Hot Rods 37 Ford firewall repair (replacement sheet metal?)
Discussion in 'The Hokey Ass Message Board' started by no55mad, Jan 13, 2023.
  1. no55mad
    no55mad
    Does anyone make a partial firewall? Something to accommodate a later model motor. Trying to avoid cutting out the original and doing a complete replacement. The original has already been modified and the toeboard area needs to be replaced.
  2. vtwhead
    vtwhead
    What does it look like now? Can you post a pic of it?
  3. no55mad
    no55mad
    Will try and get a pic. This body was a drag car at one time with the motor moved back. The original firewall comes straight down from the cowl. Where the firewall came forward for the toeboard area, that was removed.
  4. nobby
    nobby
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
  6. Stu D Baker
    Stu D Baker
    from Illinois
    ^^^Isn't it in the ***le?
  7. Stu D Baker
    Stu D Baker
    from Illinois
  8. no55mad
    no55mad
    The battery box is gone. Actually what is there now is pretty much like the Yogi firewall posted above. Wanted to come out into the engine bay more to get leg and foot room back. Have a small block so don't need to move the firewall back as far as the Yogi big block unit. Probably need to test the sheetmetal/welding skills and start fabrication.
  9. RICH B
    RICH B
    A carefully done homebrew addition to the remaining upper section of the original firewall should look better than a full aftermarket street rod firewall.
