Projects Upcoming Winter Projects 2022. HAMB Friendly Post Em'
Discussion in 'The Hokey Ass Message Board' started by corncobcoupe, Nov 14, 2022.
  1. LOUDERMILK64
    LOUDERMILK64
    from INDIANA
    The firewall is from direct sheet metal, when i got the car the bottom 12 inches was gone
  2. PONTNAK123
    PONTNAK123
    removing stock drivetrain and installing 350 v8, turbo 350, ford 8 inch, drop axle, etc etc thumbnail_20220803_210048 (1).jpg thumbnail_20220724_120330.jpg thumbnail_20220830_115107.jpg
  3. Cannot wait for the build threads on both of these.
    chryslerfan55 and PONTNAK123 like this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    6C9C55BD-47A6-4329-84A8-696F69083269.jpeg FDB9524A-89A4-428B-A781-EE47A514BD52.jpeg Getting closer. Going over with 220 then 400. Not much more. I hate sanding. At this point I could consider a color change.
  5. F-head
    F-head
    Got this the end of June 1CCCEC13-C452-4AFE-BAAD-CC44BA55FBF5.png 6307CF8C-A543-4FA9-AB85-E31831BEC2D4.png 6960A22E-042F-4B0C-9934-12FAD01BC38F.png
    Tim, joel, PINEAPPLE and 16 others like this.
  6. Lloyd's paint & glass
    Pulling a small block, putting it in my wife's truck, and building the big block for my car. We'll see how far we get.
  7. stanlow69
    stanlow69
    I`m dreaming of bubble skirts and Studebaker fins. And lake pipes. ????
    PONTNAK123 and 210superair like this.
  8. Paint this one 41 Chevy Ruby Maroon.
  9. having been playing at Bonneville for a decade I find myself wanting to build another hot rod. Looking around, I have enough parts to screw together a couple early hot rods. So I am in the early stages of planning a 27 for this winter....the parts look about like what @alchemy posted above. The only question is 27 Roadster OR 27 Modified? A Mod would certainly be quicker. Either will go on an extra A ch***is that I have.
  10. Dan Hay
    Dan Hay
    For the first time since 1982, this dependable family heirloom will be coming apart for needed repairs and upgrades including but not limited too: stance correction, wheels/tires, Engine refresh with more horsetorques, OD trans., New AC system that blows harder than it's current volume of just above a whisper. Probably take me two years.
    Tim, Kreepea_1, guthriesmith and 10 others like this.
  11. justabeater37
    justabeater37
    C46D06D2-5E59-45CB-8E07-861C4883E72F.jpeg Step one, get this thing in paint. Still waiting on the proper hood sides that have been on order since July. Step 2, Get my RPU running, Step 3, put together another 3 window body. [​IMG]
  12. Kreepea_1
    Kreepea_1
    20230123_103536.jpg Giving the Chevy a dose of SBC, McGurk, Holley, and Muncie.
    Tim, LOST ANGEL, 41 coupe and 4 others like this.
  13. Rocket88NZ
    Rocket88NZ
    Keep chipping away with this. P1040452.jpg P1040448.jpg IMG_5530.jpg P1040450.jpg
    Keep chipping away at this.
    Kreepea_1, milwscruffy, Tim and 9 others like this.
  14. flamedabone
    flamedabone
    I sneaked a quick one in on you.
    Just a little Comet hardtop, should be done by spring.
    -Abone.
    Muttley, CSPIDY, PONTNAK123 and 3 others like this.
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I frigg'in trying!!!!!
  16. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    ^^^^^^ The faded paint looks shiny.. you linseed it or ?
    I know you didn't clear it.
    @Jeff Norwell
    Jeff Norwell likes this.
  17. alchemy
    alchemy
    I’ve been working on this touring a lot this winter. Piecing the body back together from many different sources, hopefully straight. And a little machining of some parts.
    Kreepea_1, CSPIDY, PONTNAK123 and 4 others like this.
  18. guthriesmith
    guthriesmith
    Bought this 40 Merc a couple weeks ago, but not sure how much I will get done this year. I figure the main work on it will be collecting parts and planning the chop, rust repair, suspension work, which engine to use, etc.
    CSPIDY, PONTNAK123, Dan Hay and 2 others like this.
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    No linseed.. I just cleaned it and gave a coat of Owatrol.
    CSPIDY and guthriesmith like this.
  20. sko_ford
    sko_ford
    I'm still picking away at my T rpu
  21. RMR&C
    RMR&C
    from NW Montana
    Some progress. 5 inch chop.
  22. D-Russ
    D-Russ
    The F100 is an ongoing personal project and the 302 is for the Virginia HAMB Special.
  23. PONTNAK123
    PONTNAK123
    dec 6th 2022. 15 k mile az 40 convert original paint original interior . flattie with columbia. before pictures thumbnail_20221108_125316.jpg thumbnail_20220724_120326.jpg
    guthriesmith and 40ragtopdown like this.
  24. PONTNAK123
    PONTNAK123
    4 .5. 23 158 hours later 4 inch drop , split bones, disc brakes,350 , turbo 350, maverick 8 inch, weedeter ch***is kit ,weedeter coloum shaft and horn kit, lime works 40 column auto conversion, champion radiator , lots of thumbnail_20230405_143306.jpg thumbnail_20230322_110917.jpg thumbnail_20230322_110933.jpg thumbnail_20221030_135949.jpg thumbnail_20230405_143240.jpg thumbnail_20230405_161855 (1).jpg thumbnail_20220724_120335.jpg thumbnail_20230405_161841.jpg cl***ic instruments ,lots of so cal speedshop, wheel smith wheels, cali tires, borgeson box . 2 1/2 stainless exhaust . big sway bars and panhard . trans mount and center section kit from Gary aka 40 ragtop down ,just drove 25 miles today and it drives and handles awesome. needs good cleaning and 48 merc no script caps and finish the a/c.
  25. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Man that's *****in'
  26. PONTNAK123
    PONTNAK123
    thank you corncobcoupe !
