Technical Volvo M40 Transmission Conversion in Model A
Discussion in 'The Hokey Ass Message Board' started by MarcusJ, Nov 16, 2014.
  1. Flatdash
    Flatdash
    Yup, that`s pretty much the only direction to take to keep the torque tube.
  2. Mart
    Mart
    I can tell you it's much harder to make a M41/M410 fit. I'm doing it on a V8. I've got the trans to engine adapt sorted out. all in mock up stage at the moment.
    Where I am not sure is trying to make a torque tube connect to the overdrive.
    If it is not feasible, a conversion to open drive may be the answer, but I would like to keep the torque tube.
    Can any of you fellas talk us through the remachining of the output shafts?
    Mart.
    Outback and chryslerfan55 like this.
  3. rusty valley
    rusty valley
    A lot of the cl***ic car guys put the Lay**** overdrive in the rear of the torque tube. Another machine project.
    Outback likes this.
  4. minijoey
    minijoey
    I've been going trough this topic and read all the posts. Wanting to do the same conversion and keep the TT.
    But am I wrong or is everybody loosing the speedogear on their TT conversion?
  5. If you're using the Torque Tube, will the speedo-gear be on the TT.
    If going open drive shaft, you can use the exit of the M40.
  6. burl
    burl
    from Minnesota
    I ditched the tt and use a gps speado app for speed. The roadster has open drive banjo, and the coupe has open drive ford 9 inch. Everything has been strengthened to run the open drive. The Volvo trans has worked real well for me. E3F02D4E-CB7A-4340-9A38-57E594E3E92F.JPG IMG_6129.JPG
  7. minijoey
    minijoey
    But ofcourse I forgot it was in the TT. Anyway If I don't mind shortening the TT what would be the bast transition to go from Volvo box to Ford TT?
    Outback, Dannerr and chryslerfan55 like this.
  8. Thomas1982
    Thomas1982
    Hello we have Build This Adapter in complete new
    and Sets
    Outback, SS327 and burl like this.
  9. Thomas1982
    Thomas1982
    Outback and burl like this.
  10. Price??
    Outback likes this.
