Hot Rods Survivor ‘33 Ford 5W Hot Rod
Discussion in 'The Hokey Ass Message Board' started by alfin32, Aug 11, 2021.
  1. Crkrjac
    Crkrjac
    from Waxhaw NC
    Thank you!
    Joe Blow likes this.
  2. Crkrjac
    Crkrjac
    from Waxhaw NC
    Thank you!
  3. alfin32
    alfin32
    from Essex, Ma.
    95E947BE-808C-47C7-A223-4BFEE656DDF4.jpeg C4C0B184-2909-464D-89B1-B1880D3BB64D.jpeg BC2645FA-B8A6-428E-9839-7E8E6DD38B5B.jpeg Found this Special Construction registration that fell out from behind the package tray while cleaning out the interior. It now makes sense why the ch***is number didn’t match anything I’d ever seen before. Perhaps he bought a car from a junkyard with no ***le, and Ca. issued him a new number? The new number is stamped in the rail directly below a welded bead that probably was the original Ford number. Kinda cool history!
    Just Gary, chryslerfan55 and Crkrjac like this.
  4. alfin32
    alfin32
    from Essex, Ma.
  5. alfin32
    alfin32
    from Essex, Ma.
    So, it appears that the stock ‘33 rear axle ratio may be a 4:11, and coupled with the 283, gives me a 55mph top speed! What was going to be a quick and dirty engine swap has turned into one hiccup after another. Welcome to Hot Rodding 101.
    WC145, chryslerfan55, rod1 and 2 others like this.
  6. wheeltramp brian
    wheeltramp brian
    I'm no expert but those 283's Will Cruise all day at 3-3500
    Nailhead Jason and chryslerfan55 like this.
  7. alfin32
    alfin32
    from Essex, Ma.
    While test driving, Eli noticed that the interior was filling up with fumes, and realized that a 283 should have a road draft tube at the back of the block. This had been plugged on this engine, so he found a kit from Cl***ic Industries, that routes it to the carb base. Problem solved. A22A54A3-AC25-4F84-9A6C-3C9F6C27D915.jpeg A7525D6C-35E4-4DC6-8239-FBB42206E183.jpeg
  8. slug
    slug
    With the height of your rear tires a 4.11 should be no problem for a 283.
  9. slug
    slug
    Absolutely a perfect build. When you get tired of the hicups give me a call!
  10. alfin32
    alfin32
    from Essex, Ma.
    1C0B1E17-D6CC-4514-AE8D-40DED7BD1986.jpeg 52FBF3C7-CF7C-4652-84E8-C19C03C59321.jpeg B80E474F-49F6-4665-9391-3C1AD71AC65B.jpeg 113B9D8D-41BC-43DC-933D-43786295A897.jpeg C70F0012-3BD7-446F-8C85-133886FF38F4.jpeg Going to move the plate to the center, below the deck lid. 1352BD49-0EC1-464B-9A46-1E2D2C07F136.jpeg
    Stogy, Joe Blow, 57tailgater and 8 others like this.
  11. 57tailgater
    57tailgater
    from Georgia
    This is way cool. Since you put the PVC line in from the old draft tube port, where does it get intake/breather air for that and and where is your oil fill? I would have ***umed a tube on the front of the intake but I don't see one.
  12. alfin32
    alfin32
    from Essex, Ma.
    Great question, and there is a breather / oil fill tube at the front of the engine.
    We had to shorten it, and it sits alongside and just below the generator.
    Stogy and Joe Blow like this.
  13. DDDenny
    Two things Al.
    Is the oil baffle in the valley, and I'm thinking a vented oil fill cap might not allow enough air flow through the engine.
    Stogy likes this.
  14. alfin32
    alfin32
    from Essex, Ma.
    I don’t know, Denny, but before we put the pvc in-line, the interior filled with smoke.
    It does not do that now. It’s pretty low performance.
    More pics tomorrow.
    Stogy likes this.
  15. Fogger
    Fogger
    I have two cars powered by '57 283 engines. Both have pcv valves between the hole in the rear of the block and the carburetor base. Both have the canister in the engine valley and both have vented breathers on the oil fill tube. There is no reason why it shouldn't work on the '33. IMG_0076.jpg
    Stogy likes this.
  16. alfin32
    alfin32
    from Essex, Ma.
  17. Rocky
    Rocky
    Classified Editor
    too cool!
    Stogy likes this.
  18. 57tailgater
    57tailgater
    from Georgia
    Yup - tucked away for sure. Thanks for the info and pics. This is just too cool with the "originality" of the parts being used. I am thinking the oil baffle under the intake in combination with the stock style oil fill/breather should be work together but not 100% sure. I plan on doing a similar thing with a PVC on my 283. Fumes going out the exhaust vs. a road draft tube. Many years ago I was fortunate to find an original draft tube fitting that goes into the rear block hole so I just need to get a PVC fitting and some hosing. Keep up the great work! Great thread!!
    Stogy likes this.
  19. alfin32
    alfin32
    from Essex, Ma.
    It starts instantly, and will sit and idle for 1/2 hour without overheating.
    Stogy likes this.
