Projects 1946 Fordor build update 14-1-2023 coupe conversion
Discussion in 'Traditional Customs' started by dutchrod, Jan 27, 2021.
  1. dutchrod
    dutchrod
    My model A coupester is a fun little car but I also want to be able to take my family on a trip so the search was for a family ride , vintage of course !
    I found a 1946 fordor that needed some love.
    It was a older restoration but I had some fire damage on the outside.
    Plans are : Get the flatty running smooth ,Paint , lowered , sun visor and drive !
    Big changes maybe later on.
    Outback, Rawrench, Just Gary and 6 others like this.
  2. dutchrod
    dutchrod
    Interior is nice and the heat did not affect the upholstery
    Outback, etxhfeg, Rawrench and 4 others like this.
  3. Nice ride! You know which side to park closest to the wall, right?
    Make sure it runs, drives and stops, lower it a bit, and away you go. A little paint for now to hide the boo-boo.
    dutchrod likes this.
  4. dutchrod
    dutchrod
    Flatty runs a little raw but after changing points for electronic , new spark plugs and battery it is running real nice.
    camcrusher likes this.
  5. Maybe dual exhaust, too?
  6. HOTRODPRIMER
    HOTRODPRIMER
    Great car to haul the family. HRP
  7. dutchrod
    dutchrod
    Brakes where not working but to my surprise all four corners were done.
    I checked the master and that was the problem , I even needed heat to take the cap off to find out it was full off rust.
    Changed the master out for a new one and the brakes are real good now.
    Outback and oliver westlund like this.
  8. dutchrod
    dutchrod
    Yes , definitely need more sound !
  9. dutchrod
    dutchrod
    At the ,moment the I'm doing body work and hope to paint it soon.
  10. dutchrod
    dutchrod
    I got a spare axle laying in my shop for a long time and it happened to be the same as the 46.
    Collecting parts now to build a dropping jig, never did one but there must a first time for everything.
    This will be be a side project , paint is first.
  11. dutchrod
    dutchrod
    Test fitted the repro fulton visor , had to do some mods to make it work but will be good in the end.
    154969750_1400081367001910_8056931605071605468_n.jpg 156055791_1400081373668576_3801883474110016437_n.jpg
    Okie Pete likes this.
  12. dutchrod
    dutchrod
    Bought some fender skirts , looks nice but need some tweaking to get a nice fit.
    I have to wait till the rear fenders are back on the car to have the correct shape.
    155811488_1400045683672145_1898735165039675664_n.jpg 155577050_1400045693672144_5088445193397707773_n.jpg
    Okie Pete, Just Gary and Tim like this.
  13. dutchrod
    dutchrod
    Painted the roof metal flake for the first time , need more layers but run out off clear.
    Ordered some more so hope to finish next week.
    Base coat gold/ yellow to let it real shine.
    Need more layers to get the flakes even but its a start.
    The rest of the car will be gloss black.
    Okie Pete, Smiffy, williebill and 2 others like this.
  14. dutchrod
    dutchrod
    Took it one step further and lace painted the roof.
    Tomorow clear and then finally the rest of the car in black, season is coming.
    Outback, Jrs50, porkshop and 11 others like this.
  15. footbrake
    footbrake
    Did you take the heater out from under the dash?
  16. brady1929
    brady1929
    Very cool. Love the paint.
  17. dutchrod
    dutchrod
    I bought it like this.
  18. Jim Spin
    Jim Spin
    Same problem Roadster is fun but rain storms are tough to get caught in. It happens daily here in sunny. FLA. HA. HA. Paint looks great. will be really cool cruiser when done.
  19. dutchrod
    dutchrod
    Painted de body gloss black , now****embly time.
    Outback, Okie Pete and camcrusher like this.
  20. Tim
    Tim
    from KCMO
    Dang looking slick !
  21. bondojunkie
    bondojunkie
  22. dutchrod
    dutchrod
    As it is for now
  23. dutchrod
    dutchrod
    Since I love a coupe more then a fordor I started to search for a coupe roof to convert the fordor into a coupe.
    I found one and also a decklid in bad shape.
  24. dutchrod
    dutchrod
    After al lot of measuring and planning it was time to start cutting ,no way back from her I guess.
  25. dutchrod
    dutchrod
    The coupe had some sort of accident in the past so not all parts are straight.
    I used the lower part of the fordor decklid and the upper part of the coupe decklid, still some hammer and dolly work to sort this out.
  26. dutchrod
    dutchrod
    Tacked the upper quarter pieces to the body ,I cut of the the corner pieces so I can rework them to fit.
    Start to look a bit like a coupe , still lots off tweaking to get the lines correct.
    Tomorrow more work on the decklid and quarters.
    bschwoeble, Outback, EVL401 and 13 others like this.
  27. Tim
    Tim
    from KCMO
  28. goldmountain
    goldmountain
    Nice way of fixing the lace painted top.
  29. Squablow
    Squablow
    I LOVE stuff like this, looking forward to seeing more, and subscribed! Can't wait to see how it turns out.
    The remaining section of coupe trunklid you ended up keeping to use, looks just like another 4 door sedan trunklid, just slid forward. I always wondered if you could make a coupe trunklid out of a couple of sedan ones.
    texasred likes this.
  30. texasred
    texasred
    from Houston
    One thing for sure, you got some ball's
    Outback and rod1 like this.
