Technical Strange etching from rust on floorboard?
Discussion in 'The Hokey Ass Message Board' started by alwayzarat, Jan 16, 2023.
  1. alwayzarat
    alwayzarat
    That seems to be the prevailing theory. It isn’t that bad though so maybe happened long time ago and issue was resolved or happened more recently and didn’t get that bad.
  2. alwayzarat
    alwayzarat
    Ahhh true, didn’t think of that. Thanks underside is perfect.
  3. Fortunateson
    Fortunateson
    Like the last few responses. But in any case I think it looks cool like the cracks in a frozen lake.
  4. alwayzarat
    alwayzarat
    I’m almost this obsessive haha! It’s a patina style truck so it’s not too big of a deal I don’t think. Just wanted to try and figure out the why and we have some pretty good theories now.
  5. Reminded me of my aunt’s living room. She had my uncle put that marbled mirror stuff on a couple walls in the living room after a visit to Graceland.
    I’d would have wire brushed it and applied Penetrol. Then used clear floor mats in honor of my aunt and Elvis
    lippy likes this.
  6. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Maybe it was a flood car.
    Maybe the ***embler took ill,That day
  7. lippy
    lippy
    from Ks
    If you get the floor nice enough you could leave the carpet out and just wear your new socks. :D
    NoSurf likes this.
  8. Joe Blow
    Joe Blow
    What's the age of the truck? Beginnings of varicose veins......
    Bandit Billy and theHIGHLANDER like this.
  9. alwayzarat
    alwayzarat
    That is funny, and also a good idea haha! Penetrol!
    anthony myrick likes this.
  10. dirt car
    dirt car
    from nebraska
    Flagstone floors..... get in contact with William Shatner a good episode for his "Weird or What" program.
  11. jerry rigged
    jerry rigged
    THAT'S what you get from hanging out in the Twilight Zone! Creepy!!
  12. Squablow
    Squablow
    The cracked insulation pad makes sense for the pattern, but I do wonder what it was that ate the steel away but didn't make it all pitted. If it was a farm truck, lots of chemicals get used on farms/in barns that could get spilled or tracked in with someone's feet. Who knows.
    That floor shape looks like a 60's Chevy/GMC to me.
  13. gene-koning
    gene-koning
    Either a cracked insulation pad, or one with trapped air pockets formed in the lines. The sticky stuff would have protected the metal it was stuck to, but where the cracks or air pockets were, the metal was not protected. If the heater core leaked, the coolant could have ran down the firewall and into the cracks/air pockets causing the rust lines you see.
    For the record, most rust belt rusted out floorboards were rusted out from inside of the car or truck. People would get in the vehicle with salt mixed snow on their boots or shoes, the snow would melt into the carpet, and the jute backing under the carpet would soak up that sal****er mix and hold the wet mix against the floor pan for as long as 2 weeks after the event. The only places the floor would rust out from the bottom up would be places the salt water was held against the floor and couldn't drop or run off. I spent 30 years replacing rusted out floorboards, 90% rusted from the top (inside the vehicle) down.
  14. gimpyshotrods
    gimpyshotrods
  15. alwayzarat
    alwayzarat
    That makes a lot of sense. Probably the best explantation on floor board issues we’ve gotten. It’s just weird to me that it wasn’t worse.
  16. alwayzarat
    alwayzarat
    I thought about that too. It was weird though that the original carpet was in such good shape and the seat on the p***enger side was near perfect. It’s a gm floor out of a c10
  17. theHIGHLANDER
    theHIGHLANDER
    I can't believe you covered it up. Now nobody will ever see it! You coulda charged .25c to ppl at shows, a legit Ripley's "Believe It Or Not" display down the drain.
    Joe Blow and VANDENPLAS like this.
  18. jimmy six
    jimmy six
    I’m guessing the judges at your car shows have different expectations than any I’ve ever been. However I don’t own or build AMBR or Riddler style vehicles.
