Technical Strange etching from rust on floorboard?
Discussion in 'The Hokey Ass Message Board' started by alwayzarat, Jan 16, 2023.
  1. alwayzarat
    alwayzarat
    I wondered if anyone has ever encountered this? Putting in some new carpet and wanted to check the floor boards and seal any minor rust. The pans looked really good, but those lines you see are actually “etched” into the metal. Just deep enough to maybe catch your fingernail. I went ahead and sealed them with por-15 but I’m puzzled how those deep lines came to be? When I pulled out the old sound deadening and insulation it was damp on that side. When I bought this old pickup the heater core was unhooked. I pressure tested it and it leaked, so I put a new one in. My guesses are…
    #1) Maybe some type of acid like reaction between the old glue and moisture/antifreeze?
    #2) The original pan didn’t have a uniform finish way back when it was built?
    E2E2EB07-C895-45BE-8E96-A0F2ED0C4210.jpeg 867058B0-8C26-4A02-893F-F59343F1C7D0.jpeg 299AC191-2557-4700-970B-06C519221303.jpeg 0608CE16-96EB-418E-8826-65D148AC237B.jpeg
  2. rusty rocket
    rusty rocket
    The 26 T I’m building has some metal that’s etched lightly. It looks like it came off the line like that though.
  3. Looks cool
    egads and VANDENPLAS like this.
  4. alchemy
    alchemy
    The rust worms were crawling around under the carpet.
  5. Mine has a face rusted in the side of it
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s some back seat boogie :eek:
  7. alwayzarat
    alwayzarat
    That really does look like a face!
    LOST ANGEL likes this.
  8. Call a priest!!!
    But for the original OP my guess would be battery acid or something of the like .
    lots of dumb stuff can happen to an old car over the years .
  9. Squablow
    Squablow
    Wow. At first glance it looks like you peeled a wet sheet of plastic off of it. But damn, that is really eaten in there really deep, and more shocking is it wasn't a ball of brown rust, it looks damn clean.
    I don't know what's up with that.
  10. Jack Rice
    Jack Rice
    Like @rusty rocket said, kinda looks like it was always there. Strange.
  11. alwayzarat
    alwayzarat
    One of my other buddies said the same thing.
    VANDENPLAS likes this.
  12. Bandit Billy
    Bandit Billy
    Anthony, is that truck from Turin, Italy by any chance?
  13. Nope.
    Postal Service somewhere in Florida
  14. alwayzarat
    alwayzarat
    I kinda thought that too since the pan is in such good shape. Seems odd to me it would “rust” just along those lines.
  15. BJR
    BJR
    I would say it's from salt water, since you live by the ocean, or if it was ever up north from road salt.
  16. seb fontana
    seb fontana
    from ct
    Spookie! Bad ground.:rolleyes:
  17. alwayzarat
    alwayzarat
    That’s a good thought, it spent its whole life in Oklahoma. I think they get snow there occasionally.
  18. squirrel
    I expect the insulation was in contact everywhere except where the rust happened....so moisture must have been able to only get to where it was not in contact.....
  19. KenC
    KenC
    that, and maybe related to a 'string' of adhesive used to hold the insulation in place.
  20. Lloyd's paint & glass
    What year is the truck? Did it possibly have sound deadening material on it that cracked in that pattern, and the pattern is the area that wasn't protected from moisture?
  21. NoelC
    NoelC
    My guess it had the old tar type that had dried and cracked. It left the exposed cracks that rusted. As mentioned you don't know the history but someone could have tried to chemically clean it, found that a fail, in removing the rust, or offer a solution to the resulting mess, then went further removing the crap and the tar stuff. Looking you can see grind scratches.
    But so what. What you have to ask yourself is what are you going to do about it.
  22. alwayzarat
    alwayzarat
    I think that might be it.
    Jeraboa likes this.
  23. alwayzarat
    alwayzarat
    I thought this too definitely.
  24. alwayzarat
    alwayzarat
    I think so, it had like the old style insulation and then over that was a black almost plastic feeling layer that I’m sure was just dried out.
    Jeraboa likes this.
  25. alwayzarat
    alwayzarat
    Yes, the original stuff was still intact when I took it out last night. The lines aren’t deep, just enough to catch your thumbnail. But the truck sat undisturbed for 20 years. So all things considered it’s in amazing shape. I don’t think it has any effect on the structural rigidity of the floor. I’d just never seen anything like that in all the old stuff I’ve messed with. I mean it’s under the carpet, but I think I’ll put some seam sealer in those lines just to even it out.
  26. Gofannon
    Gofannon
    Is that a road map of Hazard County?
  27. lippy
    lippy
    from Ks
    I'm sorry I would have to skim coat that with some filler and block it then use some direct to metal Evercoat 4+1 polyester primer and block it with 150 then apply another coat of primer and wet block it with 400. and paint it. Then 4 coats of base, 3 or 4 coats of clear, 1500 wet and buff it. Lippy
  28. outagas1961
    outagas1961
    possibly cracks in the sound deadening concentrated the liquid to form those lines?
    Algoma56 likes this.
  29. alwayzarat
    alwayzarat
    You never know what them Duke boys are up to? Hahaha!
    Lloyd's paint & glass likes this.
  30. Squablow
    Squablow
    Road salt wouldn't do that. Road salt would rot the underside out long before it would etch grooves into the top.
