Technical Halibrand 101 Parts
Discussion in 'Traditional Hot Rods' started by JT1930, Apr 16, 2022.
  1. JT1930
    JT1930
    Does anyone have part numbers for all the bearings/parts needed to a halibrand 101 case.
    I know hotrod works has the pinion shaft and lower shaft that fit. Are the 101 and 201 all the same bearing sizes ?
  2. gimpyshotrods
    gimpyshotrods
    Yes. Bruce knows, and can likely supply you with them.
    @GearheadsQCE
    JT1930 likes this.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Gimpy,
    Thanx for the vote of confidence :) but the Halibrand 101 is not my specialty. I answered JT1930 in a private conversation, but then I got to thinking that maybe I should share with everyone and that might cause someone with better information to respond.
    Here is what I said,
    "I'm not going to be of much help on this. I have very little knowledge and even less experience with the 101.
    My guess is that the pinion shaft bearings are the same as the 201. The rear cover bearings did come in two O.D.s
    The front and rear lower shaft might also be the same as the V8.
    So, here are my guestimates:
    Lower Shaft Front - SKF 306 (sealed)
    Lower Shaft Rear - SKF 206 (shielded)
    Pinion shank - SKF 307 (open or shielded)
    Rear Cover - SKF 304???? (open)
    I may have some of these, but I don't usually stock them as most of my stuff is either Champ sized or Winters V8, which use different bearings.
    I don't have any of the other bits and pieces for the 101 QCs. I can supply HRW parts but they will be the same price through me as if you buy directly from them."
  4. briphaeton
    briphaeton
    from cal
    I would appreciate help identifying this Model A no name QuickChange ? It's uses the same bearing as a Halibrand V8 QuickChange
    Thanks, Brian
      671.5 KB
      699.3 KB
      572.6 KB
    5window likes this.
  5. 51 mercules
    51 mercules
    These are all the parts and numbers I got with my Halibrand 101.I sold it and never put together, so you might want verify the numbers.Hot Rod Works might be able to help you too! Hotrod Works Lower Shaft # 1271
    Hotrod Works Pinon Shaft #1270
    Speedway Rear Cover #4152936102
    Speedway Rear Cover Bearings #912b6304
    Speedway Pinon Bearing #912B6307ZZ
    Speedway Lower Shaft Bearing #9126206SZZ
    Speedway Lower Shaft Bearing #912B6306
    Speedway Front Seal #912S15522
    Speedway Spacer Kit #912B6304 and a couple of misc bearings.
  6. krylon32
    krylon32
    from Nebraska
    Buy all your quick change parts from the boys at Hot Rod Works, you'll be glad you did.
  7. Atwater Mike
    Atwater Mike
    My ex partner in the old shop had a T roadster built in late '40s. Halibrand quickie, lay shaft was badly galled.
    I called Teddy Halibrand, he sent a shaft up to us, completely wrong. Length, spline, diameter.
    Got back on phone, he said "There were a sparce few like you describe, very early. I don't even have drawings..."
    Possible? (Was this '101' the ONLY other possibility?) Years later, Mark Codd told me of HRW.
  8. JT1930
    JT1930
    I did. They were very helpful also.
  9. 51 mercules
    51 mercules
    That looks about right. Those numbers correspond with last 3 digits of the bearings from Speedway I got with my 101 quickchange. Hotrod Works Lower Shaft # 1271
