Projects 1957 Chevy MEL-icious Intent Build
Discussion in 'Traditional Hot Rods' started by fordman1, Jan 16, 2023.
  1. 776
    26.2%
  2. 954
    37.7%
  3. 1007
    26.2%
  4. 1133
    9.8%
  1. fordman1
    fordman1
    Concurrently I was mocking up the Lares 18644 steering box and there appears currently to be ample room for steering shaft. I picked up a steering arm puller from Harbor Freight. I may still need a section of collapsible shaft and a joint but we will see. IMG_8667.JPEG IMG_8669.JPEG IMG_8670.JPEG IMG_8671.JPEG IMG_8673.JPEG IMG_8676.JPEG IMG_8677.JPEG IMG_8678.JPEG IMG_8679.JPEG IMG_8685.JPEG
  2. fordman1
    fordman1
    Look past the ugly welds and lack of on the engine mounts, they are not final. The hole at the bottom of them is to get the socket up in them to tighten them. Not sure how the 60 year old engine mounts will hold up to drag strip launches but we will give them a try! I have some flathead biscuit style ones and I could do a saddle mount or something else down the line. Anyway they are doing their current job of holding the engine in the air which is the main thing.
  3. 73RR
    73RR
    Fresh, stock mounts should survive with a torque strap/chain.
    bchctybob, Atwater Mike, rod1 and 2 others like this.
  4. fordman1
    fordman1
    An adapter nut plus a metric bolt ground down and welded together at least got the shifter ball mounted and adapted to the vintage floor shifter. Don't love it but it will make due for now. I need to trim the m***ive hole a little more and patch it back as well as connect the linkage to the transmission. The plan is to add a plate with some sort of detents so there is no funny business with accidentally shifting into Park or Reverse while taking it down the strip. IMG_8701.JPEG IMG_8702.JPEG IMG_8703.JPEG IMG_8704.JPEG IMG_8705.JPEG IMG_8707.JPEG IMG_8708.JPEG IMG_8709.JPEG IMG_8710.JPEG
    1971BB427 likes this.
  5. I really dig that shifter boot.
    fordman1 likes this.
  6. fordman1
    fordman1
    It was less mangled before the wrecking yard removed it but oh well.
    Jet96 likes this.
  7. chevy57dude
    chevy57dude
    Glad the dash isn't cut up, like so many were.
  8. fordman1
    fordman1
    I would like to see if I can get the stock gauges to work with the different make running gear as much as possible. So no plans to cut up the dash. Eventually I may hang an under dash vintage AC unit but that may not ever happen. Also glad they make vintage looking radios that don't require chopping anything up!
  9. fordman1
    fordman1
    I added a poll so people can guess how much the engine/trans combo weighs. It is a little more than a small block.... ;)
    bchctybob likes this.
  10. fordman1
    fordman1
    Got a few more things done. Trying to pick at it every other day even though it isn’t at my house. Started the process of pulling the window to replace it with the intact used one that came with the car. Mostly just so it isn’t sitting inside the car risking it will also get broke.
    I also started pulling the front off the engine to put on the rebuilt water pump and kill the power steering pump. The MEL version of the timing cover without the pump on the Edsel engine went missing before I picked it up so I may just gut this pump as it is needed for spacing and sealing. I should pull the engine and trans back out for a good cleaning and install new gaskets as well.
    If anyone has some extra Edsel “footballs” that hold down the ears of the intake I would be interested as they switched to smaller ones on these later Lincoln’s. Otherwise I will build up some weld and grind them smooth to give more surface area. 5537F8C7-106F-462A-A248-6A636C373187.jpeg B3554FB5-35A8-4B03-985D-842328C10C26.jpeg CF73E3AF-9E5E-41BA-AF94-8A51864EF4E0.jpeg 9A20CD8D-0C6E-42E2-81D8-40F49B6938E2.jpeg
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    At least the oil filter, steering box and distributor are all still neighbors. :)
  12. fordman1
    fordman1
    There is a little more room then you would expect and the steering box needs to push a little further forward on the frame rail. I was looking at FE remote oil filter kits if it comes to that. There is a Summit Racing Fox Body torque strut on its way that should also fit in this little area. Never fear! Things will get packed in once a super charger is added to the mix.:D
    427 sleeper and chevy57dude like this.
  13. chevy57dude
    chevy57dude
    Blower! Superb.
    fordman1 and 427 sleeper like this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Back in the 80’s I sported a ball cap saying “Injection is nice But I’d rather be blown”. Then one day out of the blue an elderly gal read my cap a giggled. Sorry, never found out if she had false teeth, I just gentle excused myself from the awkwardness.
    Jet96, 427 sleeper and chevy57dude like this.
  15. DDDenny
    Those are the kind of days that just make life worth living!
    Save for the thought of false teeth.
    chevy57dude likes this.
  16. Atwater Mike
    Atwater Mike
    Back in '58 in San Jose I used to go for evening coffee with all my buds (local rodders)
    I got a '54 Corvette in a trade, frame was butchered (had a Buick Nail in it!) so I had to pull the engine anyway.
    Before finishing welding on the frame, I lowered my '46 Merc flattie w/ '39 box into the 'Vette, nice 304" w/Weiand 4 jugger, Edelbrock heads.
    Had the 'crew' over before going to coffee. Christ, it was like a wake! Dissident wailing, near crying, amid cries of, "Oh, Mike!... Don't do it!"
    Took all night and to convince 'em I was kidding.
    But imagine how much further the 'joke' could have gone if I had an F-1 rear open tailshaft and a suitable driveline...and DROVE it for coffee!
    seb fontana, bchctybob, Jet96 and 3 others like this.
  17. chevy57dude
    chevy57dude
    See, this is how it goes off the rails. One minute, we're cruising along, talkin' '57 Chevys ( a favorite subject). Next thing ya know, it's uh, kissing gals without teef! There's no place like HAMB...
  18. DDDenny
    Mike
    That was 45 years ago, are you sure that was coffee!
    427 sleeper likes this.
  19. 427 sleeper
    427 sleeper
    Sound's like it may have been Bong water!!! LOL!!!
  20. DDDenny
    Correction
    That was 65 years ago!
  21. Wanderlust
    Wanderlust
    So I’m guessing you guys have never experienced a “ gummer”
    Jet96 likes this.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
  23. birdman1
    birdman1
    I just want to tell you that the 430 has 2 oil p***ages that come up through the block to feed the rocker arms. I always take a holley .0100 jet and simply push it into the oil p***age at the top of the head where the rocker shaft bolts are. wish I had a picture. then also use the high volume 390 oil pump. It bolts right on. i also shim the relief spring .
  24. fordman1
    fordman1
    Can you further explain shimming the relief spring for me please? Thanks for the other information!
  25. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'll bet if you removed the rear door handles 99% of onlookers would not realize its a four door hardtop. A la Coney Dog wagon.
    EDIT: Chevy 215/235 six footballs should work. They are longer.
    chevy57dude, bchctybob and fordman1 like this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  27. fordman1
    fordman1
    I will look into those! There is actually a 1965 GMC sharing shop space with a 292 and some un used 250s. Great idea.
  28. X-cpe
    X-cpe
    Poorboy way of increasing oil pressure. Pull the pin or whatever is holding the pressure relief valve spring and add 1 or 2 washers, compress the spring and replace the pin.
  29. manyolcars
    manyolcars
    but then you would get all the whiners claiming you are trying to fool someone
  30. 1971BB427
    1971BB427
    from Oregon
    People have been removing and filling in rear outside door handles for decades! It's traditional as anything car related! That's what I did with my old Austin sedan, and people are surprised when I reach inside and open the back doors.
    winr, don colaps, LOST ANGEL and 4 others like this.
