Projects 1946 Fordor build update 14-1-2023 coupe conversion
Discussion in 'Traditional Customs' started by dutchrod, Jan 27, 2021.
  1. dutchrod
    dutchrod
    Corners are in , next will be the inner structure and then try to fix the decklid.
    porkshop, EVL401, Okie Pete and 3 others like this.
  2. panhead_pete
    panhead_pete
    Wow - just as you finish it you start again. That lace roof looked awesome, hopefully its garage art as of now.
    dutchrod likes this.
  3. ...even your coupe parts match the color...nice work.
  4. topher5150
    topher5150
    This reminds me of my 47. Your way of cutting the top looks a lot easier than the way I did it. IMG_20200501_163941234_HDR.jpg
    EVL401, Okie Pete, Squablow and 2 others like this.
  5. dutchrod
    dutchrod
    Upper quarters tacked in place , now i can start working on the roof line.
    The roof i got is from a long door / sedan coupe and i want build a business coupe so that will be some slicing and hammering to get it right.
    But i’m having fun !
    6C7E16D1-7CE7-4D20-8E17-84E1A788DF53.jpeg 342F0A64-8DF0-411A-91CD-46DE8B7955D3.jpeg
    EVL401, Okie Pete, 40LUV and 3 others like this.
  6. Squablow
    Squablow
    Are the quarter windows the same between the long and short door coupes, or will this end up being a body style that never existed before? Either way I like it, but curious about possible differences.
  7. dutchrod
    dutchrod
    The quarter windows are exactly the same
  8. Hamtown Al
    Hamtown Al
    1. Virginia HAMB(ers)
    ^^I'm not sure I agree about the quarter windows being the same on the short door and long door coupes. I built a 47 short door coupe that comes with fixed rear quarter windows. I also had a pair of rear quarter windows from a long door coupe that would open. They didn't fit... at least not for me!;):D
    I ended up having to use the original fixed rear quarter windows. Anybody else try to change a short door coupe to use the swing out rear quarter windows?
    YRMV:D
    Uribe likes this.
  9. dutchrod
    dutchrod
    I only know that long door coupe and fordor quarter windows are the same.
    The coupe parts i have are from a long door coupe.
    Business coupe quarters could be different.
  10. dutchrod
    dutchrod
    Flattened the roof to get the roofline how i like it.
  11. dutchrod
    dutchrod
    Spent a whole day to square things up and to get left and right side the same.
    Now filling in the pieces using parts of the Fordor roof.
    Tomorrow the gap above decklid will be filled and then the quarters can be finished using parts of the old rear doors.
    EVL401, 40FORDPU, Okie Pete and 4 others like this.
  12. Squablow
    Squablow
    Coming right along, looking good! Do you have plans to use rain gutters? Or to shave them completely?
  13. dutchrod
    dutchrod
    I will make new rain gutters out of round bar .
    Squablow likes this.
  14. dutchrod
    dutchrod
    Panel above decklid filled using roof parts.
    1F3042A5-6E70-465D-8B46-5AC904F97D58.jpg 92DE5312-6952-46F3-B0F0-86948D09EEAD.jpg
    EVL401, Stogy, Okie Pete and 5 others like this.
  15. Tim
    Tim
    from KCMO
    Looking good
  16. Squablow
    Squablow
    Nice re-use of available materials.
  17. Looking good Dennis, hope to see it on the Dutch roads :cool:
    Groeten Hennie
  18. dutchrod
    dutchrod
    Filled the quarters using the rear door skin, starting to look like a coupe.
    EVL401, Rawrench, Stogy and 4 others like this.
  19. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Looking great! :cool:
  20. dutchrod
    dutchrod
    Had to do the panel between trunk and rear window over since it didn't look right, I used parts of the old roof but it had too much crown.
    A made a new panel and now it flows better.
    also made some driprails from round bar
    6603ADC2-2B23-4014-B0EA-B81317A86229.jpg IMG_0357.jpeg IMG_0360.jpeg IMG_0361.jpeg
    EVL401, Rawrench, Stogy and 6 others like this.
  21. Squablow
    Squablow
    Very nice work, looks good, all the lines look right.
  22. dutchrod
    dutchrod
    Didn't had much time to work on it last summer but we are back at it !
    Close to finish the welding ,chasing pinholes and fight oil canning and a lot of grinding ...... IMG_2224.jpeg so soon I can start bodywork.
    EVL401, Rawrench, Stogy and 5 others like this.
  23. dutchrod
    dutchrod
    Bought a 283( I know chevy in a ford ) that I will put in with a adapter to mate it with the stock trans and driveline.
    Will get nice valve covers and air filter.
  24. dutchrod
    dutchrod
    I bougth a 168 tooth flywheel and test fitted the flywheel and adapter that I kept in storage for years.
    I could not find a 51 borg beck mercury clutch that would bolt right up this flywheel , I have a new 10" ford clutch and clutch plate so I will have my flywheel re-drilled.
    EVL401, Stogy, Okie Pete and 4 others like this.
  25. Squablow
    Squablow
    Looking good! Nothing wrong with a 283 swap into a '46 Ford, that's about as traditional as it gets.
  26. dutchrod
    dutchrod
    Hope to have it ready for primer and final sanding by the end of the week .
    also gotta start to make some interior panels.
    EVL401, Rawrench, Stogy and 3 others like this.
  27. BJR
    BJR
    Great work, I like the lower crown roof also. Please, no metal flake this time, just didn't look right on such a nice car.
  28. Incredible!!! Amazing work keep going !!
  29. topher5150
    topher5150
    What do all your Dutch neighbors think about this guy spending day and night in his garage working on old American cars?:D
    Okie Pete and dutchrod like this.
  30. Squablow
    Squablow
    This is turning out really good, glad to see updates! Looking forward to seeing it all in one piece again, well done so far.
