Off pretty easy IMO, On, very carefully.
    WalkerMD likes this.
  25. BamaMav
    BamaMav
    from Berry, AL
    Drill a hole through the wheel and punch it off from the back side. Probably have to drill the brake drum and backing plate to get through to the wheel.
    After you break about 10 drill bits just get some dynamite. It works every time!
    Just BSing you. Hope you get them off before you have a blowout on the side of the road.
  26. badshifter
    badshifter
    Some of the old caps (VW for sure) had a small hole at the edge where it contacts the wheel. You put a hook into that hole and pulled them off. I drilled the edge on my 40 ford caps and that’s how I remove them. No prying, no damage, no issues. You can’t really see the hole when on the rim.
    Rickybop, LOST ANGEL, tommyd and 7 others like this.
  27. blue 49
    blue 49
    from Iowa
    X-cpe likes this.
  28. WalkerMD
    WalkerMD
    I was gonna say drill a small hole on the edge and put compressed air behind it. Oughta pop right off.
    '28phonebooth likes this.
  29. 57Fury440
    57Fury440
    I did the same thing 327Eric did. The only difference is I ground the tip really thin on my grinder first. My wheels are chrome, so I put some tape near the end to prevent scratches. It worked for me. I used a small rubber mallet to force it under the hubcap.
    catdad49 likes this.
  30. '29 Gizmo
    '29 Gizmo
    from UK
    Awesome... did just that, popped right off. No paint damage. Thanks guys.
    Joe Blow and PhilA like this.
