Hi all - so i dug out the van norman inserto valve seat tool yesterday and decided to give it a try- the main cutter head got broken out by the ebay seller and of course i only noticed this 6 months down the road - anyway managed to get threads cleaned and new machine screws- I need to weld a small section behind the cutter and mill it back into spec- does it matter which rod i use? its just a filler section behind the cutter that takes a compressive load i would imagine- i was planning on a 7018 rod-
Don't see why not. Just remember the SMAW process isn't know for it's surgical preciseness. But it's a good rod choice.
That would be fine if that’s what you have. Eutectic has a rod that I’ve used a lot which I stronger and machines well. 680 is there number. You’d have to buy more than you need though and it’s not cheap. And I agree that that’s a small part to try to stick weld depending on your skill level.
Heat the whole piece to 500 degrees and TIG it. Small pass, let it cool a couple minutes, another small pass and so on until it's built up enough to mill it back down to size.
well managed ok with the 7018, milled it down pretty good enough, only to find the little fixed cutter for the valve size I need has been custom ground down - i did get 4 valve seats in the kit that are a perfect size but the OD is odd - what are the common valve guide sizes - in this case a 1.6" chevy exhaust valve- the van norman shows fractional steps, is that still the case today? I think this system was designed for flat heads because the cutter is almost the size of the valve and the set screw hit the cylinder head :/ guess i threw $500 down the loo on this lot.. ill keep messing with it and see if i can get it to work somewhat ok-
best i could come up with, im going to try and make and adjustable head but these are the 2 set screws i put in.. ill have to turn them down and cut slots i think.. this system is from the 30s or 40s - no cutters available si will have the grind and try make my own.. still learning how to use the lathe and mini mill.. and forgive the porous welding i was using a damp piece of cement to shield the original surface and threaded holes and it caused a mess but protected them well despite spitting..
i have already started machining down an old engine hoist jack shaft for a new cutter, and i think i might try calculate if this was ground on a mt3 taper because the mt2 is a little loose.. ill take some measurements down but bought a taper attachment for tail stock so if i can practice on some nylon till i get it right i might be able to machine the inside to match the original boring head.. then cut in a keyway and try make it take the new style replaceable cutter tips.. i only work on iron chevy and ford stuff, nothing spectacular - just a small marine repair shop i own.
Next time try a piece of copper instead. Aluminum, a carbon electrode. My choices 1,2 3. Ya did good.
Would it be possible to tell if the cutter head is a morse taper #3? My #2 is just a tad loose- I did buy an offset tail chuck for the lathe with a live center to cut tapers with possibly- like to try and fab a smaller cutter with an adjustable blade if possible-
