Projects 1957 Ford Fearlane
Discussion in 'Traditional Customs' started by micepower, Jan 22, 2023.
  1. micepower
    micepower
    from Finland
  2. micepower
    micepower
    from Finland
    yes, there will be something green in it
  3. leon bee
    leon bee
    It ain't easy being green.
  4. natrlgas49
    natrlgas49
    Its not my cup of tea but I like to see people step out and build something they like too hell with every one else and their narrow opinions
    Cooon and Callmaker like this.
  5. Budget36
    Budget36
    I’m not even a slight custom guy, but really enjoy looking at the details that are done. So many great ideas to pick up on.
  6. slowmotion
    slowmotion
    From this angle, wow! You do very nice work sir!
  7. Erwin
    Erwin
    Does that chop ever work. Great profile. I like the Camaro bumper too. You really knocked yourself out on the build.
  8. 41 GMC K-18
    41 GMC K-18
    The 57 Ford's are an interesting car, to do a ton of things with. Imagination knows no boundaries!
  9. micepower
    micepower
    from Finland
    Someting for the trunk, and little welding stuff.
  10. micepower
    micepower
    from Finland
    Y-block valve covers
    Dos Cincos, egads and 41 GMC K-18 like this.
  11. micepower
    micepower
    from Finland
    Headlights and fenders moulding
  12. Torkwrench
    Torkwrench
  13. SS327
    SS327
    I never thought headlights in a 57 Ford would ever look good. They looked like they got kicked in the balls and their eyes bugged out! But that tunneling treatment really works on them. Outstanding job!
  14. micepower
    micepower
    from Finland
    that was a good description of the headlights, I also think they look terrible in the original.
    SS327 likes this.
  15. Dan Timberlake
    Dan Timberlake
    Is the width of the eyebrow in the 57 fender the same as the 58 with quad headlights ? 1957 1958 ford .PNG
  16. aussie57wag
    aussie57wag
    from australia
    Would of been better to actually use the y-block instead of try and cover up your mistake.
  17. trevorsworth
    trevorsworth
    He's in Finland. I can't fault him for sticking to what's easier to get and maintain.
    micepower, Torkwrench and j hansen like this.
  18. sunbeam
    sunbeam
  19. aussie57wag
    aussie57wag
    from australia
    No difference in simplicity to maintain between a y-block and a Windsor.
  20. trevorsworth
    trevorsworth
    Except in terms of parts availability... you guys have lots of Y-blocks down under, Finland doesn't. If he could even find one in the first place it would be really expensive to get parts for it. Windsors are still supported by modern aftermarket, and vehicles that came with them from stock were sold in Finland.
    micepower likes this.
  21. aussie57wag
    aussie57wag
    from australia
    Actually y-blocks are equally easy to maintain. You can you the same aftermarket carb and electric fuel pump on both. Also with minor modifications the same distributor. So fuel and ignition systems can be identical. Or both can use a aftermarket distributor (example pertronics). There is a strong aftermarket available for the y-block. Anything is available online.
    Torkwrench likes this.
  22. micepower
    micepower
    from Finland
    Yes that right!
  23. aussie57wag
    aussie57wag
    from australia
    That's actually a wrong ***umption.
  24. TheSteamDoc
    TheSteamDoc
    One mean looking Ford!
