Hot Rods Model A 32 frame with stock grille
Discussion in 'The Hokey Ass Message Board' started by 3030, Jan 12, 2023.
  1. 3030
    3030
    Building 30 roadster on a 32 frame want to use stock A shell to be different, problem I'm having radiator is about 2 inches to high, would like to use a quality copper radiator. Anyone done this. Plus plan on running the hood so will be extending that.
  2. 31Apickup
    31Apickup
    I had Br***works build me a 32 style radiator chopped 2” for my coupe on 32 frame. If using a Model A shell you may need notch it on the side where it sits over the front crossmember.
    Tow Truck Tom likes this.
  3. fordf1trucknut
    fordf1trucknut
    I chopped my radiator and cut the sides of my grill shell a little but but can't remember exactly how much but it was less than 2 inches in my case but that was probally because I also moved the crossmembers a bit to make the stock hood fit.
    310909042_660967202262733_1587591474249863977_n.jpg 20220514_075355.jpg IMG_9878.jpg 20220514_183947.jpg
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    That is the plan I have for mine.
    Looks just right
    Kudos on the choice.
    The Deuce shell is a work of art, however,,, to my jaded eyes an A needs to look like an A
    El Mirage Garage likes this.
  5. 3030
    3030
    Thanks for the responses, so nobody makes a radiator that's chopped that fits a model a shell like they do a 32
  6. 31Apickup
    31Apickup
    Br***works will build whatever you want.
  7. 3030
    3030
  8. I dont have one to measure,but will a 29 radiator fit a 30 shell ? if its not too wide it might work height wise.
  9. Malcolm
    Malcolm
    from Nebraska
  10. Just Gary
    Just Gary
    I had the same problem with my '28 sedan on a '32 frame with a '28 shell.
    I trimmed the shell's lower corners, then dropped it 1.5" between the frame rails. After measuring carefully, I used one of Speedway's 4.5" chopped 1932 Lo-Boy aluminum radiators #9173425. It fits perfectly inside the '28 shell:). They have other sizes with measurements as well. It's not copper, but this might help.
    4-1/2 Inch Chopped 1932 Lo-Boy Aluminum Radiator (speedwaymotors.com)
    Lots more pictures & explanation here:
    Introducing my Fuel Coupe-styled Tudor | Page 9 | The H.A.M.B. (jalopyjournal.com)
  11. brett4christ
    brett4christ
    It' s not copper, but Champion Cooling makes a nice aluminum radiator P#3132FH, with the FH being flathead.
    You didn't mention which engine you're using, but they make this radiator in several configurations.
    Reason I even know is, I bought the above radiator before I realized I need the 3031FH which is 2 inches TALLER than the one above.
    Just Gary likes this.
  12. 3030
    3030
    Its gonna have a little 283 Chevy
  13. 3030
    3030
  14. the_brassworks
    the_brassworks
  15. Joe Blow
    Joe Blow
  16. Straight Axle Guy
    Straight Axle Guy
    A 283 will be sweet in that roadster!
