Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. 64 DODGE 440
    64 DODGE 440
    from so cal
    WTF??
  2. Old6rodder
    Old6rodder
    from SoCal
    Pressure plate on the Barn Job. Hit the ****ter shield hard enough to bend it, pulling both frame rails in. Hence, the spreader. :oops:
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
    Forgot about that one. Back in the days you sat in front of the engine.
  4. roseville carl
    roseville carl
    looked like that could have been UGLY there, ****
  5. roseville carl
    roseville carl
    Got a little done tonight, made a stiffner for radius rod 20221027_182107.jpg
    test fit
    got er tacked in place
    now on to finish welding then get the other side done...............
  6. roseville carl
    roseville carl
    ok now maybe its T&T time again........
    from this....
    to this..............
  7. Harv
    Harv
    from Sydney
    G'day Carl,
    A quick question please. I should get my FED ch***is home in the next month or so. Similar paint scheme - black rails with chrome at the front end (... am dreading going to chrome jail). I'm not sure whether to paint the rails (probably 2-pack) or get them powdercoated. Costs will be similar. According to legend both powdercoat and 2-pack are hard to touch up, but not impossible. Have heard both can be durable (resistant to knocks) but not impervious.
    Appreciate your views please.
    Cheers,
    Harv
  8. roseville carl
    roseville carl
    hate to say this Harv but my frame is painted with Rustoleum Gloss Black from quart can and spray gun, and for touch up use I use a brush. Not show quality but works for me and is p***ible and easily repairable. Since I didn't have the front end rechromed, just cleaned er up and sprayed Rustoleum chrome paint on the parts messed up, it works for me.......,.
    Also for me as I am always trying new **** it doesn't fit into my plans to powder coat anything that I may be welding on in the future............
    chryslerfan55, AmishMike and Blues4U like this.
  9. joemac05
    joemac05
    If it don't go chrome it. if its a working girl no one will notice it's just paint... <Grin>
    It took me years to get my sprint car racing partner to quit powder coating everything. In compe***ive sprint racing you are always either repairing or redesigning the dammed thing. :confused:
  10. spanners
    spanners
    What Carl says is right especially when getting started. You will modify bits and powder coating is the worst to touch up.
    Mine's not show quality in the slightest so I used Dulux black enamel from that hardware store. It's been on there for nearly 10 years and over 600 p***es and holds up ok. I touch it up with rattle can if required.
    AmishMike likes this.
  11. roseville carl
    roseville carl
    Been helping a friend with his car, Eagle in May.....
    20230121_121315.jpg 20230121_121324.jpg 20230121_121334.jpg 20230121_121343.jpg 20230121_121353.jpg 20230121_122653.jpg 20230121_122703.jpg 20230121_122716.jpg 20230121_122725.jpg
  12. spanners
    spanners
    Looks good Carl. Looks fast standing still.
  13. roseville carl
    roseville carl
    Also today in Forever 43
  14. spanners
    spanners
    I don't blame you for getting excited. Bet your neighbours love you.
  15. dreracecar
    dreracecar
    from so-cal
    Looks sharp, the only criticism are the steering arms, IF you are running the ty-rod in front of the axle, you need to bend them out towards the wheel as much as you can. the Ackerman is so off, that if you turn the wheels full lock , the outer wheel radius will turn more/sharp and scrub . It will not be perfect, but a whole lot better than it is now
  16. roseville carl
    roseville carl
    thanks will tell him.......
  17. ukgav
    ukgav
    Just catching up with this thread. Fantastic!
    I had some flathead FED fun last year in this 'loaner'.
  18. spanners
    spanners
    Please don't take this the wrong way. You've had more to do with building fast cars than I ever will but I'm curious why you're concerned about Ackerman angle on a drag car. Mine is set up like this and is a one hand steer at admittedly just on 100mph 1/4 mile.
  19. dreracecar
    dreracecar
    from so-cal
    No Problem--- If you can do it correctly and without any measurable expense--- Why not??? You still have to turn the car to get it off an on the track. If you have the chance, look down on your front end from the top of a ladder and have somebody turn the wheels, Some people are more worried about the amount of toe in or out then they are steering geometry. For the race cars I build, front tires are extremely expensive and anything I do that can prolong their life is money in my pocket. Nice Engine, I too am building a Chevy II for my dragster,
  20. dreracecar
    dreracecar
    from so-cal
  21. spanners
    spanners
    It steers good enough to turn at the end of a run but yes, I wouldn't like to be negotiating a supermarket carpark with it.
    My engine is a Holden Grey six cylinder motor approximate 1956 vintage. 138 cu.in. of tar tearing power:D.
  22. dreracecar
    dreracecar
    from so-cal
    Again your car and you have every rite to build it the way you want. In my business "Good enough" doesnt work
  23. spanners
    spanners
    Once again, I'm not h***ling you. In fact I envy builders such as yourself for what you construct. I bought this as an unfinished project and the frontend was already installed. I decided to leave it as was and try it. The original wheelbase was 103" but I added a frame section to stretch it to 113".
    Sorry Carl, I didn't mean to railroad your thread.
  24. dreracecar
    dreracecar
    from so-cal
    Its not "HIGHJACKING" when a discussion on issues. Many look at the pics to give them ideas on how things are built an take it as gospel to copy for their builds. Even Aftermarket racing spindles have it wrong when they include arms, cant take into account the many variations that exist, But it does a better job when the ty-rod is behind the axle. In front just adds more problems because one turned the spindles around
  25. roseville carl
    roseville carl
    there is no Highjacking when important issues are brought up........
    by the way nice car UKGAV love it!!!!
  26. ukgav
    ukgav
  27. youngrodder1929
    youngrodder1929
  28. roseville carl
    roseville carl
    great Saturday
    ALCAN AV8 and loudbang like this.
  29. Darren Simas
    Darren Simas
  30. roseville carl
    roseville carl
    another great Test n Tune
